Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
My Kitchenaid dishwasher not cleaning dishes on top shelf
Does not seem to be getting water to the top shelf to clean the dishes.
  • 4 more comments
  • Anonymous Feb 03, 2009
    I saw the solution -- I tried to clean the jets - this did not make any difference - is there a specific cleaning solution to use. Also how do you clean out the filter on the bottom -- on some dishwashers a filter trap can be removed -- can't find a way to remove it. Any other suggestions -- dishes on bottom shelf get cleaned - nothing happens on the top shelf -- I'm positing the dishes correctly. Thanks in advance for any help.
  • jeb60 Feb 15, 2009
    The dishes on our top rack are consantly covered with soap residue and food particles. The filter and jets are clean, but it appears neither the top sprayer of the middle sprayer are putting out any water
  • yuggster Feb 20, 2009
    I am having the same problem. I have completely removed the spray arms, trays, and the shaft that brings the water up to the upper arm. Cleaned them all and replaced. Still no cleaning on the top shelf. As time goes, it appears it is not cleaning as well on the bottom either.
  • fhsmom Apr 18, 2009
    Same thing, water not getting to the top. I've checked the spray arm, there is no sign of blockage or even residue, but I will try cleaning it. I'll report back here if it does help, though.
  • Anonymous May 22, 2009
    Mine is doing the same thing! Thankfully it is under warranty, so I will call a repair man.
    I did try vinegar..It still doesn't seem to be working right.
  • Anonymous May 24, 2009
    Ive had the same problem twice, both times it was related to the food chopper getting clogged as a result of the plastic coupling between drive and chopper snapping. About $15 for a replacement and it fixes problem.
    Its a bit difficult to replace but if you have time, it can save you $150+
    New Friend:
This is certainly a pressure problem that plagued a large percentage of Kitchenaid/Whirlpool dishwashers in homes, and here is the fix:
My dishwasher was never able to clean dishes well since new, so I took a closer look and found a design problem with the water supply tube on the back wall. There are two holes with rubber flap in the middle of the pipe, but only one is used. The bottom rubber flap is supposed to be closed, however, due to poor design in fitment, the flap will not stay tightly shut, therefore leaking precious water pressure to the mid and upper sprayer. Even the lower sprayer will be weak due to the lack of back-pressure. I took apart the flapper assembly and siliconed the bottom flapper shut, then carefully snapped back the plastic cover assembly, so the rubber will stay properly seated in the poorly designed trim. My dirty dishes come out super clean now even in quick cleanup mode!
Make sure the water supply tube is properly sealed from bottom to top! Very important to have good seal so you get a strong water pressure all the way to the top sprayer.
Posted on Jun 02, 2013
  • 229 Answers
You need to clean the jets on the machine arm with an old toothbrush etc... then clean out the debris filter on the bottom of the tub near the dryer bar. The calcification in the little jet areas causes this problem. This should help.
Posted on Jan 18, 2009
Dishes on top shelf not getting clean
Check your upper wash arm.... check the holes, especially the ones at the end of the arm. Are they possibly clogged with debris or hard water? This is the usual cause of dishes on the top rack not getting clean. The holes at the end of the wash arm are angled to eject the water at an angle to use the reaction to push the wash arm around. If those holes are clogged, then the arm won't rotate, and only those few dishes or glasses right under the arm will get clean, and the remaining 80% of the dishes on the upper rack won't get clean!
Sep 13, 2014 | GE Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes on top shelf not cleaning
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Mar 02, 2010 | KitchenAid 24 in. KUDP01DL Built-in...
My dishwasher will not clean on the top shelf
cheap trick...take a glass and put it on the top rack...right side up run dishwasher for about 4 mins is the glass full with water,no ok than check your drain hose the water is sphion out during wash,,lift it the height of unit..keep me posted
Oct 09, 2009 | Dishwashers
Top rack whisperquiet dishwasher no water
I know this isnt the same model, they dont carry your manual as of yet. But it does have some suggestions to look at on page 17. I had the same problem and I looked really carefully and found my sprayer arm was blocked. I cleaned it out and havent had a problem with it again. I do check it regular now.
Sep 27, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
The dishes on the top shelf does not seem to get clean. Does not appear water is coming out of the top spinning module.
Take out the top spinner and clean it thoroughly with descaler and degreaser / very hot soapy water. Soak it for a while and it will work wonders. Put it back in the machine and it will work like new.
Sep 10, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
There may be something plugging up the arm that sprays over the dishes. And of course, I'm sure you know not to place items like bowls, pots, etc that will block the flow of water from the bottom sprays.
Although the bottom jets do most of the working cleaning the top items, the spray from above is vital. Take the stem pipe leadin from the top to the bottom off and separate the spray arms carefully. If you can, look throgh each end to make sure no deposits are in there.
Another way is to blow compressed air from the center stem down in the water supply unit. If food particles are there you'll see them.
May 14, 2009 | Jenn-Air JDB6510 Built-in Dishwasher
Dishes on top rack don't get clean
The following suggestions will greatly enhance the ability of your dishwasher to clean all of the dishes thoroughly:
1. Rinse all of the food off of the dishes before you put them in the dishwasher.
2. Run the hot water into the sink until it is as hot as it gets before you start the dishwasher.
3. Do not pack the dishes into the dishwasher, just put in a reasonable number without crowding or stacking them on either shelf.
4. Pull the top shelf all the way out to be sure that the water connection at the rear of the top shelf is connected. Sometimes, this connector comes disconnected preventing the water from entering the top spray assembly.
THese things should make a huge difference.
Good luck with this and please rate my answer. Thanks. Joe
Feb 03, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Upper rack dishes not cleaning well
Yes, run an empty load with 1/4 cup vinegar. It sounds like there is mineral build up in the arm. Try to take the arm apart that supplies water to the top rack of the dishwasher. You can soak this in vinegar water once removed.
Jan 20, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Jan 16, 2009 | KitchenAid Dishwashers
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
4,300 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
