Question about Moultrie MFH-DGS-100 Digital Camera
Camedia 4.1 installation error
When installing 4.1, I get an error 0x80040707 Dll function call crashed Mfcdll.checkQTVer. I have tried to "run as" with unchecking the "protect my computer" box but this does not help. I have upgraded my motherboard to an intel since I last run this program. I'm using XPpro as I did with my other MB. Any suggestions please. I reinstalled Windows XP Pro and I cannot reinstall Camedia Master 4.1 for my Olympus camera, a Camedia D-560Zoom. I have searched the Olympus web site but have found no provision for technical support.Siskiyou tryin to install software for camedia 4.0 after upgrading to a quad, i get the same error message everone else is having tried doing the install in unprotect mode and still had the same error
  • buzzsaw14 Jan 25, 2009
    Still have the same problem with camedia 4.0 tried going to the link i was gien online and downloaded the software was given the same error code. I could use a driver program but once again this is an extra cost. There must be another way to correct this thanks
  • Moultrie Master
  • 19,396 Answers
You did an XP upgrade installation, this did not help.
You need to save all files and software and setup XP as a new system, and then install camedia.
Posted on Jan 26, 2009
  • 15,935 Answers
If you're getting this error message as part of an installation or upgrade routine, here's one of the easiest ways to circumvent the problem:
    1. Go to the directory that holds the file for launching the installation (for example, Setup.exe).
    2. Right-click on the installation file and select Run As.
    3. Uncheck the box that says Protect My Computer And Data From Unauthorized Activity, and click OK.
Alternatively, if you're running this installation from a CD, you may need to simply clean the CD and try the installation again. Another possibility for resolving this error is to run Windows Update on the system before running the installation routine.
This error might occur if there is a missing or invalid path in the registry. These registry entries need to be fixed in order for the installation to complete successfully.
Please CLICK HERE for step by step instructions.
After all is said and done, and you still get the error, it may boild down to a vendor software problem, and not with your PC at all.
Thank you for using FixYa, a FixYa rating is appreciated!!
Posted on Jan 25, 2009
  • 818 Answers
. Go to the directory that holds the file for launching the installation (for example, Setup.exe).2. Right-click on the installation file and select Run As.
If none of those solutions work, try these link , which provide additional information on the error and ways to overcome it:
http://consumerdocs.installshield.com/selfservice/viewContent.do?externalId=Q108167&sliceId=1
  • 4,806 Answers
Hi there
This could be a couple of things
Have you installed service pack 3 and then performed a Microsoft Update? that could resolve the problem.
The error message means that the installer is somehow getting confused with an internal command and setup will not continue, to resolve this problem you have to edit the registry manually, this procedure can take some time to work out to the novice but Microsoft provides a page where it will walk you through how to fix the error.
Good luck
    Brigadier General:
  • 8,619 Answers
Hi
Do not install the driver from the cd .Kindly install it from the link as it could be because of a corrupted cd .
Thanks
Rylee
Posted on Jan 18, 2009
PC nascar thunder 2003 install problem
i think something is wrong with the game..no .dll file no game, or maybe you'll need to crack and patch the game...without a crack folder or a patch folder i cannot help...sorry
Dec 24, 2012 | Video Game Consoles & Games
I cant Uninstall / Install nero
Nero can be a pain in some cases, and they know it, that is why they developed the Nero General CleanTool. Download it HERE and run it.
I hope this helps!
Mike
Dec 30, 2011 | Ahead Software Nero 7 Ultra for PC
Error 0x80040707
installation program error, remove and reinstall the game, maybe you will have to contact your phones vendor worst case- good luck!
Aug 18, 2009 | Sharp Wizard OZ-590A
Using 2wire 1800hg Home Portal. Have successfully connected with PC Port Adaptors using the existing telephone line. No problems. Then purchased a laptop w/ Vista installed. 2wire setup CD causes error...
Listen, you do not need that CD! This is already configured. That cd is for other types of troublesome operating systems that just cannot seem to get is DNS settings right such as windows XP. The cd is for XP only you do not need this with vista.
Thanks
Jul 18, 2009 | 2wire 1800HG Router (RG1800HG00)
MFC-260C installation problems
Go to:http://www.errornerd.com/stoperrors.php?seed=0x80040707
See it doesn't help you solve your problem.
May 20, 2009 | Brother MFC-260C All-In-One InkJet Printer
Error 0x80040707 & Direct x
You are missing a Direct X control that the player is looking for - check your security settings to make sure you are not blocking a key download. :-)
Feb 22, 2008 | SanDisk Sansa c200 MP3 Player
I have the answer!
I had same problema nd found solution on another board.
It is a quicktime error.
Download new quicktime software from here;
http://www.apple.com/quicktime/download/
Then camedia will load/install.
Cheers
Albert Teacake
Oct 07, 2007 | Moultrie MFH-DGS-100 Digital Camera
Moultrie MFH-DGS-100 Digital Camera Logo
46 people viewed this question
Top Moultrie Cameras Experts
Steve
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
