Question about Kodak EasyShare V1003 Digital Camera
Shattered lens? not sure, but looks like it
My kodak easyshare v1003 turns on ok...i used it this morning with no problems, but when i went to take pics of my sons birthday today, i turned it on and all i could see on the lcd screen was what looked like a piece of shattered glass, and nothing else, cannot review pics, so not sure if it is the lens or something else? can anyone advise? thanks
    Sergeant:
  • 367 Answers
Going to have to replace the camera. You can also try to turn it in to Kodak for repair but your easier route is to replace the camera.
Posted on Jan 20, 2009
I have a kodak easyshare V1003 .. my camera went dead with the lens out and when i got it charged the lens would not go down.. the camera does turn on and take pictures.. but the focus is blurry.. and it...
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Aug 26, 2010 | Kodak EasyShare V1003 Digital Camera
The lens of my kodak easyshare V1003 is not working when i turned it on....
Please clarify you issue. Does the lens stick? Does is refuse to retract? does it switch off?
If it switches off Try the following if any other listed faults a repair is needed:
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Use the camera w/o the memory card
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Aug 30, 2009 | Kodak EasyShare V1003 Digital Camera
Kodak Easy Share V1003 camera is frozen. Turned
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 17, 2009 | Kodak EasyShare One Digital Camera
Kodah EasyShare V1003 Digital Camera cannot turn off
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Kodak EasyShare V1003 Digital Camera
Kodak EasyShare lens makes clicking noises
try going into the menu 8 clicks down onto theaf control,and make sure its on single AF ,not continuous,as if its on continuous it will keep trying to stay in focus,if this dosent solv it its probabley a faulty lens
Jan 08, 2009 | Kodak EasyShare V1003 Digital Camera
LCD screen V-1003
It needs a new LCD screen and that would cost $85.00. TC
Nov 28, 2008 | Kodak EasyShare V1003 Digital Camera
White Sreen
unfortunately it would appear to be a CCD or main board failure.
If the camera is out of warranty (as this should be covered) my best suggestion is to pick up one off ebay with a broken screen and put your screen in it, broken screens are common on these cameras so they go quite cheaply, far cheaper than kodak would charge for repair and the swap is easy.
There are several searchs to try "parts v1003" "spares v1003" "Faulty v1003" "repair v1003"
Best of luck
May 26, 2008 | Kodak EasyShare C513 Digital Camera
Kodak V1003
goto http://www.digitalcamrepair.com/self_diagnosis_page.htm
for self diagnosis.please let me help you before leaving a bad feed back.
Mar 09, 2008 | Kodak EasyShare V1003 Digital Camera
Kodak EasyShare V1003 Digital Camera Logo
75 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
