Question about Cuisinart Grilling
How do I calibrate a cuisinart meat thermometer?
Meat thermometer
CRTN
  • 716 Answers
SOURCE: problem with temperature in the meat drawer
You Need To Have The Fan Checked.
Posted on Jan 05, 2009
SOURCE: BBQ will not heat up to cook meat
you had the burners on before you opened the valve on the propane tank.
this causes the safety in the pressure regulator to cut off most of flow, and the highest temp you'll get will be about 200 degrees.
turn off the burners and the tank, then disconnect the tank and let site for a few minutes. reconnect everything, and make sure you open the tank valve before the burner valves.
Posted on Feb 01, 2009
  • 4 Answers
SOURCE: smoker will not reach heat of 250 to 300 to effectively smoke meat
I have heard that the "new" propane tanks have a saftey valve that closes if they are opened too quickly, try opening the valve very slowly. When you say it has been cleaned that means you have checked the venturi and the burner for spiders?
Posted on Jun 08, 2009
SOURCE: Black Residue on meat using Kitchenaid meat grinder attachment
the guy that said that the meat produces this is full of it since the black reside is the blade friction against the round metal piece with the holes, i had black fine powder all over my mixer without any meat
Posted on Jul 19, 2009
woodchuck789
  • 4059 Answers
SOURCE: Meat keeps freezing in my meat draw.
There may be a separate control for the meat drawer down where the drawer is. If not, you use the fridge temp control. Make sure the vent between the freezer and fridge is opening and closing when you adjust the temp.
Posted on Oct 17, 2009
Meat weighs 2llb 20oz how long should i cook it for we like it medium rare ?
The best thing you can do is to buy a BBQ digital thermometer that you place in the meat during cooking. They have a heavy duty wire with a temperature probe on the end. Sear the meat directly over the coals (or hot side of a gas grill), then move the meat to a cool side and then insert the temperature probe and close the grill lid. Cook until it reaches desired temp, for me 125 degrees is perfect. The total cooking time is hard to judge as it depends on your grill cooking temp, but the digital thermometer takes all of the guesswork out of the equation as to when the meat is done.
Apr 06, 2015 | Grilling
Does Cuisinart Deluxe 11 grind meat?
Depending on your definition of GRIND, the manual:
http://www.cuisinart.com/share/pdf/manuals/dfp-11.pdf
says the metal blade:
chops raw and
cooked fruits, vegetables, meat
Nov 12, 2014 | Grilling
Can someone give me instructions how you use a meat thermometer?
Watch this video from Video Jug - it's gives good instructions for a food thermometer;
http://www.videojug.com/film/how-to-use-a-meat-thermometer-2
Feb 14, 2013 | Health & Beauty
What are the benefits of using a cooking thermometer?
Using a cooking thermometer takes away the need to cut into a piece of meat or chicken to see if it's cooked. Also it reduces the risk of harmful bacteria that come with undercooked meats.
Feb 14, 2013 | Home
What are digital probe thermometers? Are they used for cooking meat?
yes - digital probe thermometers are very good for testing whether meat is cooked. The thin sensor is inserted into the fattest part of the meat. A wire then runs from the sensor out of the oven door, so that you can keep an eye on the temperature without having to keep taking it out the oven.
Feb 14, 2013 | Home
What are instant-read meat cooking thermometers?
These thin thermometers can be inserted into the meat for around 30 seconds to get an accurate reading (avoid the bone).
Feb 14, 2013 | Home
Why do people use meat thermometers?
: Meat thermometers are great ways to measure the internal temperature of meat while it's cooking. It allows an easy and yet accurate way of knowing if the meat is cooked.
Jan 10, 2013 | Home
Hi! I just bought a Weber pocket digital thermometer and want to know if I shall leave it in the meat in the oven during all the roasting time or insert and check once in a while? Please help.
It is not designed to be left in the meat, while in the oven. It's an insta-read type of thermometer for occasionally checking the internal temperature, in the thickest portion of the meat, while cooking. Be careful not to insert it in such a way, that it touches a bone, It will give a false reading, if it does.
I hope this helped you and thanks for choosing FixYa.
Aug 14, 2011 | Weber-Stephen Products Weber Digital...
I have a Sunbeam digital meat probe thermometer used once. Now the display for thermo/temp comes up H instead of the temperature of the meat. What is wrong? Sunbeam digital meat probe thermometer has quit...
I left mine in a hot tub for well over an hour. It started reading room temp at about 125 degrees. It worked for me to put the thermometer in the freezer until the readings were correct. hope this works for you.
Feb 22, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
Grilling Logo
Top Cuisinart Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Cuisinart Grilling Expert? Answer questions, earn points and help others
