Question about Oster Regency Controlled Power Kitchen Center Mixer Grinder Blender Salad Dough
How do I remove the motor from my Oster Regency kitchen center base to replace the drive gear?
There were 4 screws around the inside of the motor holding it into the case. I removed them and the motor appears to be looser, but it still won't come out.
  • 16 Answers
SOURCE: Hamilton Beach blender rubber drive removal
plz cont -23051554 \ 23095757
Posted on Aug 05, 2008
Loringh
  • 185 Answers
SOURCE: Oster 6700 Blender
The only thing I can think of is to try to repair the separated rubber with one of the special adhesives.
This may not be physically, ie, damaged beyond repair, but if you think it might be repairable try something like JB Weld. They make an adhesive that sets up in 4 minutes. I have fixed some weird breaks with this stuff.
Hope this might help Good Luck Loring
Posted on Oct 25, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Locking the jar on the base Oster Fusion 600W Blender
Here is the user manual for the Oster Fusion:
http://www.osterfusion.com/Manuals/MANUALS/BRLY07-Z00-000_43_29190737.PDF
It looks like you line up the threads, place the base on, and twist to tighten.
-Tha Mp3 Doctor
Posted on Mar 21, 2009
SOURCE: replacing rubber drive coupling
if you take the fan nut off, you will see the shaft has a flat. You can use a crescent wrench on that end (not too tight or you'll damage the threads) and a visegrip on the coupler in order to get it off.
Posted on May 22, 2009
  • 10 Answers
SOURCE: oster kitchen center 5500-08a
I have not seen this problem with ours yet but if turning up the speed doesn't help (first thought would be the motor's overloading because you're using hard foods in it on a low setting). If it shuts off even under light loads, judging by the manual it's something you need to send it in for. See if there's a service center in the area. These Kitchen Centers aren't made any more and it's unlikely you can fix it yourself.
Posted on May 04, 2011
I have osterizer food grinder( Detouchable) but machine was lost where can i find a replacement for the machine...
If you mean the one that attaches to a Kitchen Center, they are no longer available, eBay or garage sales are your only hope.
http://www.ebay.com/itm/OSTER-REGENCY-KITCHEN-CENTER-MEAT-GRINDER-ACCESSORY-/270805020990
Same with the free-standing models they had.
Sep 12, 2011 | Blenders
There is liquid leaking through the bearing on the base that adapts to the motor. Is there a service repair center in my area, my zip code is 60415?
Oster.com shows one Oster service center in Illinois:
(http://www.oster.com/ServiceCenters.aspx?state=Illinois)
Household Appliance Sales and Service 7034 North Milwaukee Avenue
Niles, Illinois
60714-3707
Phone: 847-647-8250
Fax: 847-647-2214
It's a roughly 45-minute drive from your zip code, according to Google Maps. You may want to call them with a description of your problem and see if they can service. There are also several locations in PA that will service Oster blenders.
Apr 30, 2011 | Oster 4093-8 Osterizer Classic Blender...
Replacing rubber drive coupling
My coupler was split in two, and I couldn't screw it off. I had to do the following:
1. Take the blender apart (mine had 2 screws on the bottom). 2. Remove the motor housing from the blender (mine was loose from removing the two screws earlier). 3. Remove the fan by removing the fan nut. 4. Take apart the motor housing. Mine had two machine screws with 1/4" hex heads holding a bracket that tied the two ends together. Once those two screws are removed, you can take the motor out of the housing. Be careful on the fan end of the motor, because it's got two spring loaded brushes that will come together once the motor is pulled through. 6. Once you have the motor out of the housing, you'll have something to grab onto so you'll be able to unscrew the broken coupler. I used a pair of channel locks and gently grasped the motor body, and then just used a regular pair of pliers to grab the broken coupler. It's regular thread (lefty lucy righty tighty), so twist accordingly.
Once you have the coupler off, just put everything back together. The hardest part is holding apart the spring loaded brushes while you push the fan end of the motor shaft back through the motor housing.
Took me about 20 minutes to do everything.
Good luck.
Nov 20, 2008 | Oster 4093-8 Osterizer Classic Blender...
Oster 6700 Blender
Oct 25, 2008 | Oster 6700 Work Top Blender
The blender coupling on my oster snapped in half. I have the replacement part already I just cannot figure out how to get the broken coupling off the base of the motor. I also got a replacement square...
10-01-2009 Sara - see solution for rlaymon 1-9-08 "Top part of base broke off" by TanyaCS on 1-20-08 - good ideas. I just fixed mine - 2 hour job + half hour to put a new cord in. Like TanyaCS my broken coupling was rusted to shaft - used WD-40 twice and let sit - meanwhile took out motor and removed fan - kept screws and washers in order on workbench (kitchen counter) - the fan hole is "D" shaped - fan end of shaft also "D" shaped - I filed a "flat" on the other side of the factory "flat" (side of 'D' that is straight) - Used big pliers on broken coupling and adjustable wrench on on the "flats" on fan end of the shaft. Broken end came right off. New cord is 18 gauge extension cord capable of at least 6 amps. Cut off the un-needed end. Or order a replacement cord $4 when you order the rubber drive coupling $4, pin with slinger washer $3. Bet you also need new rubber feet - didn't buy for mine - wish I had. Bert
Jul 11, 2008 | Oster 465 Work Top Blender
Replace oster kitchen center base drive part
I'am the guy who posted the comment I found out how to do this.
There are 2 possible solutions the 2nd is not pretty, hope the first works for you it didn't for me.
1- The motor must be lock up, by placing a thin screwdriver through the holes in the base into the fan down into the motor,holding the screwdriver, remove the square drive from the top.The part you are trying to remove actually is screwed into a gear in the gear box, you will need a spanner wrench,(sometimes a strong pair of long nose pliers will work, engage the spanner holes,hold the screwdriver ,and try to unsrew it, you may need someone to hold the screwdriver,because it takes a lot of force to loosen it.These are regular threads,and unscew counter clockwise.
2- if #1 doesn't work-this will- but its not so pretty.The motor assembly attached to the gear box will have to be removed,it will come out as one piece
Remove the bottom plate,unplug the white wire from the speed control,and the blue- white wire from the board,also you will have to remove one of the brushes with the white -blk lead.
Now you will have to actually break off of the top plastic(bakelite)by whatever means you dream up (I actually used a small wood chisel to score a line, and crack it) once its cracked, it breaks apart easily.Once thats done turn it over and remove the four screws holding the gear box to the housing you will now be able to remove the gear-box motor assembly.
Remove the 3 screws from the top of the gear box pry the box open,remove the gear with the piece that needs to be replaced,now you need to get the piece unscrewed from the gear.I did this by locking the nurled end into a vise, and very carefully grabing the gear teeth with large channel locks(if you think of a better way thats great)it work for me,but I was very concerned about the gear teeth,you can't slip.
Try the new piece to make sure it sets all the way down to the bottom of the gear(it must or your head will be to high ,and won't lock down)if all is well,make sure everything is greased,and start re-assembly, the new coupler ,and the square drive will be the last 2 pieces assembled from the top, once again locking the motor with a small screwdriver.
Feb 11, 2008 | Blenders
This just happened to me too, and I think I just fixed it.  First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99).  I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are.  Remove the rubber skirt to reveal four screws that hold the motor in.  They are way in there so you'll need a long screw driver.  Remove the motor and unscrew the old coupling.  Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck.  I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks.  If your blender is the same, remove the bottom nut, fan blade and two washers.  This gave enough of a rod to grip to get the old coupling off.  (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck!  Hope that helps!
Jan 09, 2008 | Oster 465 Work Top Blender
DeLonghi DBM8150 problem
These instructions disassemble an electrical appliance. You should have some technical/mechanical/electrical experience to attempt this and you do so at your own risk.
See exploded diagram : http://www.kenwoodservice.co.uk/uk-delonghi/exploded/exploded-KF8150M.pdf
This is not a very good diagram to show the disassembly, however, it will at least help me to identify the parts.
Prise out the center insert in the drive wheel (#15 on the diagram) on the top of the base unit (I used a paring knife and worked my way around the circumference to work it loose).
Remove the four rubber feet (#19) from the base by pulling them out.
Undo the 4 phillips head screws in the holes where the feet were.
Remove the base and carefully position it along-side the body of the blender.
Prise off the silver switch knob (#13) - it slides straight off the switch shaft and I used a screw driver to carefully lever it off, working from each side a little at a time.
Undo the drive wheel on the top of the drive shaft by holding the fan on the bottom of the drive shaft and turning the drive wheel CLOCKWISE.
Undo and remove the two screws holding the switch support (#11) and cut the tie wrap that secures the blue cable to this support.
Undo the four screws that secure the motor assembly to the casing and remove the screws and their shake-proof washers.
Remove the internal components as a single assembly. Tilt/angle the motor assembly towards the switch support until the top of the shaft clears the rubber boot in the top and then the whole lot comes out easily.
To replace the switch (Part No. HS1144 - #10 on the diagram):
Carefully lever the white gear wheel off the switch shaft.
Undo the two small screws that hold the dial gear wheel cover in place on the switch support.
Remove the cover and the small gear wheel (noting which way around the gear wheel goes the two ends of the shaft are slightly different).
Undo the nut on the switch shaft that that secures the switch to the support (nut is 14mm diameter and needs a thin wall socket. I used long nose pliers to remove and re-install it).
The wires connect by simple push fit into their slots and the angled brass blades inside the slots grab the wire and lock it in place. To withdraw each wire, use a very thin screw driver (or similar) to depress the brass blades inside the slot. This enables the wire to be withdrawn as you depress the blade.
Re-assembly is the opposite sequence.
When putting the dial back together, remember to check that the dial reading lines up with the switch position (adjust the gears by resetting the teeth if the alignment is not correct.
Here’s the really interesting thing. After I replaced the switch, I pulled the old one apart. IT HAD FAILED BECAUSE THE CONTACTS HAD BURNT OUT. They had obviously been arcing and had completely burnt through. There were burnt off tails of the contacts lying in the switch housing and there was evidence of burning (carbon deposits) inside the switch. In short – the switch is not up to the job and will fail. Poor design and a latent defect.
Aug 17, 2007 | DeLonghi DBM8150 Work Top Blender
Oster Regency Controlled Power Kitchen Center Mixer Grinder Blender Salad Dough Logo
160 people viewed this question
Top Oster Blenders Experts
Dan Webster
Dan Webster
Dave
Dave
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Oster Blender Expert? Answer questions, earn points and help others
