Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer model MDG5500AWQ
Light stay on wity message 8.8. but don't do anything before it was resolving with keep dryer time low or high and fix the time some time work but since couple days no respond. just 8.8. stay on none of keys working. Can you tell me is still under warranty or not. My address is 44660 Fenwick dr, Canton MI.48188 Pls help us with the warranty ans. and tip for troubleshooting.
  • 1 more comment
  • Kev T Feb 21, 2009
    Our dryer is doing the same thing.
    K T Fowler
    Horseshoe Bend, ID
  • Anonymous Feb 21, 2009
    beep beeep beep does nothing
  • mkb06 Feb 22, 2009
    8.8
  • 262 Answers
SOURCE: Maytag Neptune Dryer
is the drum light on while the door is closed?? look on the teck sheet found in the lower front panel for a wiring diagram momery servers me there is a thermal fuse chances are this is bad if you cant find this tech sheet I will look in my invoice book and see if I can find the sheet for it good luck let me know what you find out
Posted on Jan 17, 2008
kevin000
  • 1847 Answers
SOURCE: Maytag dryer [electric] MED9600 lights up but won't start
The control panel seem to have the problem.
Posted on Jul 14, 2008
  • 1214 Answers
SOURCE: Bravos Dryer blinking start button
Manual says it could be a number of things, and you should have a copy of the manual since you've only had the dryer 3-4 months. If not, go to the Maytag website and download.
Some things to check -
1) Press Start/Cancel if dryer was stopped in a middle of the operating cycle.
2) Check that one of the two breakers has not tripped or fuses blown (if an electric dryer) in your breaker panel.
Please reply the flashing code number so that I may can help you further.
Posted on Jan 19, 2009
SOURCE: Maytag Electric Dryer - Control panel doesn't light unless door is open
I fixed my own problem...I took the extra 4th wire(green) and attached it to the dryer body...There is a screw with the word ground stamped into the metal above it. This is right next to the panal where the cord goes into. I just unscrewed it and put my cable there and the dryer works perfect.....These things need to have a detailed diagram on the dryer....
Posted on Feb 15, 2009
  • 686 Answers
SOURCE: disable buzzer on Maytag Atlantis MDE6200AYW
it could be done by taking the control panel off and maybe diconnecting the buzzer other than that what I have researched there is no other way sorry
Posted on Feb 18, 2009
Maytag gas dryer LDG7500AAL flame won't stay on longer than about 5 seconds.
The resistance is too weak in the hot surface ignitor to keep the gas valve open and requires replacement.
Dec 22, 2013 | Dryers
No dryer heat
If the coils are bad the unit will light with flame for 4 - 8 times then all of a sudden the ignitor will glow, kick off with no gas coming threw valve. it sounds like the high limit thermostat is short cycling the flame. This is the thermostat that sits on top of the burner chamber. remove 1 screw from the thermostat and blend it upwards away from the heat. Then plug unit back in and test to see if the flame stays on longer. Click here to see maytag dryer no heat posts. Contact me anytime here. Hope this helps..
May 20, 2013 | Maytag Neptune MDG6700A Gas Dryer
My maytag neptune MDG5500AWQ will heat only on the wrinkle release button. How do I get the front off to clean out the lint. Can't get it with the vacuum. please advise
http://www.ehow.com/how_5700381_apart-maytag-neptune-dryer.html
Here is a good link that will tell you what you need to know. I purchased and inexpensive kit from lowes that has vacuum attachments that will reach into very small cracks and crevices. It has been a very helpful item to have.
Make sure to check the vent on the outside, and the ducting that runs through the wall.
Be very careful, some of the places are very sharp, might be wise to wear some gloves, and be mindful of any wiring you could run into.
Hope that helps,
Mike
Jul 20, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My Neptue dryer wont dry unless I run it more than one cycle. model no. mdg5500awq. all lights work and seems to run fine it just wont dry the cloths unless I run it at least twice and jeans are three or...
Turn dryer on and go outside to the vent and check for a good amount of air coming out. If you do not have a good amount of air coming out, take the exhaust tubes apart and clean.
Jun 07, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Dryer is hooked up but it will not turn on; no lights, no beeps our Maytag Neptune is model number MDG5500AWQ please help
more then likely it is the thermal fuse:
here is a new one, may be cheaper on eBay or faster to get from a repair/service shop:
http://www.repairclinic.com/PartDetail/Thermal-Fuse/2986
here is the location, it is on the bottom of this page, Good Luck Tim:
http://www.applianceaid.com/gas_dryer.html#noheat
As a test you can tape the two wires together, make sure power is off and do not run dryer like this as it will cause a fire.
Dec 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The dryer heats up but turns the heat and timing
usually the coils on the gas valve are going out
Oct 24, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Neptune won't dry clothes -
I would replace the solenoids. The gas valve is not fully opening. The glow bar may be failing but the coils on the valve are in need of replacing..
Eric
Sep 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
50 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
