Palsonic LCD TV tftv93hdt. Vertical lines ,no picture when TV turned on, sound ok, eventually after many 'turn on/offs' ,picture comes on- however takes longer each day
  • 50 Answers
SOURCE: thin red vertical line on sanyo lcd-37xr1
Sounds like your display panel is going out. Has the tv been droped, or hit by anything? You should call your customer service number to confirm.
Posted on Feb 27, 2008
  • 84 Answers
SOURCE: Sony Grand wega KDF-E50A10
unfortunately the B Box assembly needs to be changed in these and price of the part alone is more than half the cost of a new tv
Posted on Apr 19, 2008
SOURCE: Vertical Color Lines with Sound
so did anyone every figure out what the problems with the controller is I have a TV with the white vertical lines and would rather fix it then replace it, very good with electronics but have never worked on a plasma TV before.
Posted on Jun 11, 2008
SOURCE: when I turn on my lg lcd tv the picture goes out
Go to http://www.lcdparts.net/LCDTVInverter.aspx and purchase there improved aftermarket inverter boards as the OEM replacements will often soon fail again.
Posted on Nov 14, 2009
SOURCE: Turn on Samsung LN-T4665F and vertical colored
when I turn the modelLN-T4661F TV on it just clicks and clicks any help how to fix it.
Posted on Nov 29, 2009
Sony bravia KDL-50W800B got only vertical lines when turn on.
You need to take it to a TV repair service, preferably one that specialises in Sony TV's. There is nothing you can do to fix this yourself.
Jun 16, 2016 | Sony Televison & Video
When I try to retune TV to pick up new TV stations I get sound OK but a black screen with message invalid format.
Check stations MPEG format . Check if it is MPEG4 and check if TV can decode MPEG4 . A firmware update may be available on tv and may fix it but it has the risk of turning the tv into a brick if something goes wrong during a firmware update.
suggest contacting palsonic to see if firmware possible and which one to use.
http://www.palsonic.com.au/customer_service/upgrade/default.htm
Feb 23, 2016 | Televison & Video
I have a Sony Bravia KDL 52W3000 LCD TV that frequently displays vertical lines when it is turned on.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 29, 2015 | Sony Televison & Video
Sharp 32" lcd tv vertical lines on screen
sounds like you have receiver connection problem..
To test it try to play dvd on your TV..if the picture is fine your TV is good..your problem is on the cable box or receiver..
Nov 06, 2012 | Sharp LC-32AV22U 32 in. LCD TV
Sound but no picture with vertical lines
its sounds that you have a bad t-con board, but before you come up in trouble shooting with in the t-con board. you must check first the power supply board if has bulging electrolytic capacitors and common is leak.
Oct 10, 2012 | Element Electronics FLX3210 32 in. LCD TV
I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Jan 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Insignia LCD 27" w/vertical lines for picture
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Mar 09, 2008 | Insignia LCDTV26 26 in. Television
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
