Question about Fujitsu 24R1 Air Conditioner
Awful smell coming from inside unit of split system when on
Bad smell like a damp cellar coming from the inside unit when switched on still smells after 30 mins run time
4 Suggested Answers
  • 140 Answers
SOURCE: Water coming from inside unit of Fujitsu airconditioner
Go to http://www.fujitsugeneral.co.nz/scripts/get-manual.pl?manual_id=36 to get the manual. Any questions please ask. Please rate me so I know if I helped.
Posted on Dec 30, 2008
rayname
  • 70 Answers
SOURCE: Wall unit emits a chemical smell when the unit is running
check the condensate pan clean out with vinegar water solution make sure you do not see any oil residue that would be a sign of a refrigerant leak let me know if you have further problems your manual should tell you how to get the cover off
Posted on Jan 08, 2009
  • 400 Answers
SOURCE: Will Not Heat
On the outdoor unit the fan should not be running, on the indoor unit the fan should be running. If you then check the outdoor unit with fan not running, you should be able to hear clearly that the compressor is actually working. If this is all correct, it is possible that your fourway reverse valve is seeping and needs to be replaced.
Posted on Apr 15, 2009
Why is there a damp smell when I open the door?
Front load washing machines have to be hermetically sealed so they don't leak. Of course opposite of their top-loader cousins. :) In your case, Try cleaning the drum and the door seal and also remove any and all soap residue that you can find. Then try running an empty load with vinegar and/or Borax. You can try bleach, too if that doesn't work. When it's all clean and smells 'normal' again, be sure and keep the door cracked open when you're done using it from now on. Being closed and sealed all the time is why mold and mildew have grown, causing it to smell bad. I hope this helps! :) -Jason
May 02, 2014 | Samsung WF1124XAC 1400 Spin 12kg Load Eco...
My machine smells damp and musty in between uses. it smells like there is stale smelly water in it, it`s so bad that we can`t leave the door open. This is only a recent thing, we have pulled it out and...
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Washing Machines
Terrible smell inside the dishwasher. Bad drain smell
Hi
The smell usually comes when the unit is unable to drain water completely, you can run your dishwasher at its hottest temperature setting with 2 cups of vinegar inside the unit. After this take off the lower front panel and clean the drain pump assembly completely, also clean the drain hose, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Aug 05, 2011 | Dishwashers
We have a bad smell coming from the fan in the freezer and smelling up the whole unit. What could the problem be?
Check the back of the fan for debris and also check that there is not water making it thru the bottom of the freezer causing dampness/mould etc. What kind of smell is it?
Jun 21, 2010 | Refrigerators
Funky smell coming from bottom of frig when running
Is it a musty smell or that of something / (rodent) decomposing? If you only smell it when it is running then look for BLACK gunk that will probably appear almost like a paste. Even things like cat or dog hair will collect in damp areas. There should be a white plastic drip pan under your unit. Look for the freezer white plastic drain hose on the rear bottom of your unit on the freezer side and follow that hose to the drip pan. It catches water every time the unit defrosts which is 3 - 4 times a day depending on which defrost timer your unit has.
Usually there is a build up in the drip pan that gets mucky and then stinks like mold. It will of course need cleaned.
Also look at the fan area for the coils. Sometimes there are unwanterd home critters that attempt to get through the running fan blades and end dead up inside the cooling coil metal radiator area.
Feb 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Bad smell from ac unit in my house
does it smell like literally , dirty socks?if so it is dirty sock syndrome, a plague of heat pumps for years. if it smells like an electrical melting or burning of wires then time to call a pro.it could be a weak capacitor or a weak fan motor. if it is dirty sock syndrome then its the microbes that thrive when temps are middle temps and reproduce when temps are hot and cold in intermittent days. hot one day and cold the next equals call for cool then call for heat and hot steam from heated coils cause s bacteria to grow and microbes to spread across coil. when you switch back it causes the smell.if the coil is clean you can spend a chunk of money on sanitizers but best bet is to run it cool for hot weather and hot for cool weather. the transitional periods are what create the smell. avoid semi cool and semi hot periods. this condition is common to acs from all brands . lots of stuff on the internet about dirty sock syndrome
Oct 31, 2008 | Sharp CV-P09FX Air Conditioner
Fridge problem
usually the smell is the water dripping into the pan under unit place cleaners and use charcoal inside unit to remove odars that collect on evaporator and get concentrated then go to drip pan
Feb 11, 2008 | Frigidaire FRT17G4B Top Freezer...
Fujitsu 24R1 Air Conditioner Logo
102 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
