Question about Refrigerators
Looking for schematic for GE model TCC18JAAARWW fridge
Blow-up of parts and location of compressor and condenser
MNTECH
  • 1543 Answers
SOURCE: ge fridge
Most likely it is the defrost heater. (it's that thing at the bottom of the coils with two wires leading from it.) To test it for sure, you'd have to use an ohm meter, but many times you can visually see that the heater is bad. Defrost the coils with a hair blower. If you don't have the heater on hand, the refrig will work fine for a week until you can replace the heater.
Posted on Sep 20, 2008
  • 833 Answers
SOURCE: Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Posted on Nov 20, 2008
SOURCE: GE TBX25ZLB Refrigerator Compressor won't Engage
Part number for compressor relay is WR7X222. However, you have a very old rotary compressor there and most likely it went bad. I would just buy a new fridge. Don't waste your time/money. The fridge is too old.
GE refrigerator repair in orange county, ca
Posted on Feb 06, 2010
walesarumi
  • 6993 Answers
SOURCE: GE profile pfs22sisass frenchdoor-freezer bottom
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food
As for the fridge, the same solution but for more details. If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
I hope the above helps.......
Good luck.
Posted on Apr 03, 2011
Macmarkus
  • 2605 Answers
SOURCE: GE Profile fridge: freezer is
Hello, welcome to FixYa.
I understand based on your post you have a GE profile PFS22MIS fridge not cooling in the fridge (upper cabinet) section, correct ?.
It is possible the problem is related to the condensor fan, but not likely. The difference with these fridges and many others (especially the older fridges) is the condensor fan does not run all the time. Instead the control board at the back (pcb) tells it when to run and at what rpm to run as well, it is a variable speed fan motor...and may in fact not run at all at periods.
The one thing I'd suggest you inspect is the back wall of the freezer. You mentioned the evaporator fan motor is operating, correct ? Is there any frost build up on the back wall of the freezer section, or if not visible have you removed the back wall of the freezer ?
I will need to watch for your reply before going forward. I hope you can appreciate there are so many variables since the fridge has many factors controlling air flow which in turn determine what the possible problem and solution will be.
Sounds to me it is a damper or blocked evaporator initially at least. Let me know what you find and we'll go from there.
Regards,
Macmarkus :)
Posted on Sep 20, 2011
Stopped working. clicking sound when it wants to start up. Is it the compressor or the relay switch model 8 yrs old old.
You.have to check if the compresor is working or damage. Try starting direct the compresor, Generali should be the electric part outside the compresor just change at the electric parts and should work. If you send a picture of the position on the connectors I will help you to try the compressor
May 29, 2015 | LG LFX25960ST Stainless Steel French Door...
My fridge gets really hot on top and between the fridge and freezer where the door meets
next time send the model number and brand name.usually when this happens is the condenser fan motor isn't working.pull the fridge out,remove the bottom back panel and check the fan to see if it's working,if it is check the condenser coil to see if it's filled with lint and dust,it could just need to be cleaned out but if it's that hot most likely the fan isn't running,if you get this tonight check it now,if the fan isn't running you could blow the compressor,the condenser fan blows and keeps the compressor cool enough so it doesn't overheat by moving the hot air and the heat also esscapes through the condenser coil so if that's clogged with dust the machine will run hotter than normal,if the fan isn't running you can stick any window fan back there and blow it onto the compressor to keep it cool until you fix the condenser fan motor,this way you won't loose any food and if the compressor goes it's new fridge time,to much to repair.hope this helps and good luck with your machine.one more thing,i've found the fans not running and by pushing the blade it runs again,if this happens the fan could run and never have a problem or it could stop an hour later but i would change it out no matter what.if it's a G.E. fridge and the motor isn't running,most likely it will be the computer board,i've found 10 machines doing this and the temp. settings turning on and off or the evap fan motor in the freezer runs slow and then fast and the condenser fan isn't running or running slowly,this is why you have to send the brand name and model number.
Oct 28, 2011 | Refrigerators
My GE bottom Freezer Fridge model pfse5njwdss not cooling at all. both fridge and freezer are not cooling, the lights are on and a very low sound exists, but not cooling. As if its not on.
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Aug 30, 2011 | GE Refrigerators
The feezer is not that cold and the door feels really hot it is a ge monogram from about 2000
Compressor is building up high head pressure. I'd be looking for another fridge since this is unrepairable in the long run
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 29, 2011 | GE Monogram ZIC360NRRH Bottom Freezer...
Where is the drain pan located on the GE Side by Side Refrigerator I have looked everywhere! Thanks in advance for your help.
why are you looking for the pan,you shouldn't have to do anything with it.the pan is at the bottom of the fridge behind the front kick plate and on some models there isn't a pan at all/the water drains to the bottom frame or floor of the fridge where the compressor is in the bottom back,the water collects there and the heat from the compressor and condenser coil evaporates the water.remove the bottom back panel,lok for the drain line or if it just defrosted you'll see the water sitting in the frame.what's happening that you're looking for the pan?
Feb 23, 2011 | GE GSL25JFPBS Side by Side Refrigerator
GE side by side unit. Freezer OK, fridge
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 – Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 – Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this work.....
Jul 28, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Side-by-Side Fridge only gets slightly cool at highest setting. Won't freeze water.
Have you cleaned the condenser under the frig?
While you are looking there look to see if the condenser fan is running with the compressor.
If the condenser has been blocked for very long or and the fan is not working there is a good chance that that the compressor is bad. Just clean the condenser and hope for the best.
Aug 04, 2009 | GE Refrigerators
GE Refrigerator external fan - air flow?
This really depends on the manufacturer and their preference on design. First, the fins at the compressor are part of the condensing coil. Most all makers have air pulled into the condenser coil and blown across the compressor. You should be moving room temerature air across the condenser and the air from that is usually then moved across the compressor.
Hope this helps clear it up .
May 08, 2009 | Refrigerators
Refrigerators Logo
105 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
