Question about Kenmore 44102 Front Load Washer
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
I get brown spots on white shirts after washing
  • 1 more comment
  • hkegan Feb 09, 2009
    I have exactly the same problem. Our washer is 5 years old, the same model.
    The wash came out suddenly with rusty stain a few days ago, and I have no clue what is causing this.
    Does anybody have any idea why this happens?
  • skoorbyad Feb 18, 2009
    My washer is about 9 years old and I have the same problem. It just started a few weeks ago. I have brown streaks and dots on my whites that will not come out. I have been told to buy AFRESH (homedepot has it) and run a few cycles with that. I usually only use cold water so I was told that with not using hot water and bleach that mold and other gunck build up happenes. So run it a few times on hot with bleach and also try the afresh. So much for having any clean whites for while until I can get the washer cleaned out. UGH!
  • 2hopeless Apr 25, 2009
    My problem may be somewhat related. Some substance gets on my t-shirts and looks like very faint spots.
    After been washed with detergent (Tide), the spot turns a much darker brown an it is impossible to remove!
    I originally blamed my front loading washer, but I was able to replicate the problem by just soaking the shirt in detergent.
    Any ideas?
  • 188 Answers
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Posted on Feb 19, 2009
I had the same problem - white clothes (the only ones washed with hot water and bleach) stained with brown streaks, and mildew build-up on gasket. I used Affresh (both the tablet and the wiping cloth) then tried another white load and had the same problem, this time with stains also appearing in brown spots the same size and pattern as the drum. I used Affresh a second time then ran a couple of subsquent tests with a white rag and everything seems fine now.
Posted on Mar 15, 2009
  • petebran Jul 01, 2009
    Update: the Affresh solution did not work. When I next did a heavy load of whites the problem re-appeared. I then ran numerous tests on different cycles, different water temperatures, with and without detergent and fabric softener and discovered the one constant factor: the problem only happen on the Whites cycle (regardless of water temperature and use of detergent/softener). This makes sense because the very high speed spin in this cycle literally sucks (heavy loads of) clothes slightly into the holes in the drum and this is exactly where the stains appear.
    I have therefore creted my own post to ask if there are any solutions short of taking the entire machine apart and cleaning the outside of the drum.
I have been having the same issue and the washer has been very loud during the spin cycle...it is definitely the bearing but boy are they expensive! Costing me $230 to fix, but they machine is still in great shape.
Posted on Jun 02, 2009
  • 4 Answers
Check the dryer for the seal in front of unit. a bad seal could be causing your clothe to come out with stains in white. so determine if its coming from the washer or dryer because a lot of the times the seals on the 417 dryers will stain whites. the seal is located inside of the drum between front panel and drum glides. stick your head inside of drum and look to see if the seal is good or not. hope this helps.
Posted on Apr 12, 2009
    New Friend:
Had the same problem with maytag maxima. After running one affresh cycle, we could piles of brown flaky slimy bits in the tub. Figured it was the enzymes of the dish washing powder(cheaper than affresh tabs) breaking down the waxy build up of cheap (everyone in the house buys their own) fabric softer in the tub lining. Ran the same cycle with a cup of powder each 4 more times before the flecks went away. Going to do the dish washing powder trick each week from now on.
Posted on Feb 19, 2013
I have the same problem with my brand new front load.I am starting to wonder if it is the water? It's not yellowing like rust it is brown spots.
Posted on Nov 22, 2009
Kenmoore 600 washing machine. Clothes comes out with brown spots.
Are you on a well, or town water supply? If machine needs cleaning you could try running a load with just water and a bottle of CLR it is a cleaner for calcium, lime and rust I think, if it smells after that of the cleaner run a load with white vinegar in it with the water. hope it helps, good luck
Jul 03, 2017 | Washing Machines
Brown streaks on white cloths?
Hi Ralph,
It may be important to have an idea as to what caused the stain/discoloration. Carbona (http://www.carbona.com/home.php) has different products specific to the various reasons for the problem. You may be able to use bleach, depending on the fabric affected. Some white material turn yellow with bleach
Hope this helps ~ Good luck!
Alexander
Mar 02, 2015 | Kenmore 45081 Front Load Washer / Dryer
Sometimes I get little brown spots on my wash, like on a tee shirt or shirt. The spot will not come out on a rewash.
the main cause of this problem is a rusty object inside the machine,ie a small screw/paperclip/nail something that has come out of a pocket and is lying in the nachine,adrian,,,,,,
Aug 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
White shirts have grayish stains
try soaking the shirt with ritz's white dye.
Sep 13, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Brown stains on white clothes in front loading washer
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I get grey stain/spots on my white cloths
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Jun 09, 2009 | Kenmore HE2 Plus Front Load Washer
Grey Stains on my whites
Need ot check the main seal and the main bearing. You can do this by accessing the rear of the unit.
Feb 13, 2009 | EuroTech EWC177 Front Load Washer / Dryer
Kenmore fornt load washer
Jan 18, 2009 | Kenmore 46462 Front Load Washer
Kenmore 44102 Front Load Washer Logo
4,497 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
