Question about Husqvarna Sewing Machines
How to lubricate a huskylock 340Dserger
Need diagram of were to oil the 340d husky lock serger
SOURCE: threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Posted on Oct 20, 2008
  • 46 Answers
SOURCE: I was given a Huskylock 430 serger and need to
There are really not any #s you can set to give a good stitch. You have to just use the #s as a guide. Most sergers from the factory will give you something decent around 4 across the board. Start there and make slight adjustments as needed. It also depends on the stitch and type of material used.
Posted on Aug 17, 2009
Zenqi
  • 208 Answers
SOURCE: I need a threading diagram for a Viking Huskylock 560ED serger
Call Husqvarna Viking at 440-808-6550 and they will email you a PDF of the manual.
Posted on Oct 01, 2009
  • 371 Answers
SOURCE: I have a huskylock 1002lcd serger. The cutting
See an authorized husqvarna viking dealer for parts (and service). It's possible you might find the part at third party vendors on line but your best bet is with an authorized HV dealer. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 14, 2010
  • 371 Answers
SOURCE: Need to find compatible presser feet for Huskylock 700
Not really sure but would suggest contacting an authorized husqvarna viking dealer. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Viking Huskylock 560 ED threading diagram
Viking 560 ED Huskylock Handbook
Threading Serger this may be helpful even if it is not the same model. The sequence of threading loopers is VERY important. If you thread them out of order, be prepared to be frustrated beyond belief!!! Something else (I don't think she mentioned) is to ALWAYS RAISE the presser foot when threading your machine. This is true for sergers AND sewing machines!
How to thread Serger
Nov 17, 2016 | Sewing Machines
Huskylock 910 stuck
since it's a husky lock, it would be a good idea to have the machine serviced
& make sure you have the manual to read so you can get use to the machine
Jun 11, 2012 | Husqvarna Huskylock Computerized 910
Threading a huskylock 234d serger
I have seen some models with a diagram for threading. Look inside the cover, in front of the machine.
Jun 01, 2010 | Sewing Machines
Sep 30, 2009 | Sewing Machines
Need Huskylock 535D all purpose need plate
The parts catalogs show this part as obsolete.
Try Googling the top Husqvarna Viking dealers to find one with spare parts from junker machines. Most dealers have a good supply of used plates.
Jul 23, 2009 | Husqvarna Husky 165
My husqvarna 905 serger is making a noise and starts running in slow motion. If it needs to be oiled the instruction booklet lacks that info
Lubrication points are in section 3-12 on page 34 of my manual. Look for Lubrication in the index if you don't find it there.
The 905 should be lightly lubricated each time it is used or after about 6 hours of operation. I recommend removing all lint and lubricating when you are finished working for the day so it will be ready to go when you need it next.
It should also be serviced regularly, depending on how much use it gets. If it is furry around the edges, find a certified repair center that you can trust. Ask around at any sewing get-together and you will be able to determine a reliable technician to take it to.
Jun 12, 2009 | Husqvarna Huskylock Computerized 905
Good luck.
Dec 27, 2008 | Husqvarna Huskylock Computerized 905
Sewing Machines Logo
26 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
