Question about Kenmore Washing Machines
Kenmore Elite: Won't complete cycle
Our washer gave us the f-02 code. We knew it was the pump, took it out, was full of gunk (I mean full). Cleaned it out, didn't work, still got the code. Bought a new pump, installed it. At first it would begin to fill the drum without agitating and then would go right to trying to pump out water, would keep pumping forever until it gave the same f-02 code. Cleaned out the water lines (thought they might be plugged) same thing. It wouldn't agitate. Unplugged the machine to reset, started over, got it to agitate, went all the way through until 20 minutes left, pumps out the water but won't spin. Pumps until you get the f-02 code again. Is this an electrical/computer issue?
  • 15,935 Answers
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Error code f 02
I think it's a slow drain fault. But would need full model number to say for sure. Still it wouldn't hurt to check the drain pump for crud. Here are some vids that might help. Don't worry too much about brand specifics. Many brands share identical and similar parts.
http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump+cleaning&oq=Kenmore+Elite+Front+Load+Washer+drain+pump+clean&gs_l=youtube.1.0.33i21l2.425000.427123.0.432800.6.6.0.0.0.0.410.1517.2-5j0j1.6.0...0.0...1ac.1.lQhVllMwg9M
Jan 27, 2013 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer won't drain
What is the model number of your washer? This condition is caused by a bad lid switch.
Aug 13, 2012 | Kenmore Washing Machines
I have a kennmore elite front loader washer and have taken off the front bottom cover and cleaned out the drain (a pen, some coins and a clear ball) I took the hose off completely by loosening the coil...
try unplugging it and lkeave it unplugged for at least hour that should reset it ,sud of course refers to low water flow into pump but i am sure that has been resolved
Jul 20, 2011 | Kenmore Elite 45986 Front Load Washer
F 02 I reset it to drain and spin for the first load. already took the bottom panel off and cleaned out the white container. still not working for the second load, still flashing F02.
f02 means long drain. something is stopping it from draining. takes the pump out and look in at the impeller, something could be caught in it
Feb 06, 2010 | Kenmore Elite 45986 Front Load Washer
My washer gives me a 02 F error code and does not spin the water complete the cycle. It just freezes
"F/02" Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Oct 24, 2009 | Kenmore Elite HE5t Washer
Kenmore elite washer drain problem
Mar 23, 2009 | Kenmore Elite 45986 Front Load Washer
Washer won't spin- flashing "f 02"
in the HE3 series it means the drain tube or pump is clogged
Mar 02, 2009 | Kenmore Elite 45986 Front Load Washer
Washer stops mid cycle and displays F 02 error code.
it means that your pump is clogged you need to take that bottom panel off the washer and twist the white cap slowly so it can drain put plenty of towels down once it is done draining pull the cap and clean the trap behind it
Dec 25, 2008 | Kenmore Elite 45986 Front Load Washer
Washer does not drain completely.
I'm not sure if this is the same model as our but I will let you know ours did not drain all the way and kept stopping, not completing the cycle. We found that if you take the bottom of the front of the washer panel off thre is a circular looking thing, it happens to be a trap for waste, sort of like the dryers lint catcher. Make sure you put something under it befor you loosen the cap water will come out. When we took the cap off, it was filled with gunk and we cleaned it out and the problem was solved!!!! Amazing because we tried everything , called everyone and not one person even mentioned we had a trap in the washer... It should be right in the center when you take the front lower panel off.. Good luck and let us know if it works for you..
Sincerely,
Mac077@sbcglobal.net
Jan 28, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis won't complete the cycle
reachin and pick up wash basket spin clock wise and drop down it is not seeding into splines
Aug 07, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
91 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
