I have a BIW 145W Tricity Bendix W-M (lucky me). It stopped in the middle of a wash cycle and beeped 5 times. This is not i the manual (only 1-4 beeps covered). It may be an unbalanced load problem. However , when load removed , the machine just won't run any programs (even spin) and still beeps 5 times. Any ideas anyone? Help would be gratefully received.
4 Suggested Answers
SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Posted on Jan 05, 2007
  • 38 Answers
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Posted on Aug 26, 2007
SOURCE: Tricity Bendix BIW 105W Washing Machine
on a bendix 105w if you set spin programme(15) the pump comes on for 10 seconds then nothing, the belt is ok. on other programmes it washes and rinses as normal, just wont spin. help!!!
Posted on Aug 22, 2011
Tricity Bendix AW1400W Loud noise when spinning
The turning tube's belt or bearing may have problem.
If you know how to tighting the drive belt, you may try.
If not, maintenance or service persone should to call.
May 28, 2017 | Tricity Bendix Washing Machines
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
Apr 24, 2017 | Tricity Bendix AW1260W Front Load Washer
Machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Mar 30, 2010 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1001w
is the door locking if not replace it.
Nov 23, 2007 | Tricity Bendix AW1000W Front Load Washer
Machine stopped mid cycle - door light illuminated
this appears to me that you have had one problem and created another, based on what you say i guess the original fault was the pump or a blockage in the outlet system, now you have dismantled the door catch and made that a fault, if possible replace the door catch with one that is known to work, then retest to get back to original fault its a bit like "my telly doesn't wok it must be the on off switch" there's much more than the switch to anything, hope i have helped, if so rate me please
Sep 18, 2007 | Tricity Bendix AW1400W Front Load Washer
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Tricity bendix aw1400w
not only check filter but when filter out check for foreign objects fouling pump impellor. (bra wires are the favourite) if pump impellor not visible, then put onto drain and listen for a low humming noise in vicinity of pump. this confirms that pump is powered but jammed. all you can do after that is to check continuity of pump and check there is power to pump when on drain - assumes you have a multimeter
May 03, 2007 | Tricity Bendix AW1000W Front Load Washer
My tricity bendix washing machine flashing and beeping end light
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Washing Machines Logo
91 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
