Question about Fisher and Paykel Refrigerators
Fisher paykel model rf201a error code f21 - Fisher and Paykel Refrigerators
SOURCE: Error code F32 for fisher
All you need to do is, take out 3lt of water from the tab on the fridge without stoping . This will take all the air out from the water tank at theback of the fridge (This will also stop leakage)
Posted on Oct 04, 2008
Got the same error here, called Fisher Paykel and the said it's an error related to the water line. They recommended running 3 L of water and see if code disappeared. If not, call service, they gave me a local company. Error code has disappeared, for now.
Posted on Nov 09, 2008
SOURCE: Fisher and Paykel model RF610
The F24 error show that the sensor in the ice maker is out of normal ranges. The usual fix is to replace the sensor in the ice maker.  Also worth checking it to see is the water to the ice maker has frozen up in the value (switch the fridge off for a day). If the error still exists after that you will need to replace the ice maker sensor. You have a 2 year warranty on these parts so the fix should be free.
Posted on Mar 24, 2009
  • 148 Answers
SOURCE: Fisher & Paykel fridge freezer, Fridgidaire
call that company server
Posted on Apr 05, 2010
ginko
  • 19396 Answers
SOURCE: Error code F20 on RF610A
Hi.
F20 means that there is a problem with the defrost system. The temperature sensor and the element comprised in the defrost system must be tested. Testing is done removing the firewall panel (usually in the freezer compartment in F&P) and accessing the parts. Parts are tested reading impedance with a multimeter. The test will determine if element is open or if the temperature sensor is open at room temperature to find out if any of the two parts must be replaced. Voltage to element must also be tested.
Try performing a manual defrost. Remove all food and disconnect the fridge overnight. If the problem does not come back, then the fault was probably a temporary malfunction. If the defrost system is faulty the problem may come back after a couple of days, when the defrost system restart malfunctioning. In that case ring the F&P number listed on the owners manual to call a technician.
Regards.
Ginko
Posted on May 09, 2011
Fisher & Paykel fridge is showing F20 fault in screen and beeps when door is opened
SOLVED: Fisher paykel French door fridge shows F20 error - Fixya
www.fixya.com/support/t16590488-fisher_paykel_french_door_fridge_shows
Feb 15, 2013 - F20 does not stand for 20 degrees Fahrenheit you pleb. It is a fault code. Your fridge probably beeps 20 time when you open the door and then stops. To fix is simple and takes 5 mins. Remove the top left hand hinge cover and you will find a broken wire. Just switch off the fridge and then connect the wires ... What does F20 mean on my F & P Fridge. When I ...
14 Feb 2018
What does F20 mean on my F&P fridge. It beeps ...
14 Feb 2018
I have an f20 error on my fisher and paykel fridge ...
16 Nov 2017
SOLVED: Error code F20 on RF610A Fisher & Paykel
9 May 2011
More results from www.fixya.com
Fisher Paykel Refrigerator F20 Error Code ' Wills Creek Community ...
www.willscreekcommunityforum.com/fisher-paykel-refrigerator-f20-error-code/ Sep 27, 2017 - If you are experiencing a F20 code on your Fisher Paykel refrigerator, you will hear a constant beeping sound when you open the frig door. This error code means there is a broken wire on the top of the door hinge (usually left side). If you are even a bit handy, A simple solder job is the fix and can save you ...
Apr 29, 2018 | Fisher Refrigerators
Error code 130
IF a Fisher and Paykel, see this link:
http://ths.gardenweb.com/discussions/2427379/fisher-and-paykel-gwl11-error-code-130
You need to list brand (if not also model number) when you post white goods questions. Codes are specific to a manufacturer.
Mar 04, 2015 | Washing Machines
Our Fisher & Paykel Intuitive Q came up with an Error Code 51, Stopped and an Alarm came on.
Hi, this is an update on what I found out about the E51 error code from Fisher & Paykel. This code is an error with the internal memory as one of the previous poster's said. Fisher & Paykel Rep said though it wont hurt the function of the machine it should still be replaced because it may effect the compliance information.
Nov 15, 2010 | Fisher and Paykel (IWL12)
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Error code F32 for fisher paykel fridge F32 and a spanner is appearing in the display of our new Fisher Paykel fridge model # RF610ADUX. What does this mean ?
Aug 24, 2008 | Refrigerators
Refrigerators Logo
117 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
