Question about Electrolux EI26SS55GS Stainless Steel Side by Side Refrigerator
Model EW26SS65GSO Alarm went off and compressor not running,checked power to compressor not getting 120 volts.Evaporator fan runs. Relaced main board,but still have the same issue,could the problem be
Electrolux Ref. Model EW26SS65GSO compressor and condensor fan will not run
aborcass
  • 2651 Answers
SOURCE: Hi i need a condensor
241712101--- heres the part number call your local suppplier or go sears .com to order it
Posted on Nov 05, 2008
SOURCE: please
make sure freezer door is closed all of the way when you press for water does dispencer light up and make click if it does make sure water comes out of pipe before hooking with frig. if you have water there make sure plastic water line is not crushed or kinked on back of frig.
Posted on Apr 12, 2009
galati2k
  • 281 Answers
SOURCE: No suction on my Electrolux central vacuum in all outlets even though motor is running and there is no clog in the hose.
go to the main unit,you have a blockage where the suction originates.can you disconnect the main suction line to the unit?do that and turn it on.if you have suction then then the main suction tube is blocked.a towel or rag of some sort got sucted in and got caught before it made it to the dirt tank please leave feedback
Posted on May 06, 2009
protek480
  • 1723 Answers
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 25, 2009
ThinkVacuums
  • 144 Answers
SOURCE: Need a new electrolux power nozzle model N106m
If you're looking for a new head for your vacuum. Then you're going to have to replace it with the same type of nozzle.
However, wall inlets are standard so you can purchase any kind of attachment kit and it'll fit your inlets and work with your system. Their are many online retailers that offer a wide range of kits that will fit your system.
Posted on Mar 23, 2010
Turbo Air Model TGF-23F Wont get cold. Compressor comes on and runs but evaporator fan isn't running.
Yes everything get power from the board. Look for wiring diagram and trace wire out
Jun 27, 2018 | Turbo Air Refrigerators
NO POWER TO COMPRESSOR
All compressors have a 1) Bi-metal t-stat and Most have
2) Start-Capacitor assist with 3) Plug-in Start Relay.
 All 3 parts are available at Most Appliance Repair stores and are not that expensive. It is usually 1 of the 3 that has failed.
If your Condenser Fan is Running it is one of the three components or a burnt off wire ... Be Safe.
Good Luck.
Oct 11, 2007 | GE PSI23MGN Side by Side Refrigerator
What type of a compressor that the sanyo SR - 36A uses? and can it work if remove a 110v compressor and replace it with a 240v compressor?
You can use a 220 volt compressor, just make sure the evaporator fan is also 220 volts as well as all of the bulbs, and anything else that is 120 volts. Everything must be 220 volts. including the start and run capicitors.
Good luck,
Marty
May 11, 2014 | Sanyo Counter Height, 3.6 Cubic....
I have a Amana fridge that the evaporator fan is not running. model no. SPD26VW Also have replaced the following defrost timer and defrost thermostat. I have about 0 volts at the fan. Removed the fan and...
There may be damaged or broken wire to the evaporator fan
There are two wires to the evaporator, one hot and one neutral Unplug and check the neutral against ground with a continuity tester if ok test the other wire in a non invasive fashion using a safety pin
The way you do is to insert the pin say at several points on the wire until you discover where the break is. Use alligator clips, one is to be connected at the connector of the fan hot wire ( The suspected wire that may be broken) With alligator connected at the end of the wire connector, insert the pin at different points to check wire integrity with an ohmmeter. Where there is no continuity, that is where the break would be.
If that does not work, you probably will have to run a new wire. Here is a hint: The evaporator fan runs only when the compressor is running. If you can extrapolate, you can find an alternate way to reconnect the evaporator fan and have your fridge running in no time.
Dec 20, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Amana sxd22s2w p1190416ww refrigerator. The Evaporator fan isnt running (compressor and condensor fan running fine) How can I tell if the problem is the fan motor itself, or something else, like temp...
Remove the cover to the fan, then remove the plug from the back of the fan. Connect a voltmeter to the 2 leads. Close the door switch and turn the fresh food thermostat to the coldest setting. This will call for cold and the fan should have 120 volts. If there is power to the motor replace the fan. No power check the thermostat. For help replacing the fan try this link http://appliancehelponline.com/sxsevapfan.html
Aug 11, 2010 | Amana Refrigerators
Amana side by side model ssd22nl. compressor runs and runs, but the evaporator fan does not come on. what would cause this problem?
Hi, If the evaporator fan in the freezer is not running, more then likely the motor has failed. The compressor will run and run because the thermostat control is never satisfied. If you have a volt meter you can check to see it there is power to the motor, 120 volts, but I would say that if it does not run, it is faulty and you must remove and replace it. If you do this on your own, take out the old motor and write down all of the information you can from the unit also. Model, serial, and name of unit. This will help if the appliance parts house needs to cross it over to a different motor. Keep me posted.
Sincerely,
Shastalaker7
Feb 02, 2010 | Freezers
Compressor in fridge not working. Freezer is working fine. Is there a reset button? What steps can I take to see if this is a simple issue?
There is one compressor that serves both the freezer and refridgerator compartments. You need to confirm if the evaporator fan in the freezer compartment is working. When you open the door to the freezer, you should see and hear the evaporator fan in the freezer compartment running. Particularly if there is a demand on the unit through the thermostat setting. If the evaporator fan is not operating, you can check the evaporator fan motor with a volt meter to see if it's getting power. If its getting voltage, but not operating, you need to replace the evaporator fan motor in the freezer compartment. There are 3 wires that attach to the evaporator fan motor. One hot wire, one neutral wire and one ground wire. The ground wire is usually marked green, the voltage wire is usually marked black and the common wire is usually marked white. You should get a reading on your volt meter of a voltage from the hot post to the neutral or from the hot to the ground. If it is getting power but will not operate, then it is definitely a bad fan motor that would need to be replaced.
Oct 04, 2009 | Refrigerators
Frigidair side by side refigerator fan not operating
I do see the power to the evaporator fan section going through the adaptive defrost part number 240554502 It would not hurt to unplug for a few moments and open the control panel inside the fresh food section and examine that control board. With it doing that you may see signs of heat or burn marks on the ADC Let me know, Sea Breeze
Jul 21, 2009 | Frigidaire Refrigerators
Top freezer refrigerator
First, check to see if the compressor motor is on (located in the lower rear). If it is, make sure the fan near the compressor is on and also make sure all fans in the compartments work. If they all work, you can check the evaporator (behind the rear freezer panel) to see if it is frozen solid. If it is not frozen, the sealed system will have to be serviced. If the compressor is not working, check the 2 wires at the compressor for voltage (should be 120 v.). If 120 volts is present, replace the relay/overload on the compressor. If 120 volts is not present, replace the thermostat.
Oct 26, 2008 | Amana ARB1905C Bottom Freezer Refrigerator
Electrolux EI26SS55GS Stainless Steel  Side by Side Refrigerator Logo
49 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
