Question about WindCrest 35 in. CTG365D Stainless Steel Gas Cooktop
Gas cooktop surface
I'm looking for a new cooktop and it seems every retailer has a different opinion about the surface.  One says I would hate stainless because it's hard to keep clean and is porous so it will stain.  Another says stainless is most popular and people love it.  My only other choices are white (the grates are either black or bright gray) or black which would not go with the rest of my kitchen.  Any info about stainless sure would be beneficial to me.
    Sergeant:
    Champion:
  • 338 Answers
Stainless is hard to clean if you dont keep up with it. Black is horrible because you see every imperfection. white turns color after some time..
I suggest stainless if you keep up with it.
Posted on Jan 18, 2009
The regulator seems to be closing off completely, and not flowing gas (LPG). We have converted cooktop from natural gas to propane per instructions manual -- changed orifice spuds, converted regulator and...
I HATE TO TRY AND EXPLANE THIS FOR FEAR SOME THING MAY GO WRONG DID YOU FOLLOW THE INSTRUCTIONS TO THE LETTER. FROM NATURAL GAS TO LP YOU SHOULD OF HAD TO CHANGE THE POSISTION OF THE ORVICE IN THE REGULATER THAT IS WHY YOU ARN'T GETTING THRU THE REGULATOR CHECK YOUR DIRECTIONS AGAIN SOME TIME YOU HAVE TO THIGHTEN THE NUT ON THE REGULATOR SO IT DISTORTS THE ORFICE TO LP, AND SOME MODELS YOU HAVE TO TURN THE ORFICE OVER. BECAREFUL AND TRY AGAIN
Feb 06, 2011 | Maytag MGC5430 Gas Cooktop
I need 4 replacement knobs and I cannot find them!! Please help
Hi and welcome to FixYa, I am Kelly. I am assuming that your model number is MGC5430 as listed in your post. If not use this link to find them by entering your model number:
(just note that there are 2 to 5 digits missing from your model number)
http://www.appliancepartspros.com
See this page:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MGC5430
It brings up the following models:
arrow_link.gif MGC5430ADB SURFACE UNIT- GAS arrow_link.gif MGC5430ADC SURFACE UNIT- GAS arrow_link.gif MGC5430ADQ SURFACE UNIT- GAS arrow_link.gif MGC5430ADW SURFACE UNIT- GAS arrow_link.gif MGC5430BDB SURFACE UNIT- GAS arrow_link.gif MGC5430BDB20 36`` GAS COOKTOP arrow_link.gif MGC5430BDQ SURFACE UNIT- GAS arrow_link.gif MGC5430BDS SURFACE UNIT- GAS arrow_link.gif MGC5430BDS20 36`` GAS COOKTOP arrow_link.gif MGC5430BDW SURFACE UNIT- GAS arrow_link.gif MGC5430BDW21 30`` GAS COOKTOP
I used the MAYTAG MGC5430BDB20 as a reference and the BLACK knob is item 6 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5515609&diagram_id=28426062#d28426062 Detailed view is here: http://www.appliancepartspros.com/part_details.aspx?part_id=4100044 If you need more assistance please respond with a complete model number and I will use other sources to loate your knobs. Thanks for choosing FixYa, Kelly
Jan 05, 2011 | Maytag MGC5430 Gas Cooktop
Whirpool cook top surface light countiune on even surface are cold
How long does it take for the light to finally go off?or does the light ever go off when a cooktop decrease in tempreture has to reach the tempreture set by the factory for that light to go off. Sounds like a thermal switch which controls the hot surface light is stuck closed If this is a new unit, I'd return it. If not, I would check the switche(s) for the hot surface light -- when the unit is cold, unplug one wire going to the thermal switch and check it for electrical continuity. If you get current from a multi-meter through the switch, replace it -- it's not opening when it cools down.If you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Dec 12, 2010 | Whirlpool RCC3024 Electric Cooktop
Bosche cooktop nht 725 a uc 1999 need conversion kit to go from natural gas to propane, hate to toss a good stove top need model kit order numbers
I spoke with Bosch customer service who said there is no natural to LP gas conversion kit available for the NHT 725.
Oct 05, 2010 | Bosch 30 in.NGP746UC / NGP742UC Gas...
Porcelain grate scratched or stained?
If you keep using the range without the aluminum pans it will eventually go away, but aluminum will leave marks on the surface of the grate.
Aug 20, 2017 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Trying to remove stains around the gas unit where temp is the hottest.
have you tried cooktop cleaner? this seams to work pretty good at getting stains out of stainless steal. (You know...cooktop cleaner is really just car wax if you had some try this on a little area and see how it works and if you like the results...there you go.) let me know what you think. But like i said always do a test point before doing the whole surface.
Apr 22, 2009 | Thermador 37 in. SGSX365 Gas Cooktop
One burner on a 6-burner gas cooktop misbehaving
sounds like the air /gas mixture is off.look at where the burner meets the gas valve (the knob) under the grates and play with the adjuster turn it slowly while the burner is on and this will change the value of the air/gas mixture good luck
Jan 25, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
I can not separate the glass cooktop from the granite surface.
alot of installers will use a silicone glue to "seal" the unit to the countertop. what happens is that means you cant get it out without cutting the glue off first.
it could also be that the unit is very tight in the countertop.
also did you remove the "hold down" screws from underneath the unit first??? there should be a screw on each side below the unit.
one more thing... do you have a gas line under your counter? if not be sure you can get a gas line to it before you try to remove the old unit. most homes have a finished ceiling under the kitchen and it would be almost impossible to install a new gas line if its not already there.
Dec 29, 2008 | Jenn-Air JED8430 Electric Cooktop
Stains from cleaning products?
Bosch (BSH appliance care) do a stainless steel conditioner you could try. I think its called Starglanz.
Nov 05, 2007 | Bosch 36 in. NGT 935 Gas Cooktop
WindCrest 35 in. CTG365D Stainless Steel Gas Cooktop Logo
151 people viewed this question
Top WindCrest Cooktops Experts
Paul Carew
Are you a WindCrest Cooktop Expert? Answer questions, earn points and help others
