Question about Toshiba Satellite M105-S3021 Notebook
When playing DVD sound stutters and gets slower and slower
When trying to play a short DVD, everything loads as usual. The sound/music comes on and the sound skips and gets gradually slower. I don't want to spray air into the actual disc drive until I talk to an expert. The sounds from songs on music library are fine.
Haven't had a single problem with this laptop. It pretty much sits in the same place in my home office, but i haven't opened up anything in the back to clean it ever since we bought it. Could it be a dust problem?
By the way, the exact number is Toshiba Satellite M105-S322
You have to look for audio uploads for your machine additional audio bass drivers
Posted on Jan 18, 2009
When I play DVDs on my HP Pavillion dv5220, the sound and picture lag even when using different DVD playing programs. Why is the DVD stuttering, and what can I do to fix it?
Try using a third party program like WinDVD or InterVideo. You can get free downloads of a lot of them, and HP has never had the best record for player technology so they can use all the help they can get!
Dec 31, 2012 | Computers & Internet
My gateway M-6846 notebook stutters when playing music. How can I fix this?
this can be caused by a number of things
are you playing music through your cd rom
If you are using your CD/DVD drive, use a cleaner.
The lens may be dusty and causing skips/stutters place a couple of drops onto the cd and run it
scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run
also under processes see what is ticking over in the background again if you see something you
dont need to be running select end now you might have a virus or malware
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer which can affect all of your computer
hope this helps
Aug 22, 2012 | Gateway M-6846 Notebook
Disc shows loading then error on all dvd disc
Put a cd in the dvd player if it is marked that it plays cds... if it plays the cd your dvd laser is shot... cheaper to get a new unit. if it doesn't play a cd try cleaning the laser. and last but not the last thing try unplugging it for a short time then plug it back in... if nothing works get the one tool that fixs most everything...... take it to office depot and they can recycle the stuff inside and help keep the earth green...then onto wally world.
Nov 26, 2009 | Philips DVP5140 DVD Player
DVD plays well until it stutters midway thru and
If it only happens with one disc, try using a Disc Doctor/Skip Doctor on it. These instruments will repair scratches and depending on the disc, repair pinholes in the disc. Usually it's just polishing the surface of the disc. Some instruments totally resurface the disc by stripping off a thin layer of the disc to remove scratches and other damage. (Used game/music stores will do this).
Aug 29, 2009 | Panasonic DVD-RV31 DVD Player
Created and burned a DVD with imac (iDVD) software. Plays fine on computer, but music skips when I play on Zenith DVD Player. Tried burning at slower speed, but same issue. Can anyone help? Thanks.
The Audio file may not be supported on the DVD player, or try another disk in the DVD player (another movie) see if the sound still skips
you could check the red and white audio cables (or HDMI if you have it) make sure they are not loose or disconnected
Feb 28, 2009 | Zenith DVB312 DVD Player
Sony vaio fsn 740/w audio and video stuttering
Please make sure that if you have not already applied this update that it is applied to your system.
http://support.microsoft.com/kb/952709
Please read the more info section to see if this update is applicable to your system's problems.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Nov 29, 2008 | Sony VAIO PCV-R547DS PC Desktop
My go video dvr4400 does not play homemade dvd's
Usually it isn't the speed of the homemade DVD but the type. DVDs come in four different formats:
DVD+R
DVD-R
DVD+RW
DVD-RW
Some DVD players will play all formats and some don't. Your manual should tell you. Do you know what formats are available for playback on your Go video?
Nov 20, 2008 | GoVideo Go Video DVD/VCR Combo
Creative Sound Blaster Audigy Value Problem
Make sure that memory resident programs have been disabled. Defrag your hard drive as well so that audio files you are recording are continuous files on your drive.
Jul 16, 2008 | Creative Labs Sound Blaster Audigy 2 Value...
Dvd drive
You might try unistalling the drivers and reinstalling them from the device manager. However, this sounds like a harware issue, your DVD drive may be shot.
Jun 20, 2008 | HP Compaq Presario R4000 Notebook
DVD player sound
is the dvd a retail dvd, or a copied dvd? can you play music cd's ok? if the sound is stuttering, you may have too many other programs running. Check the systme tray amd close down all other apps and icons. most likely a problem with the laptop needing more memory to play the dvd. also try another dvd player like vlc or divx.com, or xvid.org for updated player codecs.
Aug 27, 2007 | Gateway MX3702 Notebook
Toshiba Satellite M105-S3021 Notebook Logo
135 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
