Question about Texas Instruments TI-86 Calculator
IT-86 Both batteries removed, now dead
I removed both the double A batteries and the circular battery from my beloved TI-86 calculator. In doing so, I lost all the programs in the calculator, and now it does not work at all.
Is there a way to re-program the calculator? Is there a TI Calculator repair shop? I since bought a TI-89 that I do not like as much as the 86, and someone recently stole it off my desk at school. Ideally, I would like the TI-86 back. It seems there should be a way to reprogram it, and removing batteries should not be the kiss of death.
  • Texas Instru... Master
  • 7,993 Answers
Use the TIconnect or TIGraphlink software to reinstall the programs. You will find the programs in the TI Program archives.
ftp://ftp.ti.com/pub/graph-ti/calc-apps/86/.
Hope it helps
Posted on Sep 23, 2009
How do I reset my TI-86 after a long period of no use.
Every time you change batteries this will happen to you. First press 2nd then press and hold the down arrow. Hold until their is no black in the background but you can still see the numbers on the screen.
Sep 05, 2014 | Texas Instruments TI-86 Calculator
My Ti-86 wont turn on after i change the batteries
This may sound silly but check that you put the batteries in the correct way round for (-) and (+)?
Feb 17, 2012 | Texas Instruments TI-86 Calculator
I've had my ti-86 for a very long time & recently it just quit working. I changed the AAA batteries & the back up battery & it will not come back on. Please help???!!!!
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. Does it?
Dec 02, 2011 | Texas Instruments TI-86 Calculator
I've replaced all the batteries including the backup battery on my TI-86 and it still doesn't power on. I also tried adjusting the contrast.
It sounds like the calculator is broken. Well broken past the point where you can fix it by yourself. You can try contacting TI about the warranty.
Mar 05, 2011 | Texas Instruments TI-86 Calculator
The backup battery went dead and I replaced all the batteries, No response to the on button, Bob E
Sep 27, 2010 | Texas Instruments TI-86 Calculator
Is a watch battery the same as the one used on the TI-86. At Wal-Mart I was given a lithium battery watch CR166
Don't you mean CR1616? The TI-86 can use either the CR1616 or the CR1620 battery. The -20 is slightly thicker than the -16 but there is enough flex in the system to accomodate it.
Jul 08, 2010 | Texas Instruments TI-86 Calculator
I stop using my TI-86 for a few months and know
I hadn't used mine in years and had the same problem. Essentially you just need to give it a workout to get all the pixels working properly again and then it'll be just fine. I adjusted the contrast between full dark and nothing multiple times and turned the calculator on and off after each cycle and now it works like new.
Jul 06, 2010 | Texas Instruments TI-86 Calculator
Blank lines across the screen of a TI-86 graphing calculator
Try this, hook up new battery and go to MODE and darken and lighten the screen.. do it ten to fifteen times. if that doesn't help, try hook up most left and most right's battery terminal to a DC supply at 4.5V. dont go above 4.5 it will fry your calc (it is design to handle 3V). now you are forcing extra juice into the dead LCD screen lines... and reapeat the MODE + darken trick. I fixed mine like that! Works! and remeber to leave it completely black(darkest) for a while to keep that dead line alive!
Jul 06, 2009 | Texas Instruments TI-86 Calculator
A friend gave me a TI-86 graphing Calc. I wont turn on!!!
maybe try changing the small memory battery inside, I think its a cr1616 or cr1620. If this doesn't work use it as a paperweight.
Apr 23, 2009 | Texas Instruments TI-86 Calculator
TI 86
If batteries are inserted correctly you can adjust the contrast
Press [2nd] key and release it
Press and hold [UPArrow] key to darken till contrast is dark enough.
To enlighten screen, do as above but use the [DownArrow] key.
Hope it helps.
Oct 24, 2008 | Texas Instruments TI-86 Calculator
Texas Instruments TI-86 Calculator Logo
272 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
