Question about Dishwashers
Water wont drain from dishwasher
I push the cancel/drain button, but the water won't drain out. Could there be a problem with my pipes being frozen?
    Sergeant:
  • 229 Answers
You have to clean out the debris filter at the bottom of the washer tub. It is a plastic filter that can be removed and should be cleaned out periodically also run a bottle of drybright etc.. and it will fix this problem.
Posted on Jan 18, 2009
My Bosch SHU66C02UC dishwasher stopped midcycle with water in the bottom. We checked the fuse and it is fine. I'd rather not pay for a repairman as it is quite expensive.Thank you.
Some suggestions: try pushing the drain/cancel buttons and see if that drains the water; check the filter or trap in the bottom of the dishwasher for blockage; check the hose that links the dishwasher to the under-sink drain pipe for blockage. You could google the model number and find the owners manual, which might have trouble shooting suggestions.
Sep 05, 2017 | Bosch Dishwashers
Dishwasher not draining
The problem is a clog in the hose or the check valve from the drain pump. I will post back shortly with directions to unclog it.
Thanks/Mike
Jan 13, 2008 | Whirlpool 24 in. DU930PWP Built-in...
Dishwasher starts on its own (no house is not haunted). Start resume button flashes
have a service technician in as it appears to be a problem in the program board
could be moisture across the circuit board
Feb 06, 2016 | Maytag MDB7749AWQ Builtin Dishwasher
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
Dishwasher won't drain when cycle is complete. Not even when press on the Cancel/Drain button. Engine starts working (at least sounds like something is going on) but not water goes out to the sink...
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Dishwashers
Frigidaire FDP635RFR3 wont drain.
Theres a drain pump located at the bottom of the unit if you follow the hose from the pump then to the drain if your unit isnt draining you might have to call for service from a technician to have them change your drain pump. If the water is just sitting inside the unit and when u start the unit it should fill with water again.Also if you have a cancel function by pressing this you will make the unit drain if you dont hear anything when u press the cancel button you definetly need a pump
Apr 28, 2010 | Dishwashers
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Bosch dishwasher has standing water doesnt drain out, repair man pushed 2 buttons cancel drain and it drained last month, but happened again today and it wont work for me
Fixed mine very easily... After checking and cleaning the filters by the tub's drain, I checked the air vent atop the sink -- it had a small bit of gunk trapped in the outlet. Cleaned it out, ran a "rinse & hold" cycle and it drained the tub beautifully!
Apr 22, 2009 | Bosch Dishwashers
Dishwashers Logo
77 people viewed this question
Top Dishwashers Experts
