Question about Garden
Where is the fill cap for Hyrdaulic fluid in the Deere 5325?
Where3 do you put in hydraulic fluid in the John Deere 5325 tractor?
ButtFuzz
  • 463 Answers
SOURCE: IJohn Deere whinning noise
Is the device that lowers or raises the loader a hydraulic piston type device, or more of a hydrostatic type device? Whining noises are not uncommon with hydrostatic devices...
Posted on Mar 26, 2009
blueextc3221
  • 15935 Answers
SOURCE: system creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 19, 2009
SOURCE: John Deere 1020 Weak 3 point hydraulics
I would suggest you find a JD dealer and buy a manual if you want to do the maintenance yourself. You can also do a Google search and find manuals.
I would also suggest you completely drain the old hydraulic fluid and replace it with new fluid and a new filter if it has not been serviced any time in the recent past.
The symptoms you describe can be low fluid and/or a clogged filter. If you or anyone else has run the tractor too long and it has low fluids and/or a clogged filter, you can damage the hydraulic pump and that can get costly.
Posted on May 01, 2009
mattofilms
  • 110 Answers
SOURCE: I just purchased a 2440 john deere tractor it was
would say that your variable displacement pump has rust or other on/inside, it.
Are you using hydralic fluid (not eng oil) in her?
Can you let it run on blocks for a bit - drain and re-fill transmission?
Posted on Jul 02, 2009
  • 3600 Answers
SOURCE: how to rebuild hydraulic pump on 4440 john deere
This is something that you need to have special tools to rebuild pump, your best bet is buy a rebuilt from a rebuilder manufacture.
Posted on Mar 26, 2010
Where do I add hydraulic fluid to a John Deere 310 B backhoe
There are several places for checking and adding fluid. What seems low, the bucket hydraulics, or the drive hydraulics (ie: tranaxle)
Jul 09, 2016 | John Deere Garden
How do i check my hydaulic fluid for my 445 tractor
JD Mower Maintenance - YouTube
? 16:56
https://www.youtube.com/watch?v=RYeP_QLhsoU
Mar 31, 2013 - Uploaded by GreenMachine757
Doing routine maintenance on my John Deere 757 zero turnmower. ... DIY Mower Seat Repair - Garden Tractor Seat - Zero Turn - eXmark ...
John Deere Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages6/
Service Transmission - John Deere Ag - New Equipmentmanuals.deere.com/cceomview/OMM144042.../OMM144042_D010.ht...DO NOT mix oils. These tractors are equipped with a hydraulic wet disc PTO clutch.... DO NOT use type "F" automatic transmission fluid. John Deere Low ...JD 445 Rider Mower Issues - Need Help Please - GardenWebforums2.gardenweb.com > Garden Forums > TractorsNov 12, 2009 - But I've read a lot of threads hoping to read about my issues, and was ...What tools I don't have my friends do, and both are real mechanics, big Deere fans ....it steer hard due to lack of fluid in the hydraulic steering cylinder. ... You may need to add fluid, run the tractor around a bit, and then check it again.
Jan 09, 2016 | John Deere Garden
Where do I put the hydrolic fluid in a John Deere 755 tractor?
yvCTPtnpOroaDOyyi9dZt5aw7XkS2RQ">
Little yellow plug is the hydraulic oil fill plug.
Jul 22, 2014 | Garden
Where is the hydraulic oil resivore on a John Deere 420 garden tractor?
Its the transmission itsef, you fill it from under the hood between battery and steering console. Its a little black cap that lifts off tube.
Jun 20, 2011 | John Deere 420,1020,2010,2020,2510,2520...
Where's the hydraulic oil fill for a John Deere 3020? Is it next the seat? What's the hydraulic system oil capacity? What type hydraulic oill would you suggest?
The oil fill cap is just above the oil dipstick at rear of tractor.
the capacity of the system is 4.5 gallons.
Oct 08, 2010 | John Deere Garden
John deere 84 410B turbo, wont drive up an incline
Try changeing the hydrolic and transmission filters,also recheck the fluid level.Check the fluid level with all cylinders retracted and if it is overfull then drain it to the top of the full line.
Dec 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
I need to know where to add hydraulic fluid in a John Deere 2010
... should be between operators seat and 3rd link arm. A large nut/cap on top of the transmission cover, near the rockshaft of the 3-point hitch arms.
Nov 04, 2009 | John Deere 4000 201000-> Gas & Diesel...
I just purchased a 2440 john deere tractor it was outside for some time so there was H2O in the hydraulic fluid. I changed fluid but I get very little movement from the tractor when I release the clutch. I...
Apr 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
