Question about Singer 8763 Curvy Computerized Sewing Machine
Infernal beeping on singer curvy 8763
On the singer curvy model number 8763 which wire can i clip to get rid of that infernal beeping/stopping. I have cleaned out the entire machine of any lint i can find. Made sure the buttonhole wasn't engaged. Re-threaded it repeatedly. Made sure the bobbin case was in correctly. Changed the tension, turned it off, then changed the tension back to auto. Changed out the needle. Made sure the needle was tightened. All of this was in the past few days. It has been beeping at me for months no matter what i do to fix it and the worst part is that it decides randomly when to stop beeping and will sew fine for a few minutes until it starts back up again. I have never had a problem with the tension and it has always sewed just fine, i just need to know how to get rid of the beeping altogether as that is making me want to chuck my machine out the window.
SOURCE: With my K6 Industrial Singer
Hello there, loosen your top thread tension,if it looping on top of the material the tension is way too tight, you will also find changing the thread size to smaller thread, the top tension will also reduce,depending on application a good size thread to use is 25 grade,bobbin tension should have just a slight amount of drag as the top thread and bottom work against each other when sewing.
Posted on Feb 03, 2009
  • 383 Answers
SOURCE: How to adjust belt tension
When you say 'Vintage'-- how old are we talking about?
Please describe the belt...
Is this an old Pedal (or platform that you rock your feet, to make the drive pulley go around)
Is it a 'pedal' powered machine?-- one with a round leather belt?
If it is the latter--
Is that belt all dried out?-- or is it still supple and still providing a good surface to grip the grooves of the 2 pulleys?
Tell us more-- maybe we can help.
Mack B
Posted on Jan 10, 2011
  • 264 Answers
SOURCE: I need a threading diagram
The upper thread flows from the left to right as it goes through metalstems (posts) with holes, along the top of the machine head, and thendrops down and passes over and under the upper gension disk and thetake up spring.  Then, moves back up to the take up arm (which moves upand down like a goose's neck when turning the handwheel) then startsthe trip down to the needle, going through a couple metal loops (calledthread guides) and lastly through the needle thread guide and throughthe needle eye, as I recall from left to right (?), this part is moreobvious when looking at it.
Heres a link to a manual for that machine. hope this helps
Posted on Jan 13, 2011
  • 415 Answers
SOURCE: I amhaving trouble with the
Check the upper threading and make sure it is threaded correctly. When you pull on the thread before it goes through the needle does it give a bit or does it break? If it is breaking when you pull then the tension is way too tight or it is threaded incorrectly. Make sure it isn't looped around some guide along the line too.
For the bobbin thread... when it is in the bobbin case outside of the machine dangle it by the thread. It should hang there until you flick your wrist a bit, which should cause some thread to release and drop the bobbin down towards the floor a bit. (If it just pulls out right to the floor it is too loose). Most bobbin tension is tightened by a small screw on the bobbin case near where the thread comes though. Breaking thread would not be from the bobbin thread being too loose. Too loose would cause looping on top side of the stitch not breakage.
Make sure the bobbin is in correctly. You should feel and hear a slight "click" when the bobbin goes in correctly.
Posted on Apr 27, 2011
  • 710 Answers
SOURCE: looking for threading diagram for
Hi tusnig,
You can get a manual for your machine at the following website:
Copy and paste the address into your browser and go.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Jun 22, 2011
I need a manual for my Singer Curvy 8763
You should be able to get it here ( ) . if your browser doesn't care for direct pdf links, the service page at singer to click and grab the manual is here (
Instruction Manuals ) Type in 8763 for the model number, and you should be off to the races. The manual I opened up started out all in French, but it switches to English a bit later.
Good Luck!
Nov 12, 2015 | Singer Sewing Machines
I buyed a new sewing machine curvy 8763 and when i start trheading the bobbin the needle stats working as well and it starts beeping
Consult your owner's manual. There is a handwheel release that, when loosened, will allow the bobbin to wind but stops the needlebar trying to stitch.
Oct 24, 2015 | Singer 8763 Curvy
Does the singer curvy 8763 have a low shank
Yes, your machine takes a low-shank foot. That seems to be the most commonly used type for newer machines.
Jul 14, 2014 | Singer 8763 Curvy
Needle position
Please correct down position and remove the foot and switch off machine. Then set of the up position applique the needle. After machine On.
Nov 21, 2013 | Singer 8763 Curvy
Need a open darning and walker foot for my curvy 8763 which should i purchase?
A Curvy isn't an Athena. I have a Curvy and it is a low-shank machine that can use a variety of snap-on feet.
Mar 15, 2013 | Singer 8763 Curvy
I have Singer curvy 8763 and want to purchase a walking foot for it. Will you advise please
Your machine takes a low-shank foot, and they are very commonly available, either from eBay or Amazon, or any site that sells presser feet.
Jul 25, 2012 | Singer 8763 Curvy
I have Singer Curvy 8763. It seems that the foot control stopped to work. The machine does not sew, its impossible to wind the bobbin. It is possible however to sew backwards with the help of reverse...
I be s 8763 was sewing beautifuly, took off pressure foot to make a buttonhole read the manual followed directions button holer kept gumming up with thread and the alarm kept going off, then got flustrated, put back on the sewing pressure foot now it is like the needle is out of line will not pick up bobbin, and is definately hitting something by the bobbin, will not sew
Nov 04, 2010 | Singer 8763 Curvy
Singer 8763 Curvy Computerized Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
