Question about Kenmore Elite HE4 Electric Dryer
Starts with asistance then shuts off.
It is a Kenmore Elite dryer 110.63032101.
If I tape door switch on, push start while rotating drum, dryer starts. It then shuts down after 1-2 minutes. It will not start without assistance.
jeffyoungsemail@yahoo.com
    Problem Solver:
  • 14 Answers
A centrifugal switch selects the start winding, but the run winding is always selected, according to the wiring diagram.
So, it could be a bad centrifugal switch, or a bad motor. You can test the motor by measuring the resistance between the blue and white-orange wires (the run winding), and between the blue and violet wire (the start winding). Both values should be under 4 ohms.
To continue running, the motor run winding must be OK, the door switch must be closed, the belt switch must be closed, and the thermal fuse must be OK.
All this assumes the electronic controller is OK, but this is the stuff a handy homeowner can check before calling in the big Sears guns.
Posted on Jan 20, 2009
Kenmore elite he5 dryer has no power or start up
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
Jun 21, 2014 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer 70 series doesn't always start, sometimes it will just put out a buzzing sound after its been running and trying to restart, will start back up after 20-30 minutes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Oct 02, 2011 | Kenmore 63942 Dryer
When I push the start button, the dryer does not come on, but it just hums.
Check to see if you can rotate the drum. if you cant then you need to check the blower wheel. If you can then hold the door switch in and start the dryer. if it starts to hum rotate the drum while holding the door switch in. if it runs on it own after you rotate it then you need a new motor
Jul 12, 2011 | Kenmore 600 6963 Electric Dryer
My dryer keeps shutting off after about 10-15 mins. It starts make a noise likes it's slowing down just before it shuts off. If I try to push the knob back in to restart. It will make a buzzing noise. If I...
Mar 13, 2011 | Dryers
When pushing the start button dryer hums but does not spin. when u release start button dryer shuts off
Sounds like a bad motor. Check to make sure the drum isn't stuck, if you can spin the drum put some tape on the door switch and press the start button while you spin the drum. If the drum continues to rotate, you have a bad motor.
Mar 10, 2011 | Maytag Washing Machines
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
f you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 18, 2011 | Kenmore Dryers
Have a Kenmore 90 series gas dryer. When I press the button to turn it on, it makes a noise but won't start
Assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem. Check the blower fan and motor for any obstructions.
Jan 09, 2011 | Kenmore Dryers
Kenmore elite 110.63032101 dryer has electric, start button seams to be working, but pushing door button and turning drum still won't start it?
is the motor humming or did you start it like this before by spinning the drum,if so you have a bad motor,also is the door switch making a clicking sound when you push it in and out,it should if it doesn't you could have a bad door switch,read it out with a meter and make sure you have power to the motor,
Feb 20, 2010 | Kenmore Dryers
Dryer turns on, but does not run
Try to turn the drum inside with no clothes in it, does it turn freely both ways?
Then as someone is holding the start button, hold the door switch button, then try to turn the drum counter-clock wise, and see if it will start turning on its own.
If it does start turning, then the motor is more than likely the problem.
If it dosen't then the timer is more than likely the problem.
Feb 05, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite HE4 Electric Dryer Logo
105 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
