Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Cleaning Solution What cleaning solution do I use in the Hoover Floor Mate?
  • Anonymous Apr 27, 2009
    LOST INSTRUCTION GUIDE
  • 294 Answers
The solution is called "floor to floor" sold in a white 48oz bottle
Posted on Jan 20, 2009
Hoover floor mate h3000 will not suction water from floor when cleaning
Your collection canister may not be positioned tight enough in its place ment site. Tip machine back using foot pedal (as if you were going tio start using machine to clean) Insert collection canister (bottom container, then insert top canister with solution. The two canisters must be flush with machine side seams and must sit in position tightly. This is sometimes very tricky and may take a little elbow grease to make it click into place. Hope this helps
Jul 08, 2015 | Hoover Floormate H3000 Upright Wet/Dry...
New hoover floormate deluxe does not seem to be cleaning tile floor
Take it to your local Hoover warranty station. You have a one year warranty. These new machines are giving some trouble.
Feb 19, 2015 | Hoover FloorMate Deluxe Hard Floor Cleaner
I have a hoover floor mate hard floor cleaner and the brushes won't spin
Hi, it's Jeremy from Crucial Vacuum.
In the link below you will find the user manual for your Hoover Floor Mate vacuum:
http://hoover.com/file/597/
Here are a few repair tips to make fixing your vacuum easy. Your Hoover brush-roll is connected to the motor by two different sized geared belts. Over time, the belt's gears wear down and stretch out losing the grooves and tension that turn the roller. When this happens you will simply have to attach a new set of belts. Another reason why your brush is not spinning could be that there is debris stuck in the roller and/or bearings. You can either use a can of compressed air to remove the debris or simply remove it with your hand.
You can purchase direct your replacement Hoover Floor Mate parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/index/?manufacturer=37&q=floor+mate
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 06, 2014 | Vacuums
Unable to find recomended cleaner for floor mate, what can I use
Do NOT use ammonia...it will destroy the seals. #1 NEVER leave solution in the tank...and clean everything after every use. Lowe's and/or Home Depot have Bissels cleaner for the Hoover Floormate...also check Target and Walmart's sweeper dept. If ALL fails, you may use Zep Pine Cleaner (Home Depot) in a diluted 2oz. to 1qt. water...filling ONLY the little reservoir with this dilution!!!!! Good Luck.
Dec 28, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
I am also having the same problem - it will not dispense the cleaning fluid - it is more work trying to get the thing to work than it is actually cleaning the floor.
I just took the dispenser out and splashed the mixed water and cleaning solution on the floor, it works well, but I'd rather use a good spray bottle on my next floor cause the splashed can cause spots, unless the floor is already wet. In addition this floor mate is slow if compared to a spray bottle and a sponge on your bottom foot, moping and sliding your foot over stains, and mopping up till clean and streak free. Furthermore, I used Murpys oil instead, its works good Im happy, and tired this job requires constant cleaning and rinsing of your mop bucket, with a one man team, alot of furniture and a piano its alot of work, but worth it at the end, later, going for starbucks for that pick me up.
Jun 07, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
What kind of cleaning products should i use
The recommended cleaning solution is called Floo to Floor for all types of hard floor cleaning. can be purchased at many retail locations.
Feb 23, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Why won't our Hoover Floor mate deliver water for cleaning?
After reading postings I created my own solution. I took a 1.5cm (approximate length) flush head finishing screw and screwed it into the button contact of the white memebrane and adjusted it to the necessary heigth to make the rod depress at the corrrect depth. My initial placement was too high and I had a continuos flow of water, but was able to fine tune. Also note the head of the screw I used was a similar circumference of the nob of the white membrane.
Oct 30, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Bare floor attachment for Hoover steam vac with surge clean
According to www.vacuumpartstore.com, for model #'s F5903, 5904, 5905, 5906, 5910, 5912, 5914, and 5915, you need Hoover SteamVac Bare Floor Cleaning Attachment (old # 48417003). You can get it at www.amazon.com for $7.99.
Oct 28, 2008 | Hoover F5906-900 Upright Steam Vacuum
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
149 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
