Question about Philips DVP3150V/37 DVD Player/VCR
My remote has stopped working
My remote will still turn the unit on and off, bur the directional buttons etc. suddenly stopped working
2 Suggested Answers
tariq_romy
  • 116 Answers
SOURCE: remote control power button and stop/play/home dont work
open the remote clean with petrol
or ony from dry cloth
thare was a corben in that key becouse that key are more useable so carben
Posted on Feb 19, 2010
MY TV REMOTE SUDDENLY STOPPED WORKING WHAT COULD BE THE PROBLEM
Reprogram!
HOW TO PROGRAM Remote Control DOING CODE SEARCH
1. turn on device 2. press setup (underneath on/off) till red light stays on then take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinks off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code
Dec 30, 2014 | Televison & Video
Buttons stopped working
if remote designed for tv, and or other units the mode button may have been pressed etc.
Set to dvd etc instead of one for unit being used on.
The remote can be tested by any shop (usually for free) to see if it is sending a signal......
Oct 30, 2012 | Universal MX-900 Remote Control
Program toshiba tv remote ct-885
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Code Search Method
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
    Codes to Check:
    013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
    0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
Mar 31, 2012 | Toshiba CT-847 Remote Control
Air conditioner was working great suddenly STOPPED working...cant turn it back on.
Hello
Is there a reset button located near the plug? If so reset it.
Check your circut breaker for the outlet its plugged into also.
If your using a remote to start this unit check that the battery is good in the remote,it may only work with a remote.
Jul 21, 2011 | Kenmore 76129 Air Conditioner
My sony trinitrion always displays the video input. Who used to faed away, but is now staying on all the time. Doesn't matter if it's input 1, 2, 3, 4, etc. Turned off and unplugged but still displays all...
Using the TV's remote and having the TV on,
hold down the "reset" button and manually turn off the TV directly from the unit.(not the remote)
Release the "reset" button.
Turn the TV back on-directly from the unit.(not the remote)
A dialog box will appear on your screen.
Choose "Auto" by pushing the + on Channel Selection button on the unit (not the remote).
Use the TV/DVD selection to return to your cable input.
Jul 17, 2010 | Sony FD Trinitron WEGA KV-32HS500 32" TV
My ceiling fan suddenly stopped working. It has a remote and 2 pull chains, and neither the light or the fan are working. Only button i see on side of fan is a slide button that controls direction of...
Did you notice if there was anything else not working in the house? If so, most likely a breaker tripped. If it did, then there is a problem with the circuit. Unplug everything on this circuit and try resetting the breaker. If it still has problems, call in a licensed electrician to troubleshoot the problem.
Did anyone work on anything prior to this event? May be a loose connection. turn off ALL the power in the electrical panel before you work on the fan because you have no idea which breaker (or fuse) operates this unit. Check all the connections in the fan. If the connections are good then we need to stop here because more details would be needed.
May 15, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Suddenly stopped working, green light on remote works, but no response from car. No locks, trunk, or start.
Could be many things, loose ground or power wire on the 561, there is an inline power fuse on the red wire leading to the control unit that may be blown. It may just need to have the remotes reprogrammed to the control unit, sometimes the control unit just stops recognizing the remotes. If you have recently had the cars battery replaced, or jump started the car, check the fuse at the control unit first.
Aug 17, 2009 | Directed Dei Valet 561r Remote...
Akai KC02-E1 Remote with new batteries stopped working.
First, You cannot resync the remote, Second the IR sensor may be bad on the tv and third, the Digital bd may be bad. The IR sensor connects directly to the Digital bd which is the brains of the tv. Also, there maybe a stuck button on the remote or the buttons on the tv.
Jul 13, 2009 | Akai PT4298HD Rear Projection Television
Philips DVP3150V/37 DVD Player/VCR Logo
13 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
