My problem is national l15 vcr not working properly sometimes problems locked every function and screen display error is ``write`` And no work
Super 4 head function ntsc playback on pal tv
Super nintendo
Original-Style Super NES RF to VCR Hookup
Installation Steps:
Locate the VCR's VHF IN [ANT, CATV, 75S(ohm)] or Cable Connector.
Disconnect the existing cable wire from the VCR's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your VCR's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire from the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the VCR. Note on Sharp TV/VCR Combo
After the system is connected to the VCR:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Slide the Power Switch to the On position.
Turn your TV and VCR on. Set up your TV and VCR the same way you would to watch a movie on the VCR.
The game image should now be displayed on the TV screen. You are ready to play!
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck using the Stereo Audio/Video Cable.
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Feb 10, 2013 | Nintendo Super NES Console
I have a super nintendo and 3 games. I know that the games and cables work, but I have some problems running the games on my system. Each game does not function properly in one way or another. 1. Super...
Well there might now be an internal issue with the console and you will have to buy a new one now from Lukie games or amazon.com or jj games then.
Jun 12, 2011 | Nintendo Super NES Console
Have Whirlpool Electric Range super capacity 465 with accubake system. Turn off power to stove to clean oven and back of stove. Finished cleaning and turned power back on and get this beeping sound every...
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^TF
Sep 24, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Super capacity 465 Whirlpool range . E1 F5 code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.ER%^
Aug 26, 2009 | Whirlpool RF364 Electric Kitchen Range
Can't see "Setup" screen, or any other screens on t.v. monitor
There should be a tv vcr button on the remote control. What you done was you accidently shut off the VCR function. If you hit that button again the tv vcr button it will come back on.
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
Whirlpool stove Super Capacity 465 problem
Hi dcisco,
Happy to help you!
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 23, 2008 | Whirlpool GS460 Gas Kitchen Range
Desktop screen display goes blue
can u boot into the system?if not it can be solved if yes then there is a problem with ur monitor
if u cannot boot intoo the system load default or system restor tht u do ,......savio k frm mumbai savio_k20@yahoo.com let me know if u solved it
cheers
Jul 05, 2008 | HP D2835 17 in. CRT Monitor
No Picture
check out the tip in my profile or use a wet cleaning tape
Mar 31, 2008 | GE 13TVR62 Combo
Error E3 on Mitsubishi HS-U795
Try this :
If your VCR malfunctions, try the following steps prior to contacting your Mitsubishi Dealer:
1 Check the Trouble Checks below to see if there is a solution to the current problem that you are
experiencing.
2 If the problem is not addressed on the Trouble Checks, the safety circuits in the VCR may be in
operation, thus please try the following: (the clock setting and the timer recording will be deleted.)
1 If possible, press EJECT on the front panel and remove the tape.
2 Press TIMER RESET on the rear panel with a pencil or a ball point pen.
3 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, wait about 1 minute
until the tape protecting function is completed, then press POWER.
3 You may also try the following procedure if the above steps did not resolve the problem (All settings will
be reset to the default settings.).
1 Press POWER on the front panel continuously for about 8 seconds until the current time display on
the front panel shows "- : - -."
2 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, the tape protecting
function will work and "99" will appear on the front panel display to begin count down. Wait about 1
minute until it reaches "00" to show the tape protecting function is completed, then press POWER.
If the problem with your VCR persists, contact your Mitsubishi dealer for assistance.
Im looking for error codes.
Mar 10, 2008 | Televison & Video
E1 and f5 error/Door locked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Dec 22, 2007 | KitchenAid KEBC207 Electric Double Oven
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
