Question about Dishwashers
Kenmore Dishwasher - Wife Having Meltdown
Model 665.13593K600
2yrs Old
Ultrawash - Standard
Never had a problem until I went to run today. All display lights work but Start/ Resume. I reset breaker - nothing. Is there a reset sequence that may work? I took panel off, nothing out of ther ordinary. No smells/leaks.......
My wife is having meltdown please help. Thanks
  • dada177 Apr 15, 2009
    I turned my dishwasher last night but when I woke in the morning, there still a water at the bottom and when I tried to turn it on it won't. Any button won't turn on, so I turn off our main power switch it did not work also. I tried to find the switch for the dishwasher but I can't find it. Do I have to remove the entire dishwasher? Please help..
    Sergeant:
  • 229 Answers
Get under the sink and pull the plug. Let it sit for a half an hour or so. While you wait make sure all the drain screens etc. are clean. Usually unplugging will reset board. Kind of like a reboot on a computer. I hope this works usually does if something else major isn't wrong.
Posted on Jan 18, 2009
Kenmore dishwasher ultrawash debris on glasses
Fill the soap cup with vinagar and run it while its empty.
Mar 09, 2012 | Kenmore Dishwashers
Purchased 2007, Kenmore UltraWash d.w. makes loud buzzing noise that stats about a minute after 'start' and continues most of the time throughout cycle. Think it's the pump? Can't easily get it to be...
Please provide model number of the kenmore dishwasher.
Is there water in the base when the wash is complete? There could be couple of pumps in some Kenmore dishwashers - so hard to know which one until model number is known.
Dec 06, 2010 | Kenmore Dishwashers
Dishwasher is making a grinding sound, water and pump are working ok Kenmore ultrawash II (15years old) fix or buy another?????
Sounds like something in the pump, only guessing at this point. If you are capable take it apart and check it out. You can tie down the rotating arms inside then run the machine to be sure it is not one of them.
Good Luck,
Gilshultz
Dec 03, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Ultrawash Quietguard Deluxe Problem
kenmore washers nothing but problems, my washer says clean and will not do any cycles...... less that 2 years old
Oct 21, 2009 | Kenmore Dishwashers
Kenmore UltraWash Dishwasher is leaking from black hose...
No you will have disconnect the copper line. I would suggest that while you have it out that you replace the copper line with a braided stainless steel hose (also known as a dishwasher connector hose) If possible get a 60" or 72" hose so you can hook up the dishwasher when it is out and then push it back in with the water supply already hooked up.
Jul 31, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Dishwasher
grazi, your part number for the use and care manual is LIT3368766. You may have to call Whirlpool, thats who made this dishwasher and inquire with them. Im not finding it on any parts suppliers...Catriver.
Feb 03, 2007 | Kenmore 24 in. 16304 Built-in Dishwasher
Dishwashers Logo
406 people viewed this question
Top Dishwashers Experts
