Question about Craftsman Air Tools & Compressors
Craftsman air compressor 28 75113
The motor is running but will not inflate anything
hdpanama
  • 65 Answers
SOURCE: Craftsman 6hp / 60gal air compressor
Make sure your pressure switch is set correctly. Check your pressure gauge and make sure it is functioning correctly. Also,seems sometimes if there is any time when there isn't the adequate amount of power demand supplied the motor heats up more causing the thermal protection switches to act a little finicky which in turn shuts it down.Check how many amps the motor is rated compared to the breaker controlling the circuit. Is it a dedicated circuit only for the compressor or are there other things also drawing power from the circuit ?
Posted on Nov 17, 2008
SOURCE: craftsman aircompressor bogging down
Yes , the check valve will cause this. The check valve has a flat disk with a spring that holds it down that the air passing past it erodes away till it leaks then the air that the piston pushes into the tank does not stay in the tank but returns right back into the cylinder and puts a load on the piston. Also makes the compressor hard to start back up if it does get pumped up. Some have a dump valve that drains the pressure off the head after they shut off so it can start with no load. So if there is air bleading back and leaking at the pressure swith that will be a for sure sign it is the check valve.
Posted on May 20, 2009
  • 497 Answers
SOURCE: Craftsman 30 Gal. 150 PSI Not building air over 45lbs
The compressor valve may have a faulty gasket or seal, and maybe leaking air internally. Or the compressor might be going downhill. You can try to replace the valve seal and see if that makes a difference, otherwise you need to replace the compressor.
Posted on Aug 27, 2009
ollie reece
  • 1167 Answers
SOURCE: i have sears craftsman 22gal 5 hp air compressor not enough press
hi buddy strip the end off the check valve out and inside is a rubber turn this rubber around and try this if it still downt work it sounds like the pressure switch faulty get back to me
Posted on Oct 05, 2009
Testimonial: "thanks i took out the check valve i see the rubber but the valve is 1 piece should i just get a new one"
dmftrucker
  • 1922 Answers
SOURCE: Wiring diagram to convert Craftsman 5HP Air compressor
look on the motor cover or on the wiring cvr on mtr or on the inside of the wire termination cvr
Posted on Oct 06, 2009
I am trying to inflate flat tire and can't get it to inflate with air master air compressor 59008. what am I doing wrong?
Jack the car up on the side you want to inflate to get the weight off of it. No compressor that i know of that plugs into a cigarette lighter is strong enough to inflate a flat tire under that much weight.
Nov 01, 2012 | Mini Tools & Hardware - Others
My craftsman 3gal. compressor starts and run but no pressure is building up.it just keeps running and the gauge remains at 0 psi.
Is the petcock down below open or closed? If open, then screw it closed. Also, is the compressor portion connected to the motor working as it should? As the motor reciprocates, it should operate the compressor piston that pumps air pressure into the tank. Maybe something is broken there.
Nov 04, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
MY COMPESSOR GAGE SHOWS 135 PSI AND 135 ON THE OUT PUT GAGE BUT I CAN,T INFLATE MY MOTORHOME TIRES TO THE REQUIRED 110#.DO I NEED A LARGER COMPRESSOR?I CAN,T FIND ANY LEAKS.
It is possible that the compressor psi as it is running drops below the tire psi creating a standoff. You must maintain air compressor psi over 110 to fill a tire to 110psi. Add air to your tire but stop when the compressor motor starts to run. When the motor stops then continue to add air until the compressor motor starts and again stop airing up the tire. Repeat as needed.
Dec 25, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Can not build working pressure pressure......
The most likely problem is a burned out "run capacitor" on the motor. If you continue to try to run your compressor in this condition it will burn out the "starting capacitor" and/or motor as well.
It's also possible that you have a bad start up pressure relief valve, this valve will be between the compressor and the tank. If this valve is working properly you should hear a hiss of air as the compressor motor shuts off.
A reasonable motor repair shop should be able to replace the run capacitor for $20-$50 plus inflation, depending on your area.
If you need to test the start up pressure relief valve, you need to take it loose at the compressor or tank. Just loosening the line may not work depending on the style used. Note: sometimes just taking this loose to test it causes you to have to replace the valve.
May 29, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Motor runs pressure stays around 25psi
if they are oilless compressors then the rings are worn
Jan 15, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
1hp 4gal 2 tank Craftsman Air Compressor not Compressing
Try emptying the tanks completely. There should be a bleeder valve for each tank. Sometimes after sitting for a while with pressure, the compressor won't have enough power to start. If you get the same response with empty tanks, there is a problem with the pump pistons.
Dan
Jan 11, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Why did my craftsman 5 hp 240 volt 125 psi air
your motor overheated from too low a voltage if theres a manual reset try this,also replace the two motor start and run capacitors on the motor body
Dec 24, 2009 | Air Tools & Compressors
The compressor runs (rather noisy) but the pressure increases very slowly and not very high
Please do not take offense to anything I say but your compressor because it has nothing to do with you. It's a personal grudge against that particular air compressor and the Air Compressor **** that designed and built it. It is a piece of junk, and that's the nicest thing I can say about it.. The model you have was built for one thing and one thing only. It was to get an air compressor into the hands of customers that never really needed an air compressor for anything more then inflating a tire or a basketball. My friend's mother bought him one because, as she put it "it was cute". In all seriousness it is a throw away air compressor. I have seen several go bad with less then 30 hours time on the pump and motor. If it is bad and from your description it sounds like it, there is nothing you can do about it. Impossible to get parts for unless they come from another one of the same type. I'm sorry that I can't be more helpful. What I can say is you are better off to replace it. There are plenty of similarly sized and priced compressors that are far superior to the 3gal. 11/2 hp craftsman. The Senco PC1010 is a great compressor for it's size and specs. Good luck
Nov 09, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a craftsman air compressor (small) with 2 wheels on end, my probelm is when i plug it up it buzzes only, will not start motor, what could be problem
unplug it and see if you can turn the motor pulley by hand, it should turn freely. If it does, check to see if the motor runs with the belt off. If the motor runs by itself then either the belt was too tight or the compressor is seized.
Aug 12, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
74 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
