Question about Maytag Dryers
I have a very squeaky Maytag dryer model # LDE312! Does anyone have tips for fixing this issue with this particular make and model?
Maytag dryer model #LDE312
MNTECH
  • 1543 Answers
SOURCE: maytag dryer model lde312 runs
Remove the two phillips screws in the dryer front at ankle hight. Pull front toward you and unhook from top. Leave wires connected. Heating element visible at lower right.
Posted on Dec 01, 2008
  • 326 Answers
SOURCE: squeaky loud noise maytag gas dryer
Maytag dryer - common noise problems: See "how to take apart" first. The most common noise maker is the fan blower, it breaks on the motor shaft and makes a loud "rumbling" noise. Other common trouble makers are the rear rollers and idler pulley, they often can make a screeching noise.
A common noise with Maytag dryers is a rumbling noise that often still rumbles for a few seconds even after the dryer shuts off. This usually a broken fan blower, the inside part of the fan blower has rounded out and the fan blower is free wheeling on the motor shaft = new fan blower time. These pliers help make the repair a little easier...Snap Ring pliers.. From Tools Accessories section... How to take the dryer apart. Part is # 303836 for the mytang models. Maytag fan blower order link
Posted on Jan 13, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Maytag Neptune dryer increasingly loud.
Sounds like you need new drum rollers installed, when they get old they squeak,squeal, and make loud bumping noises.
Posted on Sep 25, 2009
  • 401 Answers
SOURCE: My dryer is squeaky. it's a GE model number
It depends on what is making the squeaking noise. Could be drum bearing, drum slides, tensioner pulley, pr even the leveling legs sometimes squeak.
Posted on Jan 10, 2010
  • 534 Answers
SOURCE: My Maytag model LDE312 dryer heats up but doesn't
Could be a blockage in the exhaust. If the clothes are coming out hot but still damp after the first cycle then there is a blockage in the exhaust in the dryer. This blockage could be where the lint filter is or in the exhaust vent to the outside of the unit. The best thing to do is pull the unit from the wall and access the back panel. Remove the back panel and with a wet/dry vac clear out the inside of the unit. Then check for a lint blockage in the hose that is connected to the back of the dryer. That should have corrected your problem If an element goes out there is no heat at all and I doubt the thermostat would go out like that Maytags are rare to have a thermostat just go out
Hope this helped
Dave
Posted on Mar 21, 2010
Belt came of dyer where does it go
Most maytag dryers you cannot work from the back side. The old style dryer is accesed by removing phillips screws at the base of the dryer. The newer models use a putty knife to realease the top. Some models called slopefronts you remove the door and then the front to get to the innards.
I have a page on maytag dryers which features videos and service manuals. MAYTAG DRYER PAGE
Mar 06, 2012 | Maytag Dryers
Maytag model no: de410 Looking for manual
I need the 6 digit model number from your dryer.
May 28, 2008 | Dryers
Inherted a Maytag dryer Model DE 4000, its noisey when ya start, most likely a bearing or roller,glide or something, is there someplace I can find a manual, and parts diagram, thank you
http://www.repairclinic.com/Maytag-Dryer-Model-DE4000-ID-87208-Parts
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-DE4000/3048/0151200
Jul 18, 2011 | Maytag Dryers
Loud Squeaky Performa Dryer Mod# PDET910AYW. I am guessing I need a rear drum bearing kit, perhaps as well as the felt pad/glide? For some other models, like Frigidaire, it looks like they sell the...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 09, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
When i turn on the dry it is making a loud Squeaky sound. the dry is still heating, just making loud squeaky sound
Hi an welcome to FixYa, I am Kelly.
This squeaky sound your hearing is usually the idler pulley, idler pulley shaft, but also can be the motor or the drum roller bearings. Usually if the drum roller bearings are bad the dryer will thump as it rotates.
The idler pulley and lever is and assembly that is item 8 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194&diagram_id=28598568#d28598568
Since it is squealing at this time when you have the repairs done that you replace the belt that is item 21 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194&diagram_id=28598572#d28598572
The motor is item 7 this link:
I recommend that if you do the repairs that you replace the idler pulley, the drum rollers, and the belt.
Drum rollers are item 17 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194&diagram_id=28598572#d28598572 (make sure to check the drum roller shafts that are item 19 of the same link.)
While repairs are being completed also inspect the drum front and rear seals. Thare are items 14 and 26 (Same part number) of the above link.
By doing all of the above you should be able to get many more years of service out of your dryer.
If you need to purchase a service manual for self repair it can be downloaded here for $9.95:
http://allrepairmanuals.com/maytag-dryer.htm?model_number=MDE308DAYW
Thanks for choosing FixYa,
Kelly
Feb 15, 2011 | Maytag MDE308DAYW Electric Dryer
Very squeaky guessing it may be a belt! also it does not shut off automatically when the clothes are dry. I thought that was a feature of this dryer. Bought it used 2 years ago.
heatman101
Asker
Nov 21, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Squeaky
heatman101
Oct 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag-dryer\model number -- Ldg7304aae
This is the heating element. they are easy to replace by removing the back cover. UNPLUG it from the power source first!! The part is cheap to.
Apr 28, 2010 | Maytag HYE3657A Electric Dryer
My Maytag model LDE312 dryer heats up but doesn't seem to get hot enough. It takes 2 hours or more to dry. Is this a thermostat or heating element problem?
Hope this helped
Dave
Mar 21, 2010 | Dryers
Dryers Logo
44 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
