Question about Acer S201HL Monitor
How do I get sound from acer monitor s201HL
Not receiving sound. Do I need external speakers?
5 Suggested Answers
  • 7 Answers
SOURCE: Acer V223w monitor
Hello Cricket,
Sound/Speakers that are built into monitors, typically are pretty poor. I suggest purchasing some speaker from your local electronics store, or www.newegg.com. (New Egg has very good deals on computers and accessories, like speakers.) Here is a link to New Egg's speaker section. http://www.newegg.com/Store/SubCategory.aspx?SubCategory=60&name=Speakers
On the back of your computer, you will see little holes (3.5mm). They are usually color coded, Green is the typical speaker output jack/hole/port. When you buy your speakers, you will plug the cable with Green Head Plug (3.5mm) that is attached to your speakers, into this Green Jack. Turn them on, and you should have audio! Now, if the volume seems weak, you can double click the speaker at the bottom right of your Start Bar in windows. It looks like a little silver circle. This is your volume control There are multiple slide bars to adjust your audio.
Good Luck!
Posted on Dec 12, 2008
  • 461 Answers
SOURCE: I'm frustrated. Love the picture
Built-in monitor speakers are usually not the best quality. The monitor should have it's own volume control have you tried adjusting it?
You can use external speakers by plugging them into the same jack in the back (green) of the PC instead of the monitor.
Posted on Dec 13, 2008
smwsolutions
  • 73 Answers
SOURCE: Recently, I purchased an Acer H233H LCD Monitor
Try installing the Acer Monitor software and disabling the the desktop sound card under 'My Computer'. 'Properties','Hardware Devices'.
Let me know if you need help doing this, or need more help.
Posted on Jul 25, 2009
odiebugs
  • 949 Answers
SOURCE: i have acer al1917w A monitor but no sound
There is no sound driver, they are speakers, they work off of the audio output jack on the back of your PC, on the motherboard. If you have the sound drivers installed for the motherboard, and no sound, then you have plugged the monitor audio cable into the wrong jack on the PC, or you have the settings wrong just as MIKE said above.
Posted on Oct 31, 2012
What do i need to get sound on my new acer monitor
It has no speakers nor audio inputs. Will have to furnish external speakers.
Jun 14, 2014 | Acer 22" X223w LCD Monitor
Need Acer S201HL driver for Apple's Mavericks
MAC is not supported by Acer on this product...
Apr 09, 2014 | Acer S201HL Monitor
No signal
Press the Function Button to open the short cut menu. Locate the Input graphic and press the button for it. Each time you press the button, it will cycle between DVI and VGA input jacks. Allow a few seconds for the display to switch inputs. Make sure that cable is connected securely to the associated jack in the back of the monitor and the computer (or other source). If either VGA or DVI input is selected ,but the VGA and DVI cables are not connected, a floating dialog box indicates:
"No Cable Connect" or "No Signal"
Your manual can be viewed here:
http://www.manualslib.com/manual/268264/Acer-S201hl.html#manual
Apr 07, 2014 | Acer S201HL BD Refurbished LCD Monitor
Acer S201HL turns on but no picture only black screen
If is your monitor LCD please try to verify if your display works with other inverter (verify CCFL lamps).
Mar 21, 2014 | Acer S201HL Monitor
Pavilion 22bw does it have built in speakers?
Troubleshooting Sound Problems with Monitor Speakers
Not all monitors come with built-in speakers. If your monitor does not have built-in speakers, then you will need to connect an audio cable to an external speaker system to hear sound.
Mar 19, 2013 | Acer V193w LCD Monitor
Acer s201hl
Hi
Try switching the monitor cable with the desktop's and see what happens.Maybe a bad cable.
Feb 25, 2012 | Acer Computers & Internet
Recently, I purchased an Acer H233H LCD Monitor with the HP e9180f Desktop. However, the built-in stereo speakers in the monitor are not working. The sound card in the desktop is fine, as headphones and my...
Jul 25, 2009 | Acer H233H bmid Monitor
No sound through external speakers
Although some monitors have built in speakers, most people have stand alone speakers. If the old monitor had built in speakers and now it is unplugged you won't hear sound. Even if the speaker cable is still plugged into the sound output on the back of your computer, the monitor must be plugged into an electrical outlet to have power.
I'd recommend buying a new set of external speakers if this is the situation.
If you never had speakers built into the monitor then normally changing monitors would make no difference whatever. The only explanation that makes sense under those conditions is that in the process of replacing the monitor, you dislodged the speaker jack from the sound output on the back of the computer.
Make sure your external speakers have electrical power plugged in, the power is on (green light on at least one speaker lights up) and the volume on the speakers is at least half way up.
Unplug the speaker from whatever hole it is plugged into and plug it firmly back in and test sound.
If still no sound other than some static on the speakers, try every single hole on the back of the computer that the jack will fit properly and test for sound.
Let me know if you have further questions.
Honest1abe
Jan 10, 2009 | Acer Computers & Internet
I'm frustrated. Love the picture on my Acer 22" monitor with speakers, but the sound is very poor. I have the volume for the computer turned up, but still can barely hear the sound. What can be done to...
Dec 12, 2008 | Acer V223WBD Monitor
Acer S201HL Monitor Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
