Question about Kenmore 42822 Front Load Washer
Where to put the soap
We were given a used H3 Washer and I don't know where to put the soap. There is no manuel.
    President:
  • Kenmore Master
  • 2,651 Answers
Heres a user manual to the "whirlpool" sister machine, your nknobs may differ slightly but overall function is the same....
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208182271.pdf
Posted on Jan 26, 2009
My kenmore h3 washer doesnt drain my powder soap down what should i do?
The newer front load machines require HE detergent. If your not using this I highly recommend switching to it for optimal performance of the machine. Now if your talking about your machine doesn't dispense the soap from the dispenser into the machine then you may have an issue with either the dispenser motor or the water valve going to it. This can be verified by taking the top off the machine and starting a cycle and watching the motor which is located at the rear of the dispenser
Jun 01, 2012 | Kenmore Washing Machines
I need the manuel, It was given to me without one, and I don't know how to use it.
Hellowww.timexaudio.com/pdf/T605_IB57807_01.pdfGet into this link. You can download the user manual to your timex clock from here. If you feel any difficulty in downloading the same, inform me with your Email Address. I've the downloaded user manual to your clock radio. But I can't send it to you by this window as it does not allow me to upload PDF files by it. OK
Dec 20, 2011 | Timex Nature Sounds LED Clock Radio
EF 2 error is showing on my electrolux EWF14811 washing machine what does this mean?
it means that your using too much soap in your washer... the service manuel recommends that you reduce the amount of soap you are using.
Aug 15, 2011 | Electrolux Washing Machines
Hummer h3 I'l change me manuel Transmission Oil
There is a threaded plug on the bottom of the transmission that is 1/2" drive take this out and the fluid will drain, replace and on the side there is another 1/2" drive plug that you use to fill, you will fill until the fluid starts to come out this side hole. Hope that helps you.
Aug 05, 2011 | 2006 Hummer H3
Water left in tub at end of load smells bad you don"t see water but can hear at a turn of the tub by hand.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
Where is the filter
Are you using powder soap if so fill washer first and let adgitate a little before putting clothing in. However i don`t recomend powder soap.
Aug 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Using reg detergent in Cabrio He cause problems?
yes you do need to use HE soap in your unit. the he type soap is a low sudsing and the reg soap will cause the unit to not rinse out and could cause it to not spin properly. the noise you are hearing is probably something n the pump and if it doesnt go away after a few loads, then you should try to check the drain line going into the drain pump. it could have something causing the noise.
otherwise you could have a spin bearing making noise. its not as likely but could happen after a year or two of using the wrong soap. the wrong soap will ruin the seals and let water into the tub bearings and that will cause them to wear and make noise.
keep running it and get back to us if you still need more help.
thanks tzweeb
Feb 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Cleaning cycle
bleach goes in the bleach area. no soap or clothes in the washer. close the lid and hit the power & clean washer buttons. should run for 60 minutes, but check it after an hour to make sure it is complete. mine ran (malfunctioned) for over 3 hours indicating 7 minutes left.
Jan 14, 2009 | Kenmore Oasis HE 27082 Top Load Washer
21086 reading sl
If it is top loading one, you use powders for 'top loading machines'. If yours is a front loader pl use powders for 'front loading machines'. It makes a big difference in cleaning.
Feb 23, 2008 | Kenmore Elite 21086
Kenmore 42822 Front Load Washer Logo
41 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
