Question about HP TouchSmart IQ504 PC
Startup freezes and sleeps for 5-10 minutes
Computer goes to sleep mode when left for a short time. Hard to restart and take up to 15 minutes to activate.
  • HP Master
  • 32,281 Answers
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Posted on Jan 01, 2013
Coldcut
  • 1554 Answers
SOURCE: samsung SENS R65 LAPTOP
look at the screen held in a bright light at an angle do you see the desktop dimly .
if not try the function monitor key,
connect an ext monitor to verify the video card is working ,fn monitor .
if you see the desktop dimly then the inverter may be out or the lamps.
Posted on Apr 26, 2008
SOURCE: sleep mode troubleshoot
diver sound instaletion
Posted on Sep 17, 2008
SOURCE: Compaq Presario V2000 Screen went black
I know this is stupied but I had the same problem and it is fixed now - here goes techies - I called HP and of course they were giving me the story out of warrenty - i could pay to talk to them and all the other stuff. They had no clue and neither did I. However in the discussion i had to give them the model number "turned the thing over to find it" When i opened it and tried again it worked. I then moved it and had the same problem - once again turned it over and it worked. I have no clue what I did but I am going to take it in to have it looked at. Can someone tell me what happened?
Posted on Jul 27, 2009
Katwal
  • 129 Answers
SOURCE: blank screen after monitor sleep just blue flashing light
First of all you can change the Power Settings in Control Panel. You can configure as you need. I mean after how much wait it should go for sleep n all.
If it takes 5 min. to wakeup that means you have so many applications running that system cannot manage or RAM is small.
The final solution just remove the Display drivers and reinstall it.
After removing please restart the system once to proceed further
Posted on Aug 03, 2009
  • 136 Answers
SOURCE: i did a hard disk self test and it said #10008 replace hard disk.
there is some problem in your Hard disk.
You can defragment all drives.
if the problem still there, you can try to format your disk.
Posted on Sep 24, 2009
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Windows sleep mode problems
Dec 21, 2012 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
Screen goes blank after a few minutes
POWER OPTION
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
POWER OPTION
-set display to never
Restart pc
Jul 14, 2010 | Dell Inspiron 1318 Notebook
Computer goes into sleep mode, proper way to get out, besides shuting down and restarting
The usual way to get a computer out of sleep mode is to either hit the return key, the space bar or the on/off button.
Sleep mode can be a nuisance at the best of times so i would recommend going into power options and disable sleep mode.
Regards.
Jun 28, 2010 | Compaq Computers & Internet
4350 nosiy while in sleep mode
If it comes out of "sleep mode" every 10 minutes, and you haven't touched the printer or sent any data to the printer, try unplugging the LAN cable for 15 minutes. If the printer stays in "sleep mode"either the formatter is bad or whatever is on the other end of the LAN cable could be bad. If you can put the printer on another PC to see what happens, that would really help you out.
Jun 19, 2010 | HP LaserJet 4350 Printer
Camera goes to sleep too quickly...is there a way to adjust?
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation after 3 minutes when the camera is turned on (when the lens cover is open and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode. Operate the zoom button or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left on for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 20, 2009 | Olympus ? 1030SW Digital Camera
Power saving mode knocks the computer out, have to restart
I have an LG Flatron 19" black w1952TQ that I bought on 2 Apr 2008; when it goes into sleep mode, will not recover. Did the online troubleshooting, reseting things, unplugging/replugging all cables, nothing works except restarting the computer, and that only works until it sleeps... Read more
Aug 05, 2008 | LG Computers & Internet
HP TouchSmart IQ504 PC Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
