Question about Whirlpool Refrigerators
What year is my whirlpool refrigerator, model ED2FHE
We are trying to determine the age and approximate value of our whirlpool side-by-side (white) refrigerator. Model # is ED2FHE. It has 21.9 cu. ft w/ ice/water dispenser in door. Everything thing works & runs well.
fridgetech
  • 473 Answers
SOURCE: Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Posted on Oct 14, 2007
  • 23 Answers
SOURCE: Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Posted on Dec 08, 2007
  • 42 Answers
SOURCE: Our refigerator is not cooling .
Hello Laura,
If you look at the rear wall inside the freezer compartment down low and find a bunch of frost on that wall, you have an automatic defrost system failure. The most likely part that has failed is the defrost thermostat. It is located on the top of the freezer coil, clipped onto a piece of tubing. It will have 2 wires coming out of it and it is about the diameter of a quarter and about 3/4" tall. To test this part you would need a test meter and enough skill to check if the contacts are closed when the thermostat is frozen withing the specifications stated on the thermostat. I believe yours would close at 25 degrees F and opens at 47 degrees F. Part # 5303918214
I hope this helps you. supertechks
Posted on Mar 28, 2008
SOURCE: I have a GE side
Well, the solution to this problem was posted in this thread
http://www.fixya.com/support/t1295372-ge_profile_ref_ice_despenser_motor_not
It seems that the bulb in the front panel is pulling to much current as it ages and it makes the control panel in not work properly. Removing the bulb will fix the problem - just fixed mine.
Also seems to match your symptoms (works sometimes and then not others - bulb current is inconstent, light dims when dispense lever pressed - again wrong current draw).
Good luck
Posted on Apr 19, 2009
Sea Breeze
  • 4655 Answers
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? appliancepartsse@yahoo.com
Posted on Jun 05, 2009
Wondering resale value to request on a whirlpool refrigerator model Ed25 Qf
It would be better to post the age, condition, and details (cubic feet, ice maker, etc.) rather than the model number.
Feb 02, 2015 | Whirlpool Refrigerators
Can you tell me age by model # Whirpool ED25SMXL 25.4 cu ft
Thanks you for your question.
The age of your fridge should be a 1993 made the 25th week of 1993.
The age is determined using the 2nd letter for the year and the 3rd and 4th digits represent the week it was built.
I hope this helps you. You can also visit the link i have provided for your viewing.
http://www.electrical-forensics.com/MajorAppliances/WhirlpoolDateCodes.html
Aug 24, 2011 | Whirlpool Refrigerators
What year was electric kenmore dryer 110. 86574110 65741 made?
The year and approximately the month Whirlpool and Whirlpool-made appliances can be determined from the serial number. The second letter in the serial number indicates the year while the first two digits of the number indicates the week the appliance was made. Locate the serial number then click on the link below for the details on how to determine the age of your Whirlpool-made Kenmore dryer.
Determining the Age of Dryers and Washing Machines Made by Whirlpool
Apr 08, 2011 | Kenmore 75944 Gas Dryer
Need urgently Door handle for whirlpool refrigator model GNF 220X
Check with Repair.Clinic.com. They have replacement parts for a large number of appliances. Step by step replacement instructions are also available. You'll need the approximate year of manufacture, model #, and serial # of the refrigerator.
Mar 06, 2011 | Whirlpool GS6SHAXMB Side by Side...
Can you tell me tha age of a dryer if i have m and s numbers of unit if so m 110.72062102 s mr1304865 kenmore
The dryer is made by Whirlpool and its age can be determined from the serial number. The second character (R) is the year while the first 2-digit of the number (13) is the week on that year the dryer was made. The dryer was made on the 13th week of the year code R which is 2004. The dryer was made approximately on April 2004, about 7 years ago. Click on the link below for further details on how to determine the age of dryers and washers made by Whirlpool.
Feb 23, 2011 | Kenmore Dryers
What year was Whirlpool Fridge Serial nummber
To determine thage of your appliance you need to have the serial number also.
Check out this tip from another expert and compare your serial number to find the age of your fridge.
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
Heatman101
Jan 08, 2010 | Whirlpool Refrigerators
Whirlpool model HAXNQ : lights out on fridge side only
Hummm... I would suspect your DOOR SWITCH on the fridge side... $11.321 shipped... eBay!
Anthony
Whirlpool 1118894 Door Switch
Dec 02, 2017 | Whirlpool GS5SHAXN Side by Side...
Whirlpool Conquest Gold White Model# - GS6SHAXLQ03
The relay is the start device,but you need to determine if you need it,try to see if you have power to the compressor,is the compressor running,is the condenser fan motor running,is the coil under the unit clogged with dust,if the fan under the unit doesn't run it will overheat the compressor and it will go off. and if the coil is clogged the same thing goes.
 Usually if the relay is bad the compressor will make a hum and a click noise but will not actually run.about every 5 minutes..
Sep 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator box is cool. At temp of approximately 42 degrees. Freezer does not function. Cooling fan is constantly running.
sounds like you have a freon leak and need a recharge. honestly if it has some age on it, best to buy a new one, over the last few years std freon has changed
Aug 19, 2009 | Whirlpool GD2SHGX Refrigerator
Refrigerators Logo
71 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
