Question about Sylvania 6419TC 19" TV
TV WONT COME ON
WHEN I PRESS THE ON BUTTON IT STARTS UP AND THEN TURN RIGHT OFF
    Problem Solver:
  • 11 Answers
My Sylvania 32" tv does the same. Flash of vertical signal, then off. That solution from CompuGuy44 is like saying "that means it's broke". How about a real solution, anyone?
Posted on Sep 09, 2007
  • 432 Answers
This is a fairly easy fix, but I recommend taking to a qualified service tech. Even with the TV off and unplugged you can still get seriously hurt.
Posted on Jun 24, 2007
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
Tx-26lxd70a tv wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 12, 2012 | Computers & Internet
My tv wont turn on and its beeping
Unplug the set, press power and hold for 60 seconds, let it sit for 30 minutes and plug the TV back in, try to power on, if no change! the problem is power supply or high voltage issue.
Mar 21, 2012 | Televison & Video
Cant turn on set and remote wont work, how can I reset tv and remote to work after our grandchildren locked the fromt buttons ans remote?
hello it sound like the key lock has been activated
The TV can be set up so that it can only be operated with
the remote control.
This feature can be used to prevent unauthorized viewing.
This TV is programmed to remember which option it was
last set to even if you turn the TV off.
Press the MENU button on the remote
control, then use the UP/DOWN arrow
button to select the Special menu.
Press the RIGHT arrow button to activate
the Special menu.
Use the UP/DOWN arrow button to
choose Key lock, then press the RIGHT
arrow button.
Use the UP/DOWN arrow button to select
On or Off.
Press EXIT button to save and return to
TV viewing or press the MENU button to
save and return to the previous menu.
the remote control.
Language
Main Source
PIP Source
Captions
Caption/Text
ARC
Key lock G
Auto Convergence
Auto Move
F Back Next G
SETUP
VIIDEO
AUDIIO
TIIME
LOCK
SPECIIAL
On
Off
With the KEY LOCK ON, the display
'KEY LOCK' appears on the screen if
any button on the front panel is
pressed while viewing the TV.
which option it was last set to
even if you turn the TV off. good luck
regards
shaun
Dec 12, 2010 | Zenith R56W36 56" Rear Projection...
My sony trinitron tv wont turn on. it blinks 4 times on standby. what do i do
Try a reset:
  1. Turn on the television.
  2. On the TV remote control, press and hold either the RESET or UP ARROW button.
  3. While holding the RESET or UP ARROW button, press and release the POWER button on the front of the TV. NOTE: The TV will turn off and then back on.
  4. Release the RESET or UP ARROW button.
If that doesnt solve it, you will need a repair.
Aug 10, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Akai TV wont turn on right
this could be the power supply board
May 13, 2010 | Akai LCT2715 27 in. LCD Television
View timer keeps blinking..tv wont turn on.nobody set view timer..is there a reset button? tried to unplug but no luck
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons need to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterward!)
Apr 14, 2010 | Sharp 55R-WP4H 55" Rear Projection...
Polaroid TV Code
About the only thing you can do is do a code search. If it doesn't show up then, the remote does not have it (as with most tv/dvd or tv/vcr combos).
Turn the TV on manually. Then, push the switch at the top to the far right (to the TV position). Simultaneously press and hold the MUTE and SELECT buttons until the TV light at the top flashes. Release the buttons, then press and release 9, 9, 1. The TV button should flash again.
Press and release the 1 button again, then press and release the TV POWER button. Press and release the Channel UP button about once a second until the TV turns itself off. Press and release the select button, and you should be good to go.
If after a while, the TV button starts flashing rapidly, then there are no more codes to search, and the remote does not have the code, and you are stuck using 2 remotes..
Hope this helps...
Jan 07, 2009 | Polaroid 4226TLMB 42 in. LCD TV
ESA ET413E LOST INSTRUCTION MANUAL, NO SELECT KEY!
when picture is displayed on your tv after pressing menu,press the channel up/down button on the remote or tv. there can also be a button that shifts right to left. this may hilight the the settings you want to change. if the up/down button scrolled you thru the settings, then the right/left buttons should change the settings.
hope it works
wg
Jan 27, 2008 | ESA ET413E 13" TV
Sylvania 6419TC 19" TV Logo
102 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
