Question about Coleman Heating & Cooling
Coleman 3120-751 manual
Need a service manual for this unit. My immediate need is the replacement filter size.
farfield
  • 462 Answers
SOURCE: I have an old 1985-86 coleman central heat and air need manual
The filter is located before the blower if your Coleman is in a mobile home it will be in the door facing. If it is a standard ac/heat application and a regular residential furnace the blower in the cabinet on down flow (ducts in floor) will be above it and possible in the duct connecting in the top. If its the other way (ducts in ceiling) it could be right under the blower. Either of these could have a filter cabinet on the furnace or could have a filter grille at the end of the return air duct (where the air is sucked in).
Posted on Mar 10, 2009
  • 744 Answers
SOURCE: replacing filter on coleman furnace L8T
The bottom panel should either pop out of lift up. They can get a little stuck so you may need to use a screwdriver or similar tool. As long we''re talking about these units, see this link:
http://www.recall-warnings.com/cpsc-content-01-01523.html
Safety first!
Posted on Mar 28, 2009
co7196
  • 3433 Answers
SOURCE: I HAVE A COLEMAN AC CANNOT FIND FILTERS TO FIT
yOU CAN PURCHASE FILTER MATTING AT ANY HARDWARE store and cut to size. Its cheaper anyway.. It comes in rolls.
Posted on Jun 10, 2009
SOURCE: need a manual for Coleman furnace
how do I hookup my Coleman Sedona refrigerator to the propane?
Posted on Jul 01, 2009
savindude
  • 175 Answers
SOURCE: I need a repair/owner's manual for 1999 Coleman
Tried googling Coleman? They might be able to help.
Posted on Jul 02, 2009
What size filters do I need for a coleman 7900 series furnace?
the filter is held in with wire "clips" RV stores carry the media and cut to size.
Jan 02, 2018 | Coleman Heating & Cooling
How do I change the filter on a coleman 3400-815?
1.) Turn off the power to the furnace at the service switch
2.) Remove the service panel
3.) On the bottom right side is a cover plate, remove it to reveal the filter.
4.) Pull the filter out carefully and replace it with the exact same size which I believe is 14 X 20 X 1.
Filters can be bought at any blue or orange box store; hardware store;l or HVAC supply house.
To replace everything, just follow the procedure in reverse and remember to turn the service switch back on when you are done or you may find yourself scratching your head trying to figure out why it's not working!
Jan 18, 2017 | Coleman Heating & Cooling
How can I find the model number for the fan. I have a 1999 avion with a coleman mach air the fan makes a lot of noise.we oil it but it quit last night and I think it may need replacing.
The model number of you upper unit which can be seen from inside on bottom of unit behind filter etc at ceiling, will give enough info for replacement fan. Here's a good spot to find part #'s etc for your unit.
http://www.rvcomfort.com/rvp/tech_info/manuals.php
Aug 20, 2011 | Coleman Mach III Air Conditioner
Hello , this is Bobby and I have a Coleman Mach rooftop air conditioning unit Model # 8335B8964 when I turn on the unit ,it throws the circuit breaker . I have replaced the starting capacitor and the...
Here's a link to a service manual, with step by step tests to determine whats wrong. I'm thinking compressor shot, but this should confirm, and or help you determine for yourself. Be careful with those capacitors eh !! Read warning in service manual.
http://www.rvcomfort.com/pdf_documents/1976141_copy.pdf
Oct 19, 2010 | Coleman Mach 15 Air Conditioner
Where can I find a manual for my coleman cam II central air conditioner for a mobile home? I recently purchased the mobile home and would like to know what steps to ntake to make it work at its best. ...
Check the website for Coleman/Intertherm for a manual, you will need the model and serial numbers of the unit. The filters for these typically sit on top of the unit, some come with frames, some lay directly on the coil. If you can't find a manual on the website or by contacting the company, check the yellow pages some towns have a mobile home supply house that would be able to help.
Aug 30, 2010 | Coleman Heating & Cooling
Changing filter on coleman AC located under RV. 2005 Dolphin . I don't know the location of the filter on my Coleman RV AC unit located under the RV. Also, I would like a maintenance and operation manual...
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Aug 22, 2009 | Heating & Cooling
There is not an air filter in the unit and we have just purchased the home with the unit in it. I need to know where the filter goes, Tjis a coleman evcon central air unit
You should be able to open the lower panel on the Central Furnance unit and the filter would go against the side where the main cold air return plenum is located. There is usually either a slot/edge for the filter to slide into, or a set of clips or a wire spring that holds the filter in place, preventing it from getting sucked into the squirel cage blower.
If you want to give Coleman a call at 1-877-726-5362, I'm sure they'd send you a owners manual for your unit so you can see what periodic cleaning and such is needed to keep it working properly.
Hope you found this info helpful. Best Regards!
Aug 05, 2009 | Coleman Heating & Cooling
Jun 05, 2009 | Coleman Propane Forced Air Heater...
Replacing filter on coleman furnace L8T
Safety first!
Mar 28, 2009 | Coleman Heating & Cooling
Mar 10, 2009 | Coleman Heating & Cooling
Heating & Cooling Logo
127 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
