Trying to clean my kenmore elite calypso 110.25062500, how can I open to clean?
Have crud coming out on our clothes. Trying to find out how to open the machine from the top to clean.
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Calypso
"LF" is a "LONG FILL" error. This will occur if water fill time exceeds 10 minutes. I don't know why this would pop up at the end of a cycle. Normally this is associated with filling at the beginning of a cycle. There is also an "FL" error, which is an "OVERFILL" error. This is normally associated with a problem with either the control board or wiring harness. This normally occurs when there is an open circuit between pins 1 and 3 on P17 of the control board. That one is a little more involved and usually requires replacement of the control board, wiring harness, or both. If you, indeed, have an "LF" error I would check your water source coming in. Check your fill hoses for kinks or obstructions, first. Then, turn the water supply off and remove the hoses from the back of the machine. Place one end of each hose inside the wash tub and turn both water supply lines back on to make sure you have good water flow coming through the hoses. Replace the hoses if they show signs of bulging, cracks, leaking and/or restricted water flow. Turn water back off and check the fill valve inlet ports on the back of the washer for accumulations of sediments in the screens. It doesn't take much to restrict water flow. You can clean the screens with a cotton swab. If you check everything and still have problems with the error code popping up, I would replace the fill valve. It's an easier fix and less expensive than a control board. If you decide to replace the valve, it is located under the console on your washer, I believe. It's fairly simple with a couple of screws to remove on the console and a couple of connectors and hoses on the valve to remove. Make sure you unplug the machine and turn off the water supply before attempting. I hope you find this advice helpful. Let me know if this works for you.
Posted on Jul 14, 2007
jsrock516
  • 5911 Answers
SOURCE: Calypso kenmore elite - problems trying to wash a load
This is usually a symptom of a bad motor control board which located under the console. I had the same problem. You can open the console by removing the three screws in the back and lifting from the rear first. The console will pop off. In addition, if you look along washer top front edge in the seam there is a retaining clip about 2 inches in from each side. Using a putty knife, push in on each clip while lifting and the top should pop up. There will be a tech sheet affixed to the front wall of the washer between the wash tub and case. This tech sheet will give you all the guidance necessary on how to perform tests to prove whether or not the motor controller is at fault, or if the pump is at fault. I believe you may have a motor controller problem, though. Another possibility is getting something caught in the drain pump reservoir. This could binding the pump. Let me know if any of this is helpful to you.
Posted on Aug 16, 2007
watugot
  • 290 Answers
SOURCE: Kenmore Elite Calypso won't drain
The most likely thing to cause the code and the leak is the water pump. If the shaft seal on the pump leaks, the water gets into the drain pump motor and shorts it out. The code is telling you there is a high current/amp draw at one of the motors.
You can see if the pump is leaking by tilting the machine back, removing the screws that hold the bottom to the front edge of the machine and looking at the pump. If the pump is leaking, you will need a new pump and possibly a new motor control board.
Post back if you need further instructions and we will walk through the repair.
Posted on Nov 09, 2007
  • 113 Answers
SOURCE: Kenmore Elite Calypso wont drain
Oh the dreaded calypso pump...Seen that one a million times. Pumps get clogged pretty easily. Try to get the water out manually first. Than push the washer back and lean it against the wall so that you can access the bottom. Remove the 3 screws. Bottom panel should come off. The pump is on the right, its black. Get ready with a shop vac or alot of towels, theres gonna be a flood. There are 2 clamps on black hoses that need to be taken off so that you can slide the hoses off the pump. Next remove the 3 bolts that hold the pump in place. Next lower the pump out of the hole it sits in. Youll have to follow the wiring harness up and disconnect it. Now you can try and clen out the pump or replace it. Part # is 285990. Costs about 75.00. Hope that helps. Let me know if yiu need more help. Dave www.washermd.com
Posted on Dec 16, 2008
  • 49 Answers
SOURCE: my kenmore elite calypso keeps beeping Fl what
FL (flood condition) also can be an indicator of a bad pump. The washer tries to drain and cannot because the pump has failed or is jammed with debris.
You can run a complete washer diagnostic procedure to see if you can isolate the fault by doing the following. I recommend you make sure the room is quiet so you can hear the pump motor running when expected, as well as the main drive that nutates and spins.
Perform a "key dance" to put the washer in the diagnostic mode by pressing the Prewash Options button, Wash Time, Prewash Options, Wash Time - each 2 times in rapid succession within 5 seconds total. The display will change to 99 and begin counting down (in seconds) as it runs the following tests. Listen for the pump motor to actually run and not just "hum", indicating a jam or burnout.
Display 99-81, Nutate & fill
Display 80-61, Nutate & recirculate
Display 60-41, Nutate, Fill & drain **
Display 40-21, Nutate, Fill & drain **
Display 20-0, Spin & drain **
You can cancel the test in progress at any time by pressing the Stop/Cancel button.
**during these phases the pump will run forwards and backwards (recirculate & drain). If you do not hear water pumping inside the washer or draining out the drain, your pump is likely bad and needs to be replaced.
The old style pump was a two-part assembly and the re-engineered part # mentioned above is a single piece that solves the impeller failure problem the original pumps were prone to have.
www.pcappliancerepair.com sells replacement pump part # 285990 for this washer and they are a reliable supplier with a good value. You can purchase a lifetime warranty on the pump from them for an extra fee.
Unfortunately there is not enough room in this text box to post the pump removal & replacement procedure but you can get your local handyman to do the work for you if you are not inclined, as I was, to drain the washer and turn it on its side to figure out how to replace the pump.
The other problem is that once you start getting a pump failure you need to look at the root cause. If the pump was ruined by draw strings or debris being sucked into the pump impeller, it is time to replace the top wash plate assembly (the plastic plate inside the washer that the clothes sit on).
There is a rubber seal on the outside edge of this plate which wears out over time and rotates upward, opening a bigger gap between the plate and the stainless steel drum which lets draw strings and other things get sucked all the way down into the pump. The upper wash plate & seal is a single unit and the seal itself cannot be replaced as it is molded into the plastic piece. Order this from Sears to insure a more recent 'cure date' on the rubber seal from the manufacturer, rather than 3rd party suppliers who might stock the part for longer periods and have old rubber seals past their cure date. The wash plate should be replaced about every other year.
Posted on Oct 03, 2009
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Kenmore Calypso washing machine has an odor during washing cycle
clean the washer with bleach and a small amount of detergent
Apr 20, 2010 | Washing Machines
Where is the filter located on a kenmore elite calypso washer
reomovethe 3 screws across teh lower acess panel, youll see the filter clean out right behind there , be warned before unscrewing get a plastic bag, or a few towells you will getwet!!!!!!
Mar 17, 2009 | Kenmore Washing Machines
Kenmore elite calypso top loader clothes still wet after spin
more than likely the machine has a bad clutch or motor.. in most cases it is cheaper to just buy another top loader.
Mar 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite calypso 21086 leaves dirt streaks on clothes
Run the hottest & fullest cycle possible - without a load - and add a grease remover - like goo-gone. Fatty tissues build up inside the tub - and can be released on hot cycles if HOT wasn't used very often.
It is recommended to run a HOT load every 2 weeks or so to avoid these buildups and staining of clothes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 20, 2009 | Kenmore Elite 21086
Black stains on white table cloth
Hi! topjdog
I hope you have been running the monthly cleaning cycle. This includes cleaning the front gasket.
InMrFixIt
Aug 16, 2008 | Kenmore Elite HE4 Electric Dryer
CL or CA is an over amp draw most likely caused by the motor thermal protector or motor controller It can be caused by too large of a load try to press "STOP/CANCEL" to clear if the problem returns you will need to get inside the unit
Jul 09, 2008 | Washing Machines
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
