Question about LG RH177 DVD Recorder/HDD Recorder
Lg dvd drawer opens by itself and wont stay closed
Hi, my lg rh277h dvd recorder and hard drive has started to eject the dvd drawer by itself and wont stay closed. you close it, it stays closed for a second or two, then ejects. when i turn the unit of, it powers down and then ejects the drawer. it now wont play dvd's as it wont stay closed. only 18 months old. frustrating and very disapointing. any ideas?
  • 2 more comments
  • Anonymous Feb 01, 2009
    same - the machine powers on and  off by itself too...
    very annoying - if you keep opening and closing it will play a dvd once it starts reading... i have a different model and it started happening after 5 years
  • sslatha Feb 16, 2009
    hi, my lg rh277h dvd player drive has started to eject the dvd drawer by itself and wont stay closed. you close it, it stays closed for a second or two, then ejects. when i turn the unit of, it powers down and then ejects the drawer. it now wont play dvd's as it wont stay closed. only 18 months old. frustrating and very disapointing. any ideas?
  • Anonymous Apr 04, 2009
    Sam problem, only 2 years old and constantly ejects all dvds
  • Anonymous May 25, 2009
    Same problem here.
    http://www.ifndef.altervista.org/index_e...
    This worked a treat
I tried the solution documented at
http://www.ifndef.altervista.org/index_eng.html
3:rd Loader repairing
Posted on Jan 28, 2009
  • Cyber_Nick Oct 15, 2010
    Really good solution Thanks
  • Mike Carter
    Mike Carter Nov 30, 2013
    no solution in that link!
  • 4 Answers
The solution given WORKS a treat. Took 15 minutes.
Posted on Mar 20, 2009
The link DOES solve the problem. Worked for me even with another LG model number not listed there. Thanks!!! :)
Posted on Jul 06, 2010
This soloution worked perfectly for my HR352SC - many thanks!
Posted on May 19, 2012
Hi. I own an lg drt389h dvd recorder. disk drawer opens by itself and won't stay closed
Ever heard of Sellotape? Cloth tape's even better. If it must be black electrical tape will do nicely.
Now FIX IT and get on with your life. :-)
Apr 01, 2011 | Televison & Video
DVD DRAWER won't open
OK.
I assume the display does not say 'locked' when you press eject.
A DVD drawer is run by a small rubber belt on most of these old machines. This belt can be worn out (Very common)
The DVD drawer position is detected by a switch that can be pressed in or out to detect the drawer is closed or open. This switch can cause the drawer to stay in if it thinks the drawer is not yet closed. Cleaning the switch (Take the DVD drive out and remove and clean or replace the switch) can usually fix this.
A fault with the DVD process cicuit board can also cause this. I would recommend a new machine if this is the case.
Testing:
Bad belt - the DVD drawer shifts a bit when the eject button is pressed.
Bad switch - a whirring sound can always be heard when the DVD is first powered on. May give an error in the display.
Bad process board - Generally, says open forever or close forever and will not change back to normal display. You cannot get any other functions to work after you press eject. Unplug the machine, its normal until you press eject again. (just a generic common thing)
Mar 22, 2010 | Sansui VRDVD5000 DVD Recorder/VCR
LG RH1757 (80 GB) DVD Recorder / HDD Recorder Drawer keeps opening Drawer keeps opening and closing and won't read discs! Rassie from Cape Town South Africa
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Mar 16, 2010 | LG RH177 DVD Recorder/HDD Recorder
Sony DVD RW DRU-820A
HI,
Double check the Ribbon Cable Connector is installed Correctly ( 40-80 Strand IDE ) sometimes if these are not fitted squarely Or pushed in hard enough. Can cause a Problem.
Also try the emergency eject procedure on The Drive. Small jewellers screwdriver Or Needle, insert into the drives faceplate ( pinhole in drives faceplate drawer ) push to open dvd drawer. pull out drawer Gently. And push back in. This ocassionally works for a stcking Drawer/eject mechanism.
Finally try the drive without a disk in ( open/eject Or Close )
Mike @ Compurepair.
Jul 01, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
Keeps ejecting dvd
Does it also do this without a DVD in the drawer? Does the drawer open even when it's empty or only when it has a DVD on the tray?
Allen
Jun 04, 2008 | RCA DRC8320 DVD Recorder/VCR
Troubleshooting with the LG HDD/DVD recorder RH277H
Takes about 15 minutes and its works.
Mar 02, 2008 | Televison & Video
LG DVD recorder/VCR Combo problems
you need to replace the dvd loader(the whole setup, the draw/tray,laser sled assy ,etc) statewide sell
parts for lg.unless you know an authorised lg repair agent.too bad you dont know me, lol.
(ps,its not in the manual,cuz there is nothing you can really do about it without serviceing the unit)
Feb 18, 2008 | LG RC199H DVD Recorder/VCR
LG RH277H - won't play bought DVD'S
The cd tray eject after put in the DVD movies, but VCD working fine...it is means that the drive's region code haven't set yet .(please refer to user manual to setting the region code) ..or unplug the recorder drive from the dvd player,using the computer setting to change the region code by connecting to computer's IDE cable .
Oct 19, 2007 | LG RH177 DVD Recorder/HDD Recorder
Akai DVD recorder tray will not open
I am pursuing the exact problem above. I have found a not so hi tech solution. I firmly rap on the top above the disc drawer. This is while Close is being displayed and the drawer is in. If you hear some spinning and load displays it should now work. It may be back to cycling again on the next ejection though.
Technically I figure it may be a sticky magnetic reed switch or what ever they use to detect the drawer position. Mine displays either open or close when it starts to cycle.
Aug 08, 2006 | Akai DVDRW120 DVD Recorder
LG RH177 DVD Recorder/HDD Recorder Logo
2,599 people viewed this question
Computer Repairing
Computer Repairing
