Question about Apex Digital AD-2500 DVD Player
Can't connect apex dvd player to HD tv?
Need to know how to connect DVD player to Samsung HD TV and get signal.
SOURCE: DVD/VCR combo player won't work
I had a similar problem and corrected it with a solution found on another site. Try hitting the I/P button on the remote which controls whether "Interlaced" or "Progressive Scan" is used to display the image on the TV. Mine worked when "Interlaced" was used. but no picture was displayed when "Progressive Scan" was used. The I/P button toggles between the two settings.
Posted on Jul 19, 2007
SOURCE: dvd player not loading
I openned mine up and found that the lens carrige was not in the fully retracted position. I pushed it all the way back to the back of the slide. Then I removed the two screws on either side of the spindle support so I could get to the lens. I hit the lens with some compressed air, plugged it in and loaded a disk and it worked like a champ. Listening to some Stevie Ray Vaughn right now!!! And going to watch some movies later. ;)
Good luck, I hope this helps someone.
Wrench
Posted on Dec 03, 2008
  • 159 Answers
SOURCE: APEX Digital VCR&DVD PLAYER ADV-3800 will not play DVD's.
What it so far done, it looks pretty fine. I'd break apart the problem if is posible to do it, i mean maybe you have some other sets around the house or some friend who have them.
  • i'd test the dvd/vcr in a different tv
  • i'd test the tv with a different dvd
i would start over again the installation after this test.
the reason is to know if you can trust in those sets and second maybe with some other try the installation works
Posted on May 02, 2009
  • 103 Answers
SOURCE: apex AD-1100W dvd/cd/mp3 player quit playing movies
hi,
Does it happen for all dvd disc or some particular dvd disc. If it is with some particular disc then clean the dvd and try them. If the problem exist for all the dvd then try to clean the lens by dvd lens cleaner and try to play. dvd lens cleaner will be available in dvd stores.
Thanks,
Posted on May 23, 2009
SOURCE: code for apex tv through philips universal remote
Go to www.urc.philips.com/
Follow the steps..its easy. It will ask for the model of your remote which you will find where your batteries are located..The code I used for my APEX tv was 0023.. to load the code first hold the setup button until the red light stays on..then press tv or whatever mode you are setting up..then enter the code and if the red light goes off it is the right code and you should then press channel up to see if it works...If this code doesn't work the site above offers other codes.. Hope this helps!!
Posted on Dec 06, 2009
How hook up dvd player to tv. what channel put tv on to see dvd pitcure
You should be connecting your DVD player to either an HD input or a composite video connection. Most modern TV SHOW will have at least 2 HD connections. On your TV setup menu there should be an HD connection to choose (probably HD-2) You will need to switch your input selection on your TV menu between HD/TV for TV and HD2 for DVD. It's hard to give specific directions without knowing the TV and DVD models.
Oct 27, 2016 | Televison & Video
No audio input from TV on DVD Home Theatre
U have audio signal incompatibility. If the audio output is digital it may not work with an analog input, etc.
May 08, 2017 | Audio Players & Recorders
How to program the TV remote to work with an APEX DVD player? I do not have the APEX DVD code.
As far as I can remember, the original JVC remote doesn't support a DVD player. It doesn't have the necessary buttons to control the player functions. You'll need to stick with the original Apex remote if you have it, or look for a universal remote that is compatible.
Jul 30, 2011 | JVC AV-32D502 32" TV
My dvd player appears to be working - the disk is in place and the numbers advance as if it is playing - but all the tv screen displays is No Signal. I've talked to a Comcast tech and the problem doesn't...
Make sure your TV input source selector is set to the correct option (Video 1, Video 2 or Rear Video Connection or whaever the options are for your TV) when you want to play a DVD.
Try using the DVD player on a different TV to see if the DVD player is working OK.
Then try a different DVD player hooked up to your TV to see if your TV is set up OK.
You can also try using a different set of cables just in case the cables are faulty.
Try using an S-Video cable from your DVD player to your TV (if they both have those connections)and see if you get any signal that way.
When you are testing, be sure to check the sound on your TV to see if you are getting any audio signal from your DVD player.
By carrying out these troubleshooting procedures you should be able to narrow down exactly where the problem is and then fix it.
Apr 19, 2011 | Apex Digital AD-2600 DVD Player
Had to get new DVD player as old one packed up. Connected one year old Samsung television receiver LA26B450 to new Philips dvd player DVP3560K but gives no colour, only black and white. Have checked...
to put this simply ive spent almost all day advising on this exact problem have alook at my fixes and it will show you the problem but to put it simple you either have connected the wrong cables ie-- rca vs caroma the best way to fix this is to correct the setting in the output on your dvd player it needs to know what signal to send the tv ie rca caroma or hd cable
best of luck let me know if you need further help
sonic boom electronics
Dec 28, 2010 | Samsung SP42P2S Television
DVD player and HDTV incompatiblity?
Which ports on the TV are you using to feed the video signal to the TV: Composite (yellow RCA), Components (red, blue, green RCA), HDMI?
Dec 23, 2009 | Samsung LA26R71BD 26 in. HD-Ready LCD TV
My dvd
He may have reconnected the DVD player to a different connection on the back of TV. If so, you'll need to change the INPUT source using your tv remote control. On the TV remote, there should be a button that says something like INPUT or SOURCE. This button will let the TV display the signal coming through the different jacks on the back of the tv.
Jun 17, 2009 | Apex Digital PF2720 27" TV
DVDs are only in black and white
Jimbo.. is your new TV HD compatiable??
Nov 11, 2007 | Apex Digital AD-1110W DVD Player
Apex Digital AD-2500 DVD Player Logo
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
