Question about Garden
Stihl 025 bogs down when given gas - Garden
  • 211 Answers
SOURCE: Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
best regards savumihai71
Posted on Feb 14, 2009
SOURCE: Fuel line for Stihl 025 chainsaw
there is a good video on this problem on you tube. should be easy to find.
Posted on Dec 31, 2009
dontbother10
  • 2220 Answers
SOURCE: stihl 025 /ms250 any difference
Answered in clarification.
Posted on Feb 05, 2010
dontbother10
  • 2220 Answers
SOURCE: stihl 025 diagram of parts needed.
Try to get an IPL here:
Stihl USA Contact Us
http://www.stihlusa.com/contact.php
Stihl considers all OE parts, IPLs and Shop manuals proprietary. When they discover an on-line source for any of these they force it be removed. If they tell you no your recourse is to register a complaint. Please do. Then go here, join, post an email address and your need.
ArboristSite Beg for manuals thread (free to join)
http://www.arboristsite.com/showthread.php?t=72322
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 21, 2010
  • 12 Answers
SOURCE: I need to rebuild the carburetor on a Stihl model
I don't have a diagram or the part numbers to the minor and major repair kits, but a Stihl dealer should be able to help. Tell him you need a kit for a ZAMA C1Q type carb. The exploded view should be with the kit.
Posted on Jun 13, 2010
Manual for 025 workshop manual
A workshop manual would have to be requested directly from Stihl.
Jul 29, 2017 | Stihl Garden
Gas vent for Stihl 025
1117 350 5800 Normally available thru the dealers but here is someone on Fleabay that has them.
1117 350 5800 Fuel Tank Vent
Mar 23, 2015 | Stihl Garden
What is the difference in a Stihl 025 chainsaw and a ms025 chainsaw
nothing it's the same . stihl never used the ms back when the 025's were produced. later they changed to calling all their saws ms but the 025 is equivalent to a ms 250 I believe
Sep 28, 2014 | Stihl Garden
Stihl chainsaw problems
Adjust the high speed screw on carb
Install a new spark plug
Use fresh fuel
Aug 05, 2014 | Stihl Garden
Stihl MS250 overheats and burns out engine.
the carb fuel augments mite be set to lean or gas oil mixture not mixed rite
Apr 11, 2014 | Stihl 021 023 025 Ms210 Ms230 Ms250...
Hard pull stihl ms 250
UH OH.......may be engine damage, from over heating or not enough oil in gas.
Dec 22, 2013 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Changed carb on a stihl 025 from a single set screw to a double set screw . what settings do i need to start initially
on the needle setting closest to engine(air) it is turn clockwise till it stops, then open it up counter clockwise 1 turn. The second adjustment needle, should be turned clockwise till it stops, then opened up 1 1/2 turns. Adjust the second or gas, until your engine sounds like it is running it's best.
Dec 06, 2013 | Stihl Chainsaw 42mm Piston Rings 025 O25...
How to remove Stihl 025 muffler?
You need to pull a little harder, lol.
Dec 07, 2011 | Stihl Garden
Stihl 026 chainsaw... bogs down when giving it gas. Removed the breather and helped a little, but still bogs down under a load.
Probably need to adjust the high and low speed settings on the carburetor.
See your owners manual for location and adjustment procedures.
Apr 12, 2011 | Stihl Chainsaw 024 026 Oil Pump
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
