Question about Cameras
On my gr-hd1 the POWER SWITCH popped off! along with a small spring that was under it. Where can I buy both of these parts. Where can I send it in for a cheap repair? and how Much?
On my own, im not paying for ********
Posted on Jan 19, 2009
My power button on my Gateway ML6232 is loose
Keyboard/Hinge Cover with Power Button Bezel,
http://www.laptopswer.net/products.php/GATEWAY_ML6000-MT6000_POWER-BUTTON_3CMA7KBTA07/cPath,1_97_102/language,en_US/osCsid,8d147ed2c28ef93651edc40940d868e7
The Power On switch is not part of this small cover. The Power On button that you see, is merely a little button cover. The actual switch is under it, and mounted to the laptop.
[ The Power On switch is a Momentary Contact Switch.
Much like this example of an ATX power on switch,
http://www.directron.com/atxswitch.html ]
Removal and Replacement of the Hinge Cover with Power On bezel:
1) Remove ALL power to the laptop. Remove the AC adapter (Charger) and Battery.
2) This strip cover pops up. It has small plastic protrusions, or tabs molded on the outside edges.
These tabs snap into place in the Palm Rest Cover.
I use a small flat tip Jewelers screwdriver, and ease up on the end opposite of the Power On button. Then carefully go along the edges.
Replacement is to just line it up, and snap back into place.
Regards,
joecoolvette
Jan 14, 2012 | Computers & Internet
Just bought a used JVC GR-HD1 camcorder. Bought two new SanDisk SDHC 8GB memory card. When I press "record" I get a "card error" message with both of them. Are they the wrong type of...
This camera can not use an SD card of that size. Just like with any computer intergraded hardware, they have to write parameters of that day into the operating system of the device. They can not just leave it "open ended" to allow any size that might be available in the future. I believe the maximum is 1GB of standard SD speed (as in not the max of ultra speeds). 1GB would be more than enough at the resolution this camera will store still frames (it can not store video on SD cards). This is from personal experience with my own GR-HD1U.
May 21, 2011 | JVC GR-HD1 Mini DV Digital Camcorder
I have had my Delta bathroom faucet about four years. The hot water side drips. Can not get it to stop. It is one faucet with hot and cold handles with all sitting on a small platforum. The platforum is...
Go to delta website, take a picture of faucet with your cell phone and send. They should be able to identify and send you the parts. Meanwhile you'll have to turn water on and off from the emergency shut off valve under the sink. If it looks like the picture, it's probably the rubber seat and spring. If you don't want to wait go to your local "hardware" store. There may be someone there to help you. Bring the stem or cartridge, along with the rubber seat and spring. Don't use cold water while stem is removed. Turn cold off as well to prevent a mishap.
Apr 23, 2011 | Delta Faucet Bathroom Faucet - Delta 2...
I CANT GET THE JVC GR HD1 TO CAPTURE IN HD. THE PROGRAM IS COREL VIDEO STUDIO PRO. IT CAPTURES IN DV PERFECT BUT GO TO HD AND ITS JUST A GRID OF COLOURS.
Try the ensharpendecoder-win.exe by techsmith from camtasia studio 7.
I have been having problems for 2 years with Studio 11 plus and my GR-HD1.
And yesterday i downloaded this small prog 353 kb and now i can use the camera in Mpg2 mode.
Hope this helps anyone with the same problem
Regards Barry
Mar 13, 2011 | JVC GR-HD1 Mini DV Digital Camcorder
How to switch menu language on JVC GR-HD1, from japanise to english?
Hello
There is no mention about the language selection on this device's user manual. You may have to reinstall the software I thinks. If you wants its manual send me a mail to my email address given below.
gopakumarg43@ymail.com. The manual is in Adobe Acrobat Reader format. OK.
Jan 11, 2011 | JVC AV-27850 27" TV
How do you get the JVC GR HD1 to upload in hd on a pc? which cords and software do I need?
This can be done through the fire wire port (mini firewire400 on the cam to what ever firewire size port is on your computer) to and any video editing software that can handle HD codecs. Inside the editing software there will be a way to import video from a camera. This part of the program will control the start and stop of the camera via the firewire (ie you do not push buttons on the camera). It will start the tape and record into the PC. You can choose to compress the video to a bunch of different formats to make it more manageable. The owners manual spells it out pretty good. If you can't find it let me know and I might still have a web link to one.
Jan 17, 2010 | JVC GR-HD1 Mini DV Digital Camcorder
Power Button Came Off
Hopefully this is not a duplicate post as I lost the previose post I spent so long writing when I hit Post Solution.
I had the same issue with mine and finally lost the button. I could not find a way to get it to stay in (and I'm very good a figuring things out like that). I'm pretty sure something broke and left no sign.
I called JVC when it happened back in 2007 but there was no recall on this. The tech I talked to could not find the part and told me it was not available. Two years later I decided to try again and this time talked to a tech lady that was very open about how and what she was looking at to find the part. When she could not find it, she emailed me a parts diagram (exploded view) of every component set that makes up the camera. Turns out that the switch is not mentioned anywhere in the parts list that correlates with the diagrams because it;s part of an assembly that has do be replaced as a whole. This is more info to back up my thinking that the switch can not be put back in place once it pops out. After we both looked at it for a while I found it as the exploded view is not showing that portion of the handle in full view. I forget the name of the assembly but I think it said something like Power(rec?) board IDK. Either way it sounded more of an internal thing but that was it. I will be ordering this part this year so I will have to dig up all that info again. The process to replace this switch assembly is very complex and requires that the handle/tape housing be removed from the camera. Then it all has to be taken apart with tons of micro screws and small parts. No unsoldering that I could see (most every mini board disconnects with mini plugs. Let me know if you want more info once I order this part. I think it was around $150 but I hope it is still available.
Jul 01, 2009 | JVC GR-HD1 Mini DV Digital Camcorder
JVC Gr HD1 power/record button fell off and tape stuck inside
I have a solution posted on replacing the button in another Question but as far as your question; If you still have the button you can pop it back in (push in and hold tight) and move it to the position to turn it on. Once it's on you don't have to hold it in to keep the camera on. Only switching it to the off position will turn it off. Let me know if you lost the button and I can give you a work around for that (even if you still have the button and are jamming it in there but it's not working my workaround could help).
Jun 06, 2009 | JVC GR-HD1 Mini DV Digital Camcorder
Cannot get key switch out of steering column
First thing I would say is you should pickup a repair book like CHILTONS for your year make and model of jeep it will give you step by step instructions. On most older jeeps to remove the key switch you must first pull the steering wheel (steering wheel puller needed) then horn contact under that, then the turn signal switch under that, under that you will find a spring loaded security plate that must be pushed in and held untill you remove the split ring around the steering shaft that holds the plate in ( it's not easy it's a STRONG spring and it takes three hands with two strong thumbs to compress the plate and spring and another hand with a small screwdriver to remove the ring. (They do make a small cheap tool to compress and hold the spring but if you have strong thumbs it can be done without the tool) once you remove that plate you will see a small flathead allen screww along side the key switch remove it and the switch should pull out. Some must be turned to the run position to pull out but Im not sure about your year.
May 26, 2009 | 1983 Jeep CJ7
Power switch
The power switch is only supplied with the operation unit (camera/off/vtr assembly). You can find this replacement part here.
Mar 06, 2008 | JVC GR-DVX7 Mini DV Digital Camcorder
Cameras Logo
26 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
