Question about Fuji FinePix E510 Digital Camera
Fuji finepix e510 won't turn on
Tried new batteries & usb connection
depress on burn, rcv green lite, lite goes off, len does not open, camera does not turn on
  • 4 Answers
If your Fuji e510 battery system is like the Finepix S3000 or the S3100 take a look at the following postings: Finepix S3100 (Camera power does not come on...) by banobo of Feb 07,2008 and check out solutions #2 & #4, (Mine is #4), Also see posting by "tomawamba for Fuji S3000" and my slightly differently worded solution.(Only one posted). May be best to get camera working before connecting with anything else. Good luck, be patient.
Posted on Jan 18, 2009
Battery charging shows quick green light
Ill try to help you, I think the slow flashing green lite is when you first plug it in the longer its on it will flash quickly when almost finished mine blinks untill full then stays on try to wear your battery all the way down then try to charge again good luck
Mar 24, 2014 | Nikon COOLPIX L19 Digital Camera
Can't open the lens and it's always low battery
It would appear to be the battery or the battery contacts. Clean the contacts on the battery and recharge the battery. If still does not charge then get a new battery
Dec 17, 2013 | Olympus Sz-12 14mp Wide-angle With 24x...
I have a HP camera CW450t camera and cannot turn it on with the power button on top. I know the batteries are good because I can turn on the camera with the review button and review the pictures that I...
I had the exact same problem. What I found out was that certain types of batteries have more power to power the camera and make sure the batteries are brand new because they might have been sitting in your cabinet or where ever and run out of power and not be able to open the lens or turn the power on, and the manual (disk) that came with the camera says not to take the batteries out if the camera's on and if your lens isn't opening properly it's because your batteries are low on power. Well I hope I helped. Bye.
Dec 27, 2010 | HP Cameras
I have a kodak easyshare c533 camera and it won't turn on. I tried new batteries but all it does is flash the green light. Any ways to fix this?
Green light flashed, turned red, lens would not open. Put in new rechargeable batteries, still nothing. Someone here suggested to try regular AA cheapie batteries. IT WORKED!
Nov 09, 2010 | Kodak EasyShare C533 Digital Camera
Camera turns on then off immediately
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Nov 04, 2009 | Kodak Easyshare M893 Digital Camera
Err 99
Although you may have cleaned the lens contacts, did you clean the camera contacts? This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Dec 04, 2007 | Canon EOS-10D Digital Camera
Will not turn on
Sounds like your lens is stuck. Try a gentle tug and it should open all the way. Then you can power your camera down.
Nov 01, 2007 | Samsung Digimax S800 Digital Camera
Camera won't turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.
Hope its helpful to you
Sep 26, 2007 | Samsung Digimax L60 Digital Camera
Camera lens is out, but camera is off
First deconnect all batteries, usb cable anything from the camera. Leave it for about 1 hour and then without connecting batteries press and keep the the power button pressed for about 1min. Then press twice on every other button including the shuter, zoom or stuff like that. This should reset a microcontroller that remembers the last operation done. This doesn't reset the camera. After this, connect the batteries and try to power it again. IF this doesn't work. Try to push the lens back in using your fingers. Don't force them to much if they doesn't appear to go back. Use 2 fingers to press on the lens one on each side aplying equal pressure. You may hear a click noise when the lents start to go back. Again, don't force them to much. Try these at first and then if they doesn't work, please post back and specify what does the camera do. No led's no nothing or ..?
Mar 13, 2007 | Nikon Coolpix 3200 Digital Camera
Fuji FinePix E510 Digital Camera Logo
434 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
