Question about Dishwashers
How can I remove the spray arm on GE model GLD2800V00WW dishwasher
The water doesn't drain. I want to clean under the pump housing.
eagle338
  • 4889 Answers
SOURCE: Dishwasher will not spray water from arms
Check for utensils or pot handles that may be hanging below the bottom rack and interfering with motion of spray head.
Clean holes with toothpick.
Check temperature at hot water faucet with meat thermometer. If below 120°F (49°C), turn up thermostat on hot water heater.
Posted on Oct 19, 2007
SOURCE: water not going through spray arms
Have same problem except big motor spins independent of stripped? impeller. tried to reassemble but seems mechanical or adhesive agent misssing from one shaft or the other and the motor spins the impeller (now tight) only to have it slip off again and stop pumping water.
Posted on Feb 04, 2008
SOURCE: dishwasher pump will drain but not force water into spray arms
If the washer is not used regularly the shaft can stick to the seals and prevent the motor from spinning. This happens quite regularly for me if I don't use the washer often. You can just take off the bottom panel - after shutting off power to the dishwasher - and access the motor. you should see some fins and then just try to spin the motor by hand. It usually takes about 90 degrees of rotation before the motor breaks free from the seal. You'll have to fight through the spring-like resistance created by the seal-shaft adhesion. After it breaks free the motor spins freely and you should be all set to go. I haven't found a more permanent fix for this other than running the dishwasher more regularly.
Posted on Feb 09, 2008
SOURCE: frigidaire fdb949gf dishwasher won't spray water from arms
I found on my first dishwasher the arm holes were plugged. I had to clean out each and every hole with a small wire. They would not even turn until I cleaned them God luck.
Posted on Jan 31, 2009
SolutionGuy
  • 331 Answers
SOURCE: water won't come in
Cynthia,
There's a flood/safety switch in the dishwasher. It's there to monitor the water level. It does this by rising as the water rises... if it gets too high, it'll shut the water off.
Open the door and remove the lower rack. You'll see it right there in front. Lift and drop it several times to clear any debris. (In order for the dishwasher to get water, it has to be all the way down.) Now try your dishwasher.
SG
Posted on Mar 27, 2009
How does water actually get into the tub of a GE Model GSD2200G00WW dishwasher and to clean the overflow area how do you get it out I have cover off, down to rubber, got some stuff out, ? filter
First--Water enters the dishwasher through the water inlet valve which is the plastic electric valve that the house plumbing attaches to. On GE's its usually under the left front corner once you remove the small access panel. Power is applied by the the timer during the fill cycle. Second-- there is no other filter down in the area you are trying to clean. To remove that rubber boot/sump area you would need to un-install the dishwasher and remove the motor pump assembly from underneath. Here are a couple of things to check for poor cleaning. 1---internal water level---should be about 1/2 inch at door front edge. If not, that inlet valve may be partially blocked and need replaced. 2---water temp needs to be at least 120 minimum. If not hot enough it will not dissolve soap. 3--- look closely at all the little holes in the spray arms. Pay close attention to the end holes that are used to spray out water like a jet engine and spin the arms. Any blocked holes need to be cleaned with something like a toothpick. 4--- check dishwasher at cycle end. If tub has excessive amount of water left inside you may have a blocked drain hose from dishwasher to house drain system. Remove and clean. A small amount of water in sump area is normal but none u near door.
May 02, 2015 | GE Dishwashers
Tip
How to repair or fix a Dishwasher if it doesn't drain
Dishwasher Doesn’t Drain Following a cycle, a small pool of clean water inside the tub is normal. An excessive amount of water means the pump isn’t pumping water out properly, the drain hose isn’t carrying it to the drain pipe, or the house’s drain lines are backed up.
If dirty water spews from the air gap, the drain line is kinked or clogged. (If you’ve recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made; see your disposer instructions.)
1) Remove the cover from the air gap at the top of the sink (usually a short chrome domed cylinder that sits at the back of the sink), and, using a stiff wire, clean it out. Also check the entire length of the drain hose for kinks or blockages, especially at the drain connection to the disposer or drain line.
2) Once the dishwasher is cool, shut off the power to it, and—if your dishwasher is made to allow this—remove the strainer, located under the bottom spray arm at the base of the cabinet (see illustration). Unscrew the hubcap, lift the spray arm off, and remove any clips that hold the strainer to get it out. Scrub it clean with a brush, then replace it.
3) Determine whether the sink trap or house drain line is clogged.
4) If the dishwasher still doesn’t drain properly, the drain hose may be clogged or the drain valve may need replacement. You can check the drain hose for obstructions, but this sometimes involves pulling the dishwasher out from under your counter to access the hose, disconnecting the hose at both ends, and flushing it out with a faucet or garden hose or replacing it with a new hose.
on Sep 03, 2010 | Dishwashers
Dishwasher will not drain
Hello there and welcome to fixya
Please check the following carefully
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it. Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced. Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Oct 05, 2011 | Neff 24 in. S5409X0 Built-in Dishwasher
Hello. after washing water still inside of machine. MAYTAG QUIET SERIES 300.
Hello there and thank you for choosing fixya
Drain line/air gap
Pump
Belt
Motor
Timer
Jun 29, 2011 | Maytag Dishwasher
Slow or no drain of water. cleaned out sump covers and ran drain cleaner thru cycle. looking for possible secondary filter.
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
Hope it helps...
Jun 27, 2011 | Hotpoint Dishwashers
Kenmore dishwasher won't drain. Can hear motor trying to cycle but it sounds like it's locked.
Hope it helps...
Jun 23, 2011 | Dishwashers
Will not drain
Jun 23, 2011 | Thermador DW44Z Built-in Dishwasher
Frigidaire Dishwasher Professional Series runs loud now and the dishes aren't clean when it finishes its cycle.
Check the water supply line for kinks, check bottom strainer/drain inside to remove particles/trash blocking water from exiting to pump washer motor, be sure no items block rotation of washer heads. Good luck.
Feb 26, 2011 | Frigidaire Professional Series 24 in....
What would cause my dishwasher not to drain?
not sure if you have posted the model number of your dishwasher.
There are several reasons for dishwasher not to drain.
1. faulty drain pump
2. clogged kitchen sink drain
3. drain cycle is not reached due to faulty dishwasher controller
4. clogged drain hose
5. the wash cycle is not completed due to heater not heating water - (try rinse cycle to confirm)
Happy to help if you can provide some details on when the drain cycle is not working. do you get any alarms on dishwasher..etc.
Feb 25, 2011 | GE Nautilus 24" Built-in Dishwasher
Dishwasher doesn't drain properly
Following a cycle, a small pool of clean water inside the tub is normal. An excessive amount of water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up.
GA_googleFillSlot("HT_Appliances_Dishwashers_Articles_Box_Top_Left_ATF_300x250");
GA_googleCreateDomIframe('google_ads_div_HT_Appliances_Dishwashers_Articles_Box_Top_Left_ATF_300x250' ,'HT_Appliances_Dishwashers_Articles_Box_Top_Left_ATF_300x250');
If dirty water spews from the air gap, the drain line is kinked or clogged. (If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made; see your disposer instructions.)
1) Remove the cover from the air gap at the top of the sink (usually a short chrome domed cylinder that sits at the back of the sink), and, using a stiff wire, clean it out. Also check the entire length of the drain hose for kinks or blockages, especially at the drain connection to the disposer or drain line.2) Once the dishwasher is cool, shut off the power to it, and-if your dishwasher is made to allow this-remove the strainer, located under the bottom spray arm at the base of the cabinet (see illustration). dishwasher_er1.gifUnscrew the hubcap, lift the spray arm off, and remove any clips that hold the strainer to get it out. Scrub it clean with a brush, then replace it.
4) If the dishwasher still doesn't drain properly, the drain hose may be clogged or the drain valve may need replacement. You can check the drain hose for obstructions, but this sometimes involves pulling the dishwasher out from under your counter to access the hose, disconnecting the hose at both ends, and flushing it out with a faucet or garden hose or replacing it with a new hose.
Thanks for using fixya.
Nov 02, 2010 | GE 24 in. GSD4320Z Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
