Question about Roper RGX4634KQ Gas Dryer
No heat roper dryer (gas) runs but no heat model#rgx4634jq0
  • Dan Webster
    Dan Webster May 11, 2010
    Can you hear a click? If you can then that means ignitor and sensor is working. So you need to change the coils part #279934.
    If it don't click you needs either a Ignitor broken or the flame sensor is open. Get one of those meter that beep when you put the 2 wires together. Then remove the wires on these parts and see if they make that meter beep. If not then you have found the bad part.
    Guru:
  • 462 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} These are the standard things to check out a gas Dryer. If you feel confident
Do you get a "glow" the glow (orange in color) is for the gas to be ignited?
.1 No glow indicates a no voltage problem to the burner or the igniter is out. Confirm power to the gas valve area 110V usually. If you have voltage the problem is somewhere in the area your in; probably the igniter.
2 If you don't have 110 Volts the problem is in the controls. The fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating (s), are all suspect and have to be eliminated 1 by 1.
Hope this helps. With any luck all you need is a new igniter.
Clean the duct out while replacing the igniter if so because the main thing that causes igniter burn out is low air flow. A kinked Dryer vent hose, lint, and plugged up fan circulator on the motor, or if yours has little holes in the inside cabinet where the air is taken to be heated and recirculated, these can get clogged with lint also and cause a problem are the 4 main causes of low air flow..
Hope this helps and please rate me accordingly Thank you and good luck.
Posted on Mar 13, 2009
Roper Electric Dryer...model RED4440XQ0 will not heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 04, 2011 | Roper RES7646KQ Electric Dryer
The dryer heats up for a few minutes the continues to run with no heat it is a Roper dryer model number RGS7646KQ3
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 25, 2010 | Roper RES7648E Dryer
Roper gas dryer does not heat, timer does not move, runs continuously, can the timer malfunction cause dryer not to heat?
heatman101
Oct 22, 2010 | Roper Dryers
ROPER GAS DRYER WILL NOT BUT RUNS
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 13, 2010 | Roper REX4634KQ Electric Dryer
I have a Roper Gas Dryer model RGX5634KQ2. The
My bet is that your ignitor is bad....change the ignitor and you will be working again...
Here is a tip that I wrote about your problem that will explain it further...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 30, 2010 | Roper Dryers
Roper gas dryer does not heat.
If the ignitor is not powering , go to the switch. That has to send power to the ignitor, then on to the gas valve.
Jul 22, 2009 | Roper RGX4634KQ Gas Dryer
Dryer runs but is not heating up
Hi, Could I get the model # so I can assist you further?
I need to know if it is electric or gas .
Thanks
Vic
May 30, 2009 | Roper RGX5635E Dryer
How do i open the machine to get to the coil valve/ do i remove the blower wheel? and if so how is that done (roper mod# rgx4634jq0)
Here are the break down diagrams and Replacement parts for WHIRLPOOL RGX5634KQ2 |
AppliancePartsPros.com
Did you check the element?
Check if glow?.
also checked the continuity of the flame sensor.
If is good.
Am I to assume then that the heating element is bad? Or could there be another issue?
thia mean that the thermal fuse is bad.
You need to replace along with the cycling thermostat and see what happens.
"Did it solve your problem?"
Apr 18, 2009 | Roper RGX4634KQ Gas Dryer
Dryer not drying cloths
http://www.pcappliancerepair.com/model-display.php This shows the screws (#2) that hold the front on. Use a putty knife to push on spring catches (#20) to release the top.
Jan 24, 2009 | Roper RGX4634KQ Gas Dryer
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Roper RGX4634KQ Gas Dryer Logo
152 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
