Question about Thermador C301U Electric Single Oven
Thermador oven (c301u) door hinges weak, how to install new hinge
Door light comes on. THe hinges appear to have weakened. Need to know how to replace the hinges. What is involved?
  • 2 more comments
  • dmil945 Jan 25, 2009
    I have the same problem. I've had the both Door Hinges and Door Stops replaced. The authorized serviceman is baffled. The problem progressively gets worse again as you use the oven. To keep the light off I have to push a chair against the oven.
    Thermador was totally rude about this situation and offered no support except to pay for another authorized service visit.
  • wwright001 Mar 12, 2009
    I have a C301 BS/03 wall oven and have the same problem with the hinges.  Door will not close tight...light pops on because door is basically open, and can not keep even temp. because heat is escaping.  Just called for service...parts $178.00, labor $193.29.  This is ridiculous!  If hinges are weak, how long before I have to put out another $371.29 to replace them again.  Can not find any info. on how to replace them.  I guess it is a big secret so that you have to go through Thermador and use an authorized service rep.  Anyone with do-it-yourself information on replacing the hinges, please let me know.
  • Anonymous Mar 17, 2009
    same thing door is open, light on, until a chair is placed against the door.
  • volkers Mar 29, 2009
    I have the same issue, and the oven is only 14 months old.
    The service folks charged me approx $300 ( " Sorry, you are out of warranty " ) to replace the hinges , but two days later the oven light stays on unless you push hard on the door.
    Previously, this gradually worsened until the light only went off when the oven was cold.
This is a relatively easy fix however you will need to remove the door and it is heavy!
Start by opening the door completely and engage the small "locks" that are at the base of the hinge. This will ensure that the spring loaded hinges do not "spring open" when you remove the door. You then will need to remove the hinges from the door via a series of phillips head screws that hold the hinge assembly in place. The new hinges must be "preloaded" into the Open position using a vise or some means of holding the hinge in place while you use a small section of pipe to provide leverage needed to open the hinge so that the Locks can be engaged.
Once the new hinges are "pre-loaded" and the locks are engaged, you can reverse the procedure to re-install the hinges into the door and re-install the door.
Good luck!!
The hinges are commercially avaialble from Applianceparts.com
Posted on Oct 13, 2009
  • foxvalleypro Dec 19, 2010
    There is no way to pre-load a closed-spring system. There are no adjustment points, no shims and no other means to adjust the fairly hi-powered spring in these Thermador oven hinges. You are better off buying the replacement hinge assemblies online and replacing them yourself. As of December 2010, I've seen them online for about $25 each. A DIY person can manage the replacement.
  • BOB BENNETT Oct 23, 2011
    I have a C301US wall oven. In order to remove the hinges I had to unload (disengage the brass clip) the old ones in order to remove them. On the re-install, I had to put them in untensioned. I used the end of an aluminum lacrosse stick as a lever to move the hinge arm into position so that I could snap in the brass clips prior to putting it back on the oven.
SOURCE:
Remove oven door from hinges
the door is removed with the hinges in place. with the door open, lock the hinge sections together with the little clips on lowest hinge section. When locked, lift up on the door (not the handle) sides, swinging it up until it can be pulled out. Install in reverse order.
Feb 17, 2014 | Thermador Ovens
Fisher and paykel oven door wont close, there is a gap at the top of the door. The seal seems to be intact. The door feels loose to the touch.
you need to either replace - or get the door hinges replaced, the spring in the hinges has weakened over time, if it is still in warranty, then they should replace them for free, if not, then take the model number to your local f&P dealer and buy new hinges. Remove the door and dismantle the door to gain access to the hinges, undo the 2 screws holding each hinge in place, clean the inside of the glas while apart, reassemble in reverse order.
May 17, 2011 | Fisher and Paykel OS302SS, Stainless Steel...
I have a Thermador smw272 oven that the lower oven door will not close all the way and the light stays on. I have replaced the hinges and roller assemblies three times and I still have the same problem. I...
is the door switch bad?when you open the door all the way if it is at a 90 degree angle the hinges are good also i just looked your model number up and it says the hinges are no longer available part 14-38-045-01
Nov 14, 2017 | Thermador SMW272 Electric Double Oven
I have the SC272TB Double Oven. The top oven is fine but the lower one will not stay closed. Whether baking or not, the door seems to pop open just enough to turn the light on. We walk by and press the...
Welcome to FixYa.
Yes this has been a fairly common issue with the Thermador wall ovens as well as their freestanding ranges.
Typically the remedy will be replacing the hinges, but there is a "fix" you can attempt in the interim. At least in hope of keeping the oven light from being on all the time, hence damaging the control board which houses the oven lights transformer.
The issue with those Thermador wall oven and freestanding range doors ( especially on the freestanding "professional" line ) is the weight of the door is so great, the hinge will actually move slightly over time, other times the entire hinge will need to be replaced.
This is what I'd recommend ( also official Thermador remedy, rest assured as I am a authorized factory trained Thermador service provider ) before pronouncing the hinges need replacing though.
**This does require a somewhat involved repair, so if you don't feel completely comfortable or have any reservation to trying this, please call in an local authorized Thermador ( B/S/H/ ) service provider.**
Recommendation: Adjust the door box hinge per instructions below.
1. Pull the oven away from the wall about 12".
2. Remove the hinge box cover plates.
3. Remove the vertical side trim piece. It covers one of the screws that must be loosened.
4. Loosen the 4 screws that secure the hinge box.
5. Place a rolled up dishtowel at the bottom of the door and close the door and apply light pressure to the door while re-tightening the four screws.
See fig below
6. Re-install the hinge box covers & side trims.
7. Re-install and secure the oven.
That should do it, ( or as stated, improve the situation ) if the hinges are too far gone they will need to be replaced unfortunately.
Let me know if you require further assistance or if indeed this solved your problem.
Thank you for choosing FixYa today and good luck going forward.
Regards,
Macmarkus :)
Jan 26, 2011 | Thermador C302U Electric Double Oven
Is there any way to tighten this door up ,the one i have comes down just a little and the light comes on
Hello, Welcome to FixYa. Yes this has been a fairly common issue with the Thermador wall ovens as well as their freestanding ranges. Typically the remedy will be replacing the hinges, but there is a "fix" you can attempt in the interim. At least in hope of keeping the oven light from being on all the time, hence damaging the control board which houses the oven lights transformer.
See fig below
Regards,
Macmarkus :)
Jan 06, 2011 | Thermador SEC271BS Stainless Steel Single...
Oven takes forever to heat up - its a thermador double oven - me272
Hello- Check these things first-  Door seals tend to get stiff over time. This is normal. Door hinges can become loose or get bent a bit, causing door to not close tight. This little gap can allow heat to escape, causing extended pre-heat times and frequent cycling of elements. If door doesn't seem to pull shut tightly- hinges will need to be replaced. If oven appears to operate normally otherwise, this should solve problem.  Let me know if the info helps- have more if needed- Thanks  - Ed
Mar 17, 2010 | Thermador C272 Electric Double Oven
Removing the door from a thermador oven CT130
Usually you will find a hole in each hinge to hold the hinge open when removing the door.
It is impossible to fight the door hinge springs and remove or install the door.
One opens the door and puts a nail through the hole to keep the hinge open for each hinge.
Feb 20, 2010 | Thermador Ovens
The oven door (Model SMW272) does not close completely. It may need an adjustment or a new seal?
Generally speaking, if a oven door does not close properly, and it is a drop down door, then it usually due to weak springs in the hinges.
There is no adjustment provided, so the only solutiom is to replace both door hinges.
Please rate my nsolution.
Thankyou.
Jan 28, 2010 | Thermador SMW272 Electric Double Oven
Thermador oven door won't close all the way - seems like the seal is holding it open. I can press and hold it closed, but if I release, it pops out. The oven light stays on all the time. Model smw272
Have exactly the same situation. All the solutions I have seen talk about replacing the hinges or seal. But people report the same thing happens a month later. Looking hard at the door what it needs is something to pull it right at the top. So I installed a rare earth magnet from www.kjmagnetics.com I used part number BX884DCS which costs $4. It mounts with a couple of screws and I put it on the door a couple of inches down from the top.
Its possible that heat from the oven will kill the magnet over time but for $4 I can replace it for a lot less than hinges and it works great. The door closes more securely than it ever did when the oven was new.
Hope this helps.
Aug 05, 2009 | Thermador SMW272 Electric Double Oven
The upper oven door dosen't shut tight.
Door not closing properly is normally due to weak door hinges.
Normal procedure is to replace both the hinges.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Thermador SC302T Electric Double Oven
Thermador C301U Electric Single Oven Logo
5,920 people viewed this question
Top Thermador Ovens Experts
Marvin
Marvin
Steve Allison
Steve Allison
Are you a Thermador Oven Expert? Answer questions, earn points and help others
