Question about Malber P28 Front Load All-in-One Washer / Dryer
Malber p28 washer door won't open
Washer door will not open
2 Suggested Answers
  • 6277 Answers
SOURCE: malber washer dryer 800 handle
As the handle will have to be replaced I would suggest calling for a service engineer is the only option ;-0(
You will either have to search in telephone directories OR stay on line and search for '(make) washer service' for instance or '(make) washer spares' and hope that you can find someone reasonably local.
Sorry and good luck.
John C
Posted on Mar 25, 2011
Malber WD2000 door won't open
Malbers use a thermal (heat acting) latch to hold the door closed, so it stays latched for about 2 mins after being turned off. This is to give you time to think before you open the door and possibly spill water all over your feet. When the little bi-metallic piece cools off, it bends to one side (inside the latch assy) releasing the catch, and the door can be opened. Sometimes, the bi-metallic part bends OK, but the latch catches and won't release. It just needs a little vibration to free it up. A smack to the latch area (on door or face of Washer) will free the latch.
I tell my customers: Don't pull too ******* the white door handle. If you can't open it with your little finger (seriously) it's not ready to open!
Nov 14, 2013 | Malber WD2000 Front Load Washer / Dryer
My malber wd2000 door won't open
Malbers use a thermal (heat acting) latch to hold the door closed, so it stays latched for about 2 mins after being turned off. This is to give you time to think before you open the door and possibly spill water all over your feet. When the little bi-metallic piece cools off, it bends to one side (inside the latch assy) releasing the catch, and the door can be opened. Sometimes, the bi-metallic part bends OK, but the latch catches and won\'t release. It just needs a little vibration to free it up. A smack to the latch area (on door or face of Washer) will free the latch.
I tell my customers: Don\'t pull too hard on the white door handle. If you can\'t open it with your little finger (seriously) it\'s not ready to open!
Malber P28 washer. On hot water cycle the drum is part filling with water then stopping wash cycle and door is unlocking. I was able to open the front loading door with the drum half full of water - gushed...
Sounds like a control pcb malfunction. Remember that you are dealing with MAINS Voltages which can be lethal.
Never continue to use a machine that floods or enables random water release for any reason. The end result might be Electrocution, and it is certainly not worth that risk
Poppa
http://www.cdbaby.com/cd/poppamadison
Oct 04, 2013 | Malber P28 Front Load All-in-One Washer /...
Broke the door handle on malber wd 1000? Do they sell the handle or door?
Sorry to see this 16 months too late.
You can find Malber Distribution Corp online, or call them at 516-323-5299. Tell them Mike, in DC, says hi.
Oct 30, 2012 | Malber WD1000 Front Load Washer/Dryer
Malber combo doesn't start
This problem is usually the front door latch "interlock" is not engaging. This is the safety device which keeps you from opening the door and pouring gallons of water on your feet. When you close the door, if the machine DOESN'T recognize it's closed - all electricity is cut off and the machine does nothing. If the machine DOES recognize the door is latched, the latch will lock and you can't open the door (for about 90 secs after you turn it off or unplug it). Does the door LOCK when it's closed? If not, just close it harder several times. A medium "slam" almost always takes care of a "sticky" interlock - and it doesn't hurt anything.
Aug 01, 2012 | Malber WD1000 Front Load Washer/Dryer
Water leaks on floor from my p25 washer.
This is a common problem with Malber. On the lower right hand corner, there's a door with a lint filter. This filter needs to be cleaned on a regular basis. Be careful when removing the filter. It has a large rubber gasket that expands when it's installed and tightened and will offer some resistance when removing. When the filter becomes clogged, water backs up and forces it's way out through the filter.
Aug 31, 2011 | Malber P25 Front Load Washer
Malber washer dryer 800 handle broke. cant open door
John C
Mar 25, 2011 | Malber Washing Machines
Hi, How do I open the door on a Malber wd1000 when is it stuck after the cycle is over?
Some machines require it to be empty of water to allow the door to open.Try dropping the drain hose low into a bucket to allow it to open, then clean the filter as it may be blocked causing this problem... Good luck
Feb 10, 2011 | Malber WD1000 Front Load Washer/Dryer
Malber P21 works 3 times slower than normal; I am afraid it will just stop.
I have a Malber P21 the door was open and not turned on and it filled with water till it overflowed onto floor....any ideas?
Dec 02, 2008 | Malber P21 Front Load Washer
Malber P28 Front Load All-in-One Washer / Dryer Logo
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
