Question about Ovens
Kenmore Wall Oven Model 91147465791
Oven heats up then shows error code F 10 any ideas as to what is bad.
jyackle5
  • 8197 Answers
SOURCE: Kenmore wall oven (model 911.41065690). Works fine
The F7 error code on your oven indicates the touch pad has failed. To repair it you will need to replace the touch pad which is listed as a control panel w/keypad in the parts diagram.
If you do the repair yourself, disconnect the power to the oven. Take the 3 screws out above the door that hold the control panel on to the oven. Pull the control panel out at the bottom and lift it up, then pull out the top and drop it down so you can see the back side of the control panel, and you will see a ribbon connector going from the touchpad to the electronic oven control (ERC).
There is a latch holding the ribbon connector to the ERC, raise the latch to release and pull the ribbon out of the ERC.
Replace the part and reverse these instructions to replace the control panel.
good luck
Posted on Sep 30, 2009
  • 30 Answers
SOURCE: error code f7 on Kenmore wall oven 911.41165791
Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
Posted on Nov 08, 2009
  • 30 Answers
There is a probelm with the control panel. You can fix it for about a penny. The panel has a printed ribbon cable that plugs into the relay board. The ribbon cable is actually two cables pressed together, which can be seperated by simply lifting them apart. The ribbon cable has a defect in that the plasic insulation is defective, causing the leads between the two ribbons to cross, or short circuit. Simply place a thin sheet of paper between them, and make sure you push the paper down all of the way to the plastic housing, fold over the edges around the cable, you are done.
  • 30 Answers
SOURCE: Kenmore oven keeps beeping, shows F7 on display.
Please, don't replace anything before trying this first! The insulation in the ribbon cable is poor, so the conductors in the cable become crossed. The ribbon cable is actually two ribbons pressed together, and the conductors between the two cables are shorting or becomming crossed. Lift the two cables apart, place a piece of paper between them, fold the edges of the paper over the cable so that it does not slip out, and make sure to shove it all the way down to where it will meet the plastic display panel housing. There, problem solved, and you didn't have to buy new parts.
Posted on Dec 08, 2009
SOURCE: kenmore wall oven keeps showing error codes f5 and f3
oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
Posted on Jan 12, 2010
Why kenmore oven code f-10 comes on when bake or broil is on
I would first pull your range out from the wall, unplug your range, then take off the back access panel and ohm your oven sensor.
It should ohm out at 1100 ohms at room temperature.
If that checks good, then your control board is the problem.
Here's the oven sensor probe for your model:
Part#316217001show?id=yo6223wzsty&bids=122738.613159039&type=10&subid=
yNjEzL0lDVy9zb3RvaHB0cmFwLw%3d%3d">
Here's your control board:
Part#316418208show?id=yo6223wzsty&bids=122738.582384825&type=10&subid=
0NjEzL0lDVy9zb3RvaHB0cmFwLw%3d%3d">
Aug 20, 2014 | Ovens
Flashing PF 32 error code
Hello - This manufacturer does not show to have such an error code for a wall oven. However the error codes F30/F31 indicates that the unit either has an issue with the oven sensor, wiring with the EOC or the probe connections is open or shorted. Contact a professional to move forward accurately.
Nov 10, 2012 | Frigidaire 30 in. Electric Gallery Series...
Shortly after pressing the Bake button it starts beeping and F3 shows on screen. In the past, it would do this a couple times and then begin to heat and be fine. Othertimes, it would just stop cooking in...
F3 error code is telling you the oven temperature sensor has failed on the oven. You can access the oven sensor from inside the oven. The sensor is a stainless steel probe about 1/4 inch in diameter and several inches long. Disconnect the power to the oven and remove the screws that secure the probe to the rear oven wall and you can usually pull it into the oven.
Jan 19, 2011 | Kenmore Ovens
Error message f4 fan lt electric double oven model 49425 & 49429
Every fault code I am able to find concerning F-4 period has to do with bad oven sensor. This is the probe coming through the wall inside the oven to read oven temp and to regulate it. Hope this helps. Rick
Mar 04, 2010 | Ovens
Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
Ovens Logo
99 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
