Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Wiring from thermostat to furnace
I HAVE A COLEMAN EVCON MODEL AGU10016A NOT SURE HOW OLD IT IS BUT I NEED TO KNOW HOW OR WHAT WIRES NEED TO BE HOOKED UP FROM THE THERMOSTAT TO THE FURNACE TO MAKE IT RUN PROPERLY I HAVE TRIED AND CANNOY FIGURE IT OUT.....
    Problem Solver:
  • 8 Answers
Typically you normally will have five wires controlling your furnace and airconditioning. R Y W G C. If you get some thermostat wire. Connect them like this---- red wire will go to R(this is your 24V to thermostat)----yellow wire will go Y(Y is your cooling)----white wire will go W(W is for heating)---green wire to G(green is your fan)---black can go to C(this is your common to supply 24Vto thermostat)
Posted on Jan 19, 2009
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
I upgraded my thermostat to a digital one. when i removedd the old one only the red and white wires were used. i also replaced the thermostat wires. i hooked up all the wires according to color red to r,...
As your unit had just 2 wires, Red and White, you had just heat only with no AC and no fan on as described as you have no green circuit wired up at the furnace or thermostat, you can add a relay if not equipped but that would make your unit very old.
Oct 19, 2013 | Heating & Cooling
Coleman evcon furnace
Sounds like it isn't getting a call for heat. If you have a digital thermostat it could be the problem. I have seen them look like they are working but burn out. A simple way to check is take the stat off the wall. There is 2 wires. It's low voltage so don't worry about shock. Touch and hold them together. If it fires up change the t stat. On a . 2 wire it makes no difference which goes to W or R
Oct 16, 2013 | Heating & Cooling
How do you replace a pressure switch on a coleman evcon furnace
The pressure switch is mounted with 1/4" or 5/16" self tapping screws and has 2 wires and a rubber tube that attaches to the induced drafts assembly.
Jan 25, 2013 | Coleman 7990-319p Evcon Gas Furnace...
I have a coleman evcon model eb15a furnace. it does not work with the therostat, if you turn the main breakers on the fan and one elament come on the fan auto/continuious run switch doest work either any...
Hello, have you tried jumping the R and W wires on the thermostat sub base? If this turns on you furnace than the thermostat is bad, however if there is no display on the thermostat and does not power up by jumping the R and W Wires then most likely the transformer is bad and must be replaced.
Mar 16, 2011 | Coleman Heating & Cooling
I have a coleman Evcon model AH16-0 . I am
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Jan 06, 2010 | Heating & Cooling
I have a coleman evcon gas furnace I want to change the termostat to a programmable thermostat I don't know where the wires hookup we have four wires red,white,yellow,green. I have a honeywell RTH230b...
The thermostat has terminals which are marked for color, R = red, W = white, Y =yellow, G =green. There should be a jumper between Rh and Rc, Hook the red to Rh.
Jan 01, 2010 | Coleman Propane Forced Air Heater...
Furnace blower not working how it should
first off buy yourself a honeywell stat, in my personal opinion lux stats are garbage, I have run into so many that are bad stats !!! but as far as your fan not shuting down, sounds to me like your fan center on your circuit board is bad and will not shut down the fan when needed, you will have to replace the circuit board, as the fan center is a part of the whole of the circuit board, hope that helps
Jan 19, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
694 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
