Question about Sharp EL-1197PIII Calculator
How do you print date and time with EL-1197PIII
RonPark
  • 855 Answers
SOURCE: Replacement paper roll size???
Your calculater takes 2 1/4 inch wide standard rolls of paper. These rolls are available all over the place so you should have no trouble finding the rolls.
Posted on Sep 26, 2009
  • 5603 Answers
SOURCE: Hi I have a EL-1197PIII. I have moved it from my
The "E" is an error indication. If you divide a number by zero that would cause it. But a reset should clear it. Also dead backup battery will cause it.
FIRST replace the backup battery in the unit. There is a small panel on the bottom to access it.
Then do the reset. There is a "poke hole" to reset it that should be marked. Refer to your manual which is also available for free download online.
Posted on Nov 05, 2009
SOURCE: What ink roller should i get for the Sharp
check with staples.
Posted on Jun 18, 2010
SOURCE: How do I set the
Click on the link below to download the Sharp EL-1197P III owners guide:
http://www.scribd.com/doc/30938397/Sharp-Calculator-EL1197PIII-User-Guide
Posted on Aug 26, 2010
  • 102366 Answers
SOURCE: I need an owners manual
You can download the manual from the manufacturer's web site at
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/Calculators/Manuals/cal_man_EL1197PIII.pdf
Posted on Aug 11, 2011
How do I set date and time
To set the date, make sure that you are in Rate Set. type in the date such as August 3, 2010 would be entered as 08.03.2010 then press the date time key. This will set the date. To set the time type in the time such as 4:20 PM would be entered as 16.20 then press the date time key and this will set the time.
Apr 16, 2015 | Sharp EL-1197PIII Calculator
Sharp EL-1197PIII Calculator won't print using the blank ink. Ribbon is correctly installed.
I still have to believe that your ribbon is not quite seated properly on this. I would check that again. If this is not a "cartridge" then Check to see if it is upside down.
Jan 15, 2015 | Sharp EL-1197PIII Calculator 12-Digit...
HOW DO I CHANGE THE DATE AND TIME?
Only the EL-1197PIII has time and date settings, so I assume you own this model. A link to the manual is here: http://www.sharpusa.com/~/media/96B576A9DADF49A0B1321B57CAB1741D.ashx
You can find the time and date set up process on the first page, 3rd column, 2nd paragraph, under the headline GRAND TOTAL/RATE SETTING MODE SELECTOR.
Feb 11, 2010 | Sharp EL-1197P Calculator
Setting the time and date
Feb 02, 2010 | Sharp EL-1197PIII Calculator
How do you fix -E appears when printing option is used?
You may have a defective printer. It has be overhauled, clean and re-timing on the gears
Sep 10, 2009 | Sharp EL-1197PIII Calculator
Setting correct date
You may download a copy of the manual here. The clock setting instructions are in the middle of the first page.
Sep 02, 2009 | Sharp EL-1197PIII Calculator
Need to change the time on calculator
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position.
Date:
Enter in the order of month, day and year, then press date/time button
to complete the entry.
Use ▪ to separate month, day, and year EXAMPLE 3▪13▪2009.
When (date/time) button is pressed, the number entered is evaluated
and displayed as “date”
Time:
Enter in the order of hour, minutes, then press date/time button to
complete the entry.
(There is no entry available for the seconds value. The
clock starts at zero second.)
Use to separate hour and minute values EXAMPLE 8▪15
When is date/time button is pressed, the number entered is evaluated
and displayed as “time
When settings are complete place the switch back to GT
Mar 11, 2009 | Sharp EL-1197PIII Calculator
Sharp EL-1197PIII Calculator Logo
81 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
