Comfort Maker Gas furnace Model number AS48M180T will not stay on long enough to heat home
2 Suggested Answers
hotuna
  • 288 Answers
SOURCE: gas furnace wont stay lite
I'm a little confused by your terminology. You are saying you have a pilot lite and electric heat strips? Are you possibly meaning burners? Is the heater running for 2 hours straight without shutting off? how cold is it there? Lastly what temperature do you have the thermostat set at and how close does it get to the temp. before it shuts off?
Posted on Dec 20, 2007
I AM WORKING ON A COZY W501E WALL FURNACE AND CANT GET THE PILOT TO STAY LIT. i HAVE CHANGED THE GAS VALVE, THERMOCOUPLE,AND THE SENSOR FOR THE HIGH LIMIT. THE PILOT WONT STAY LIT.
Pretty much the only thing that will do that is the thermocouple not generating enough voltage for the valve to say it's OK.
Usually you need to hold the button for pilot lighting for 60 seconds. You can use a meter to check that it's generating enough power. The thermocouple has to be in the pilot flame properly.
Check this video:
https://www.youtube.com/watch?v=suen7QlJl4o
Gas furnace will not light Thermocouple test with the multimeter
Or see this site:
How to Test Thermocouple with Multi Meter Heating and Cooling
Feb 11, 2015 | Cozy Heating & Cooling
How do I tell the age of my Comfort Maker furnace?
Check for a serial number. Inside the door or near where the wires go in.
Sep 13, 2014 | Heating & Cooling
What is a two stage furnace?
Two stage heating is a method to make your home more comfortable while reducing your energy. Sound contradictory? Well, that's the truth. Two-stage furnaces are designed to operate like two separate furnaces, maintaining more consistent comfort levels throughout the home. Your furnace or air-conditioner maintenance group will be able to give you more information regarding their working, but I'll explain the basic facts.
A two-stage furnace will always start in the first stage and attempt to meet the heating demand. During mild winter only the first stage will be required that to running at about 60-70% of its efficiency.When temperatures drop, the furnace adjusts itself and enters the second stage to meet the demand for heat within the home. With two-stage heating, a homeowner has no need to keep adjusting the thermostat.
Jan 17, 2014 | Dayton Gas Furnace Heater
Gas valve clicks when furnace is running
is there a second call for a flame on during the heat cycle..it may be worn out or the signal to open is not strong enough..
Jan 08, 2014 | Honeywell Icp Heil Tempstar Furnace Spark...
How do you lite the pilot lite on a Rheem Gas Furnace Model #rgma-125a
If I recall correctly, model number Rheem furnace you listed has electronic ignition to light the pilot, when the home's thermostat calls for heat. Is this what you're having a problem with?
Mar 11, 2011 | Heating & Cooling
Furnace does not turn on normally
Having to reset it tells me that there is probably an error code blinking on the control board. Look for a small viewing port that looks into the cabinet. Count the number of blinks then remove the panels to find the wiring diagram pasted on one of them. On the diagram you will find a diagnostic code to help you narrow down the problem. It could be as simple as a plugged air filter.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Feb 07, 2010 | Goodman Heating & Cooling
Thermostat T87
how old is unit? Sounds like it may be short cycling which could be do to it going off on limit.
Sep 15, 2017 | Honeywell CT87B ROUND HEATING&COOLING...
Furnace pilot is not igniting.
the first blower you hear is the inducer motor it pushes the exhaust out. sounds like abad gas valve.do you have a standing piloit light or is it eletronic ignition. if electronic and there is no glow you have a bad ignitor
Oct 04, 2008 | Honeywell Power Humidifier: Furnace...
Cycles too soon
If the thermostat has been changed since last heating season maybe a thermostat setting.
Dec 28, 2007 | Heating & Cooling
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
