We have a 1995 52 in rear protection TV hooked up to Time Warner. Laft night while using the guide, I mistakenly hit record instead of select on the cable remote. We do not have a DVD recorder but the cable box when to rEc and locked up. It also switched to a different channel that we could not change. We unplugged everything to try and reboot the cable box but it wouldn't work. My husband took the TV remote and selected the menu item. Not sure what he did but we lost all picture except for the words Antenna B Channel 3. I then called Time Warner, they reset the cable box back to the time but we are still locked out of the TV. We can only go between Channel A and Channel B but lost the other options Video, etc.They sent a technican out and could not figure out what is wrong with the TV.
Called our son to help us out.
Posted on Jan 19, 2009
My 32 incn Hisense Roku tv can I hook it up to my time warner cable instead of wireless connection
Yes, you can. You would need to hook the cable box up to the tv using an HDMI cable for it to work. Hope it helped!
Jan 08, 2017 | Optics
How to hook up vcr and tv using digital adapter
You can hook up the VCR directly to the TV; you don't need to hook up the VCR to the adapter. If you already had the VCR hooked up to the TV, you don't need to change those connections.
Jan 29, 2015 | Televison & Video
Got the digital set up box from Time Warner Cable but they did not include hook-up instructions.
If you have an HDTV, you can hookup HDMI cable from set-top-box to the HDTV's HDMI input and select that input on the TV using your remote. If you have analog TV, you can hookup using RCA cables (yellow to yellow, white to white). You could also call Time-Warner for assistance.
May 16, 2011 | Televison & Video
I have Time Warner cable. I have a Symphonic SR90VE vcr/dvd that I have hooked up to the main TV. The cable box services a second tv in another room. I can't seem to get the main tv and the vcr/dvd player...
Cable goes to vcr cable INPUT, then run cables from vcr OUPUT to tv INPUT or AV.
Then put tv on input or av channel or channel 4 and use put the vcr on the channel you want to record.
Apr 19, 2010 | Televison & Video
We have a Panasonic DMR-EH55 dvd recorder, it worked just fine until March, 2009 when Shaw quit subscribing to tv guide. Has there been any resolution to this issue?
Shaw like Time Warner in many areas of the U.S. will never go back to TV guide.
Your best bet is to switch to the competition in your area.
Jan 31, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
When I connect HDMI from a Time Warner DVR to my Vizio thru a DVI/HDMI adapter, I get no sound. I can only get sound if I use Component input (RGB+ audio R&L). Is this a DVR issue or a Vizio issue?
Use the Time Warner remote and hit the settings button twice. Scroll down to "audio: digital out" and select HDMI. That solved it for me.
The only issue I have now is that I also have component sound outputs going from the cable box to a receiver. When I turn off the TV while the HDMI cable is hooked up to both the box and the tv the sound goes out to the receiver...
Nov 15, 2009 | Vizio P42HD Television
Wii hook up to time warner cable box with a dvd
I needed another part... an RCA cable splitter to put two cables into the same TV connection.
Nov 09, 2009 | RCA Televison & Video
TVGOS (TV Guide on Screen) stopped working on Time Warner.
split your input cable line and connect one end to your digital input and the other to your
analog or air input.
Jun 28, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
Hooking up
depends what you're trying to hookup. TV? take coax from tv out to INPUT on back of ilo, setup tuner(selected in source). From VHS? hook up a vcr to another one of the inputs, A/V one the unit. Even the ones on the front will do. Then after going into the record menu and setting up the length/quality settings, then select source to select which input you want to record from and hit record. Try to end it before your alotted time expires and forget about programming it to record something automatically via the time, It never works well, if at all for me. Best bet is +RW's depending on unit. Mine is MU unit and Sony +R's work good for me.
Jan 23, 2008 | iLO DVD Recorder DVDR05
Picture in picture problem
When you use the Time Warner Digital box, you're using the tuner inside that box rather than the tuner inside your TV to select a channel. Picture in picture TV's have two tuner's inside so you can view two channels, but they can only tune the analog channels from your cable company, and only if it's hooked up in a manner that will permit this to happen.
So you only have one digital tuner (the Time Warner Box) so you can only view one channel at a time even though your TV supports Picture in Picture.
It MAY be possible to have limited use of the PIP if you connect your TV in a different way. Your Time Warner box is most likely connected to your TV set with composite cables, those are the Yellow, Red, White cables. If you buy a coaxial cable splitter and split the cable before it goes into the Time Warner box you can then run a coax cable into both the Time Warner box and the coax input on your TV. This would allow you to tune the analog Time Warner channels with both of your TV's tuners. In my area I think the first 60 channels or so are still available in analog, but there is no way to watch any of the higher premium channels without the Time Warner box.
If you go through these steps and you select the coax input on your TV your PIP will work on the lower channels. It MAY be possible to tell your TV to display the input from the composite cables on one of the PIP screens and the input from the coax on the other, but I kind of doubt it.
I know this sounds complicated and if you're not familiar with the way all this works it is complicated. The reason lots of people won't respond to this kind of question on this site is because there is no easy fix and by trying to help I run the risk of getting a bad rating. I don't get paid for this, I just like trying to help, so if I have not explained this in a way that's helpful to you please ask some additional questions before you give me a bad rating. Thanks.
Jan 01, 2008 | Panasonic CT-32D31 32" TV
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
