Question about Nintendo Professor Layton & the Curious Village Games for DS
Xxxxxxxxx - Nintendo Professor Layton & the Curious Village Games for DS
  • 50 Answers
Dat dosent make sense
Posted on Feb 20, 2009
Lg 32lc7d hdmi no signal
Try another HDMI source (borrow a friend's BluRay for example} to confirm it is the TV at fault. If it still doesn't work, the TV needs a main board replacement because all the HDMI circuitry is on the main board. this usually happens after a power surge or lightning storm, and a near hit is all it takes, Sometimes, if you have a Satellite Receiver it too might be damaged on its HDMI output. So 1st try another source..IF you replace it yourself be sure to find the right board by using the TV's service # example 32LC7D-XX.XXXXXXX.. The letters where I have Xs are very important and must be matched,
Mar 30, 2014 | LG 32LC7D Television
When I receive text messages, only the number shows up, not the name of the sender
HelloThis kind of problem normally comes in non branded/china mobiles, the only remedy is, put the contact number with full country and area code like +XX-xxx-xxxxxxx, then it will give you the name with contact number.
Hope it helps, good luck
Dec 11, 2010 | Cell Phones
How can i open my email address?
which provider u have.
i.e yahoo, hotmail, gmail????
for yahoo goto mail.yahoo.com and enter your id and password
for hotmail goto hotmail.com and enter xxxxxxx@live.com and password(xxxxxxx means your id)
for gmail goto gmail.com and enter your id and pass
Aug 16, 2010 | Computers & Internet
What is the format for the Keurig coffee serial number.. I have the numbers, but apparently not the appropriate format and don't have the brewer with me
I had the same problem. I tried the following format and it finally worked:
xx.xxxx.xxxxxxx
Apparently you need to put the decimals in. Good luck.
Mar 02, 2010 | Keurig Coffee Makers & Espresso Machines
I decided to switch to ubuntu 9.04 os but i have problem with dial-up connection using Dlink 562is modem.
1. Install hsfmodem_7.60.00.09full_i386.deb from terminal
* type sudo dpkg -i *.deb
* Where is the linux source build directory that matches your running kernel?
* [/lib/modules/2.6.20-15-generic/build] press Enter
* Please enter region name for modem unit 0 [XXX] : type country name then press enter
* Please enter your email address [unknown] : type your email address then press enter
* Recorded The registration ID for modem unit 0 is: XXXX-XXXX-XXXX
* Please enter license key [FREE] :
2. Open new terminal, type ./genertor.pl [email address] [Registration ID]
3. get key: XX-XX-XX-XX-XX-XX
4. enter the key on Please enter license key [FREE] :
5. Copy hsfpatch to /usr/lib/hsfmodem :
* $ sudo cp hsfpatch /usr/lib/hsfmodem/
6. Execute patch file : $ sudo ./hsfpatch
* file 'modules/imported/hsfengine-i386.O' openend
* patching... done
7. Reconfigere hsfmodem : type sudo hsfconfig
* Press ENTER for all the questions
* Would you like to keep using them? [no]
* Please enter region name for modem unit 0 [XXX]:
* Please enter your email address [XXX@XXX.com]:Please enter
* license key [XX-XX-XX-XX-XX-XX]:
8. Reconfigure hsfmodem complete :
* Config for modem unit 0: /dev/ttySHSF0
* Device instance: 0-PCI-14f1:2f30-14f1:20d5
* HW revision : Basic2 2.18 Standard DAA 3VoltsIA
* HW profile name: hsfpcibasic2hsfi
* Registration ID: XXXX-XXXX-XXXX
* License owner : XXX@XXX.com
* License key : XX-XX-XX-XX-XX-XX
* License status : OK
* Current region : XXX (T.35 code: 0054)
* The /dev/modem alias (symlink) points to ttySHSF0
9. Install KPPP
10. Browse The World
Jun 17, 2009 | D-Link DFM 562IS (DFM-562IS) Modem
Keep receiving "End of Forms or Forms Jam on device XXXXXXX"
The problem was due to a block/clogged EOF(End of Forms) sensor. I resolved it by using a can of compressed air to clean/remove any foreign debris from the sensor.
Apr 08, 2009 | IBM 6400 Matrix Printer
Trying to remove a ip route on the 5871.
normally on router commands, in order to delete something you do not write del, but instead write out the command you would type to add the route with the word no in front of the line.
so if the command to add was eth ip addroute xx.xx.xx.xx xxx.xxx.xxx.xxx xxx.xx.xx.xx 1
the command to take it off would be, no eth ip delroute xx.xx.xx.xx xxx.xxx.xxx.xxx xxx.xx.xx.xx 1
May 09, 2008 | Efficient Networks SpeedStream 5871 Router
About paypal
Hi buddy,
In your PayPal's "My Account Overview", it would show as:
Xxxxxxx Xxxx (xxxxxxx@yahoo.com), that would be your PayPal account name and thats what I placed in FixYa.
You be good.
Apr 03, 2008 | Blenders
CODE REGION
Turn the player on and open the disc tray. Press [CLEAR] followed by [1][3][6][9] and one of the keys [0]...[8] corresponding to the region you want to set the player for (1 for Region 1, 2 for Region 2 and so on, press 0 for Region 0 or Region Free). Turn the player off then on again for the changes to take effect.
To verify the region code, press [SETUP] followed by [1][3][7][9]. A screen will then pop up with the firmware info and the current region code setting. Using [SETUP][1][3][6][9] did not work for me.
Or
To modify the region, turn on the unit and open the disk tray. Using the remote, press [CLEAR][1][3][6][9][zone code] and cycle power on the unit (not necessary to unplug the unit, simply use the front left <POWER> button. Example: Turn on; open tray; [CLEAR] [1][3][6][9][0]; unit OFF, unit ON and you'll get a zone free DVD player.
To confirm the zone code, turn on DVD player, (unit may or may not have a disc, check that the disc tray is closed, and press [SETUP][1][3][7][9]. You'll have all the firmware information (Version xx.xx.xx.xx SUB-VER xx.xx.xx.xx;
8032 xx.xx.xx.xx; Servo xx.xx.xx.xx; RISC xx.xx.xx.xx; DSP xx.xx.xx.xx; Region Code 0) That's that final "0" that you are looking for!
Mar 17, 2008 | RCA DRC247N DVD Player
Nintendo Professor Layton & the Curious Village Games for DS Logo
77 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
